Does the Alcubierre drive shorten distances?
  • Context: Undergrad
  • Thread starter Thread starter Jaime Rudas
    Warp drive
The discussion revolves around the Alcubierre warp drive and its implications for measuring distances in spacetime, particularly whether the distance between Earth and Alpha Centauri would be less than 4.3 light years when measured along a path through the warp bubble. The conversation includes theoretical considerations and interpretations of spacetime geometry, as well as the nature of the warp bubble itself.
  • Some participants propose that if an Alcubierre warp drive could be constructed, it would allow for travel to Alpha Centauri in less than 4.3 years due to changes in the geometry of spacetime.
  • Others argue that while the warp drive contracts space in front of the ship, this is compensated by an expansion of space behind it, suggesting that the overall distance remains invariant when measured through the warp bubble.
  • One participant asserts that the worldline of the spaceship is timelike, indicating that the ship does not travel faster than light with respect to the space inside the bubble, and therefore the distance must be less than 4.3 light years as measured through the bubble.
  • Another participant questions the interpretation of distance measurements, emphasizing that the distance from Earth to Alpha Centauri measured along a path through the warp bubble may differ from the distance measured from the ship's perspective.
  • Some participants highlight the need for careful interpretation of the ship's path and the properties of the warp bubble, which is made of exotic matter and has counterintuitive characteristics.
  • There are calls for mathematical backing to support claims about the requirements for the bubble's operation and the implications of the spacetime perturbations involved.
Participants express differing views on the nature of distance measurement in the context of the Alcubierre drive, with no consensus reached on whether the distance between Earth and Alpha Centauri remains invariant or is effectively shortened when measured through the warp bubble.
Limitations include the dependence on theoretical constructs of spacetime and exotic matter, as well as unresolved mathematical interpretations regarding the mechanics of the warp bubble and its effects on distance measurements.
  • #31
PeterDonis said:
It's neat that he responded!
And the superluminal velocity with which he did it.
PeterDonis said:
I would be interested to see his take on the spacetime diagram I mentioned in post #28. I would particularly be interested to see his description of how the Euclidean 3-dimensional spacelike slices he refers to are drawn on that diagram (they would be 1-dimensional spacelike lines on the diagram, which only considers motion in one spatial direction, but that would be sufficient to illustrate his meaning).
I would also be interested in his answer to the issue I have raised several times now: the ship's worldline is timelike, and it takes much less than 4.3 (or 4.1 if we allow for the distance ##d## at the start and end) years for the ship to go from the start point to the end point, so the distance the ship travels must be much less than 4.3 (or 4.1) light years.
Well, with his "normally I don't answer", I wouldn't want to abuse his kindness.
  • #32
Yes, I understand that. What I was actually hoping is that someone would be able to find papers in the literature where the issues I have raised are already addressed. Unfortunately I have so far not been able to find any. That is somewhat surprising to me, but it might be that the questions we are discussing have simply not come up in a way that would generate a paper addressing them. "Warp drive" physics is something of a niche field and there might not be many physicists actually taking the time to look at the details.
  • #33
Jaime Rudas said:
the CMB photons that we received today have traveled about 13.8 Gly
PeterDonis said:
No, the CMB photons that we receive today were emitted about 13.8 Gy ago. Saying that "the speed of light" means they must have traveled 13.8 Gly is not justified, because the spacetime they traveled in is curved.
By definition, a light-year is the length of the path travelled by light in vacuum during a time interval of one (Julian) year. From this, I deduce that if a photon has traveled for 13.8 Gy, then it has traveled 13.8 Gly.
  • #34
Under appropriate circumstances, yes. "Appropriate circumstances", when you dig into the details, turns out to mean flat spacetime.
And, as I said, this deduction is wrong because the spacetime in question is curved.
  • #35
So in curved spacetime the speed of light is not c?
  • #36
if you mean the coordinate speed of light, that doesn't even have to be ##c## in flat spacetime, if you use non-inertial coordinates.
In curved spacetime, in general, no, there are no coordinates in which the speed of light is ##c## everywhere, though you can find coordinates that make it ##c##, at least to a good enough approximation, on a local patch of spacetime (by choosing local inertial coordinates on that patch).
All this is why in GR we don't talk about "the speed of light" being ##c##; instead we talk about the light cone structure of spacetime, which is the actual invariant that "the speed of light is ##c##" is referring to in the cases where it's true.
  • #37
No, what I'm referring to is the speed of light understood as the length of the path travelled by light in vacuum per unit of time.
  • #38
And what, specifically, do you mean by "the path travelled by light"? Think carefully. In a curved spacetime, particularly one that is not stationary, like the spacetime of our expanding universe, there actually is no such thing as what I suspect you're thinking of--what anyone would intuitively think of in flat spacetime.
  • #39
Locally (that is, at each point), in an expanding universe, the speed of light is c. If I integrate it with respect to time, I get the length of the path travelled by light.
  • #40
So you are summing the separate local observations of many (infinite) local inertial observers, each at a different cosmological time and place (and these observers are not maintaining a static distance from each other as their world lines are tracked). You may accept this as a definition of distanced traveled, but it is very different from an everyday definition, and many another would not find it meaningful.
  • #41
PeterDonis said:
There is a comment to be made about this as well. What he means here by "three-dimensional space" is "a surface of constant ##t## in the coordinates in which the metric is standardly written". But while it is true that one can "read off" from his metric, without requiring any calculation, that the metric of such a surface is ##dx^2 + dy^2 + dz^2## (which makes it look like Euclidean 3-space), the intuition that makes us call that surface "three-dimensional space" is that it is a "surface of constant time", i.e., a surface with ##dt = 0##. But for the "warp" case ##v > 1##, the ##t## coordinate is not timelike! That is, ##t## is not a valid "time" coordinate, and surfaces of constant ##t## are not valid "surfaces of constant time".
This is a fundamental point. It is clear by inspection the t coordinate is spacelike, not timelike inside the bubble when it is operating as a warp drive. This means that the interval between two Euclidean slices, while timelike outside the bubble, is spacelike inside the bubble. Thus this is not a valid foliation, as normally defined.
  • #42
I think you are thinking of a process something like this. Draw a spacetime diagram in some coordinate system and add the (orange) worldline of the light pulse:
Pick a series of events in some sense evenly spaced along the line (you might choose fixed intervals of an affine parameter along the null path, or fixed coordinate time intervals) and draw timelike dividing lines between small regions (black):
Measure the spacelike distance between each dividing line and the next along a line orthogonal to the divider (green):
Sum the spacelike distances. Take the limit as the even spacing between dividing lines reduces to zero.
Am I right? If so, the issue appears to be the freedom to choose the direction of the timelike dividing lines. I don't think there's a unique choice (even in flat spacetime) and the final result will depend on your choice of scheme for picking them.
  • #43
Davis & Lineweaver present their equations 19 and 20 as follows:
$$\dot D= \dot R\chi+R \dot \chi$$
$$v_{tot}=v_{rec}+v_{pec}$$
This explains the changing slope of our past light cone in the upper panel of Fig. 1. The peculiar velocity of light is always ##c## (Eq. 21) so the total velocity of light whose peculiar velocity is towards us is ##v_{tot} = v_{rec} − c ## which is always positive (away from us) when ##v_{rec} > c##.
As I see it, the velocity I defined is nothing other than what D&L call peculiar velocity.
  • #44
Pretty much, yes, although they are expressing it in global comoving coordinates instead of local inertial coordinates, and they haven't emphasized the caveat that this only works within the confines of a local inertial frame centered on a particular event.
However:
Please write down this integral explicitly and evaluate it for the case of a CMB photon emitted at the surface of last scattering and just reaching Earth now. What do you get?
  • #45
But they are defining a local relative velocity. Do they also turn around and define a distance traveled by a body with peculiar motion? That’s the step I find dubious, because you are summing local measurements of observers at different cosmological time and place, with non static distance between them. That is what makes it hard for me to accept as a distance traveled.
  • #46
My question is whether the sum (integral) that is being implicitly done here actually evaluates to the distance that was claimed, namely, the travel time times ##c##. That's why I asked for the integral to be explicitly written down and evaluated. Once we have an explicit integral to look at, then we can discuss what, if anything, it actually means physically.
  • #47
So, @Jaime Rudas , if you apply your notion of distance traveled for light in an FLRW solution, to a traveler in the warp bubble, and use as the timelike congruence relative to which you are summing distance as that of comovers within the bubble, you get that an in bubble traveler has traveled zero distance.
  • #48
I haven't had a chance to study this in relation to the warp metric, but are there any timeilike paths that enter and leave the Bubble? Alcubierre's description in the paper of the bubble 'appearing' around traveler, is obviously not realizable within GR.
  • #49
The diagram in Figure 3 of the lecture notes linked to in the OP of this previous thread would seem to me to show that there are:
While inside the bubble, such paths would have to be moving "in the opposite direction" from the bubble, from the standpoint of observers at rest at the center of the bubble. From the standpoint of observers far away from the bubble, such paths, from what I can tell, would appear to be "dragged along" with the bubble while they were inside it. These are very heuristic descriptions, of course, and I haven't done any actual calculations to verify what I think the diagram is telling me.
  • #50
One simple calculation is that if ##v_s## is 2, then the slope of light cones well within the bubble is appx. ##2 \pm \sqrt 3## (considering the x t surface). In other words, in the future direction, backward light rays slope to the right in the coordinates.
[edit: I made a miscalculation, which is doesn't change the general observation. The light cones are given by ##2\pm 1##.]
  • #51
Yes.
  • #52
##D=\int_{t=0}^{13.8} v_{pec} dt = \int_{t=0}^{13.8} c dt= 13.8 Gly##
  • #53
The problem is that the "length of the path" is ambiguous in a curved spacetime. Here is the main issue:
When you talk about the "length of the path" what you are doing is you are taking a 4D path in spacetime and you are projecting it onto a spacelike 3D sub-manifold. Then you integrate the spacetime interval along that projection to get the length. That projection is ambiguous in curved spacetime.
You have neither identified a path in this integral nor calculated the length of that path. A path ##p## will be some map ##p: \mathbb{R} \rightarrow \mathcal{M}##. From the path you can get a tangent vector ##V^\mu=dp^\mu(\lambda)/d\lambda## and integrate the length of the tangent vector along the path ##\int g_{\mu\nu} V^\mu V^\nu d\lambda ##.
When you are asked to show your work, just writing the answer you want isn't responsive.
  • #54
Yes, that's right. That's precisely what I said in post #4.
  • #55
What path in spacetime is this integral taken over? You've described this integral as giving a distance, which would imply that it's an integral over some spacelike path. Is it?
  • #56
And then, in the very next paragraph of the same post, you said:
Jaime Rudas said:
my question isn't that, but whether or not the distance between Earth and Alpha Centauri would be much less than 4.3 light years if it were measured along a path going through the warp bubble.
What @PAllen is telling you is that, so far, you have given no definition of "distance" that we can use to try to answer this question. The definition you're proposing for FLRW spacetime is irrelevant--that's what the quote from you just above is saying. And you've given no other.
So what definition of "distance between Earth and Alpha Centauri, measured along a path through the warp bubble" do you think should be used?
  • #57
Yes, it's true, I made a mistake when I said I was referring to the length of the path traveled, when what I had in mind was the integral of peculiar velocity with respect to time.
  • #58
I think you're the one who should answer that, since you were the one who stated that the distance between Earth and Alpha Centauri would be much less than 4.3 light years if you measured it along a path going through the warp bubble.
  • #59
Well, my answer was based on both Earth and Alpha Centauri being inside the bubble at some point, which you objected to. Inside the bubble, spacetime is flat, so the logic that says "distance is speed times travel time" works just fine, and that was the logic I was using.
If you want to say that there are other ways of defining a "distance" between Earth and Alpha Centauri in such a scenario, yes, of course there are. For example, you could take the diagram in Figure 3 of the paper that was referenced earlier, and take "Earth" to be at the left edge, and "Alpha Centauri" to be at the right edge, and find a spacelike line connecting the two that goes through the bubble. Any such line will have a sharp "kink" in it as it goes through the bubble, where it turns from being horizontal to being close to vertical in the diagram. If you ignore what happens at the boundaries of the "kink" (i.e., at the boundaries of the bubble), and just consider the segments outside the bubble, they will combine to a length not much less than 4.3 light years, true. And if you take the limit where the bubble's size goes to zero, treating the bubble as a single curve in spacetime, the "kink" basically disappears and you just have a spacelike line 4.3 light years long in the background flat spacetime.
That's basically the argument Alcubierre appeared to be making in what you quoted from him earlier in this thread.
  • #60
So then, since the peculiar velocity is always ##c## the length of the path is just ##c## times the time.
So, if you use the time coordinate inside the bubble you will get one distance and if you use the time coordinate outside the bubble you will get a different distance. And you can change to any distance that you want simply by changing coordinates. And this is true for flat spacetime too, not just curved spacetimes.
  • · Replies 22 ·
  • · Replies 82 ·
13K
