Entanglement swapping and Bohmian mechanics
  • Context: Graduate
  • Thread starter Thread starter Demystifier
  • Featured
362 replies · 18K views
DrChinese said:
The answer is: Victor's Bell State Measurement, leading to ##\Phi^+## and ##\Phi^-## as you say, can be done on any basis. If Victor were to choose H/V, L/R, or +/-, all of those can cast Alice and Bob's photons into either ##\Phi^+## or ##\Phi^-## - regardless of what basis Alice and Bob choose.
Morbert said:
When Victor's apparatus is set to perform a BSM, the basis is ##\{\Phi^+,\Phi^-,HV,VH\}##. When Victor's apparatus is set to perform an SSM, the basis is ##\{HH,VV,HV,VH\}##.
Understood. Up to here, I feel like you guys are telling me the same thing. Is there any disagreement on this?
I think my confusion was simply that I regarded the "H/V basis" in @DrChinese post #309 wording to mean Victor only ever measured H or V (I guess that's the SSM), and not that he measures in a basis where the possible outcomes are ##\{\Phi^+,\Phi^-,HV,VH\}## (the BSM). Thanks both for clarifying for me. :)
DrChinese said:
Here are the caveats:
i) In the Ma et al reference, Victor always chooses the H/V basis.
When you say "H/V basis" here do you mean the basis ##\{\Phi^+,\Phi^-,HV,VH\}##?
DrChinese said:
ii) When Alice and Bob measure on the same basis as Victor, there is still the a swap occurring.
This is where I get a bit confused on the terminology "basis". Alice and Bob each just get 1 particle right? So they can't use the "same (4-state) basis" as Victor who has 2 particles? So here you mean whether Alice and Bob measure literally H/V or L/R or +/-?
We can model Alice's and Bob's measurement in the HV bases as a single measurement on the 1&4 subsystem which has the basis ##\{HH, HV, VH, HH\}##. In which case the basis will align with Victor's SSM basis. But you are right: If Victor configures his apparatus for an imperfect BSM, the basis will be different from the Alice-Bob basis.
Got it! Thanks for clarifying!
Morbert said:
1. What's wrong with correlation if Alice and Bob both measure in the HV basis and Victor obtains ##\Phi^+##?
2. PS Just in case: Here "No BSM" means no BSM when Victor has his apparatus set to attempt a BSM.
It may be helpful to simply jump to the bottom for the summary. :smile:
1. ##\Phi^+## generally yields opposite Alice/Bob correlation to ##\Phi^-##, right? Actually this is a point is not entirely clear in Ma. I have always been under the impression that ##\Phi^+## and ##\Phi^-## yield opposite correlated Alice/Bob results on all bases. After, they have opposite signs in Ma's (2) and everywhere else.
Ma et al: You can see that per their Fig 1 (which you used): ##\Phi^+## and ##\Phi^-## yield opposite results when Alice and Bob are measured on the +/- or L/R bases, but yield the same results on the H/V basis. It looks like you kept this in mind. I don't know if Ma did this intentionally, or in error, as it doesn't see to quite fit with other sources. The specific entry I am questioning in Fig 1 is the last |Φ+〉 in the list, with results VV. I think that should be marked differently, but I acknowledge my uncertainty.
Megidish et al: Matching what I have always understood: "When the polarizations of the middle photons are correlated (hh or vv) they are projected onto a |Φ+〉 state. When they are anti-correlated (hv or vh) they are projected onto a |Φ-〉 state."
Also, keep in mind that for this experiment, they held Victor's measurement basis constant at H/V (Fig. 3). And of course, returning to their (2), we have the 4 equally likely Bell states we agree on (bolded representing ones being reported on):
|Ψ〉1234 = 1/2(|Ψ+〉14⨂|Ψ+〉23 − |Ψ−〉14⨂|Ψ−〉23 − |Φ+〉14⨂|Φ+〉23 + |Φ−〉14⨂|Φ−〉23) [Ma 2]
I re-examined your 4 charts. I now realize I misinterpreted/misread some of your labeling. So I am now asking for confirmation on a couple of the charts.
Chart 1. I accept your presentation as correct and mine as "suspect" for now. As mentioned, I will continue looking for something that puts this question to bed.
Chart 2. I still agree with this, but it does not relate to the Ma experiment. (Since they don't ever measure Alice and Bob on different bases from each other.)
Chart 3. & 4. These 2 are basically the same, but showing a different timing order. I agree with this, conditioned on your treatment as being on the H/V basis for Alice and Bob. See also 2 below.
2. Since we're discussing the ideal case: all pairs 2 and 3 that overlap in the BS lead to a swap, or at least are indistinguishable from a swap. The true "failed BSM" cases are where there isn't enough overlap to satisfy the coincidence window condition. Note that those can't be the case, else your statistics for the "No BSM" case wouldn't work out. The reason that your statistics for the "No BSM" group are correct: Because only 2 of the 4 Bell states can be identified, the other 2 cases are grouped into your label. Since the output 4 Bell cases occur with equal probability (25%).
Put another way: Ma ignores all reporting on what you call the "No BSM" case, in either their Fig. 1 or Fig. 3. In the text, they make the comment: "Victor's detector coincidences with one horizontal and one vertical photon in spatial modes b’’ and c’’ indicate the states |𝐻𝐻〉23 and |𝑉𝑉〉23, which are always discarded because they are separable states independent of Victor’s choice and measurement." I might say instead that those cases always produce separable state statistics (i.e. no correlation) because it combines 2 unidentifiable Bell states that produce opposite results (netting to zero). After all, they also state: "|Φ+〉23 = (|𝐻𝐻〉23 + |𝑉𝑉〉23)/√2 (both detectors in b’’ firing or both detectors in c’’ firing)." So that's a case where you have both an |H> and a |V> result, but the Bell state is identifiable.
I would be happy if there is some other paper out there that clarifies the point. I've read quite a few*, and Ma is the only one that seems to disagree (if you call it that) with any others. See for example:
https://arxiv.org/pdf/0809.3991 Fig. 2, the HOM dip goes to zero. That dip does not discriminate between the 4 different Bell states, it combines all four and all four individually disappear. Two of those exactly cancel (destructive interference), and two do not trigger 4 fold coincidences. But all 4 states exist coming out of the BS, and two disappear due to strictly HOM quantum effects - so they can't be separable.
To make some sense out of the encyclopedia above :smile: :
1. I believe ##\Phi^+## and ##\Phi^-## yield opposite correlated Alice/Bob results on all bases.
2. Although what you call the "No BSM" case is not reported in Ma or elsewhere: I believe it is actually the indistinguishable ##\Psi^+## and ##\Psi^-## Bell state cases.
I'm not sure either of these points need to prevent us from moving forward. We completely agree on the reported results of Ma and Megidish, as far as I can tell. :smile:
Matterwave said:
1. Understood. Up to here, I feel like you guys are telling me the same thing. Is there any disagreement on this?
2. I think my confusion was simply that I regarded the "H/V basis" in @DrChinese post #309 wording to mean Victor only ever measured H or V (I guess that's the SSM), and not that he measures in a basis where the possible outcomes are ##\{\Phi^+,\Phi^-,HV,VH\}## (the BSM). Thanks both for clarifying for me. :)
3. When you say "H/V basis" here do you mean the basis ##\{\Phi^+,\Phi^-,HV,VH\}##?
4. This is where I get a bit confused on the terminology "basis". Alice and Bob each just get 1 particle right? So they can't use the "same (4-state) basis" as Victor who has 2 particles? So here you mean whether Alice and Bob measure literally H/V or L/R or +/-?
More great questions. It's amazing how quickly a few words here or there can point in different directions without me realizing it.
1. A little disagreement. @Morbert uses the lingo "##\{\Phi^+,\Phi^-,HV,VH\}##" from Ma differently than I with "##\{\Phi^+,\Phi^-,\Psi^+,\Psi^-\}##.
a. Morbert: ##\{\Phi^+,\Phi^-\}## portion there is no disagreement about, we mean the same thing. I haven't found an exact analog to his ##\{HV,VH\}## portion, but perhaps Morbert is referring to Ma's text: "Victor's detector coincidences with one horizontal and one vertical photon in spatial modes b’’ and c’’ indicate the states |𝐻𝐻〉23 and |𝑉𝑉〉23 which are always discarded because they are separable states independent of Victor’s choice and measurement.". So we need Morbert to help us here. The statistics are the same for Morbert and I once we discard the last 2 terms from our sets. And note that the total of his last 2 terms and the total of my last 2 terms are exactly the same. But they are not exactly the same sets.
b. DrChinese: ##\{\Phi^+,\Phi^-,\Psi^+,\Psi^-\}## represent the 4 Bell states, any one of which can equally randomly emerge from the Beam Splitter portion of the BSM apparatus when there is suitable indistinguishable overlap. I don't believe there is anything controversial about this statement whatsoever.
2. Victor only ever measures on the H/V basis in Ma, regardless of BSM or SSM setup selection. In the BSM selected setup, Victor can identify 2 of 4 Bell states; those being ##\{\Phi^+,\Phi^-\}##. The states ##\{\Psi^+,\Psi^-\}## cannot be identified during a BSM and those cases are discarded.
3. See 2., Victor only measures on the H/V basis for photons 2 and 3 used for the BSM or SSM. This is normal for swapping experiments, including Megidish.
4. Alice and Bob each get 1, yes. For Ma, the decision was made to always select the same basis for both Alice and Bob each time. Both H/V, or both L/R, or both +/-. They only report 4-fold coincidences in each trial: 2 results from Victor and 1 each from Alice and Bob.
1. The correlations yielded can be inferred from the expansions. ##\Phi^+## expands as$$|\Phi^+\rangle=\frac{|HH\rangle+|VV\rangle}{\sqrt{2}}=\frac{|++\rangle+|--\rangle}{\sqrt{2}}=\frac{|RL\rangle+|LR\rangle}{\sqrt{2}}$$And so it will yield same correlation in the HV and +- bases, and opposite correlation in the RL basis. Similarly $$|\Phi^-\rangle
\frac{|HH\rangle-|VV\rangle}{\sqrt{2}}
\frac{|+-\rangle+|-+\rangle}{\sqrt{2}}
\frac{|RR\rangle+|LL\rangle}{\sqrt{2}}
$$so ##\Phi^-## will yield same correlation in the HV and RL bases and opposite correlation in the +- basis.
This is all consistent with Ma's Fig 1.
2. The label "No BSM" refers to Victor configuring his apparatus for a ##\{\Phi^+,\Phi^-,HV,VH\}## measurement and registering ##HV## or ##VH## which are not Bell states. (None of my graphs showed Victor performing an SSM though they are readily producible)
This looks like a typo. Ma mentions HV and VH, not HH and VV:
3. This looks like a typo. Ma mentions HV and VH, not HH and VV:
1. This looks pretty good, Morbert. :smile: And it is consistent with Ma Fig 1. So on the H/V basis there is same 1 and 4 correlations for both ##\{\Phi^+,\Phi^-\}##, while for the other 2 bases they are opposite. For now, assume I agree with you. And thanks for taking the time to explain your thinking.
So I'm not saying that's wrong, but there is an oddity (to me :smile: ) following that thinking. ##\{\Phi^+,\Phi^-\}## then will yield same correlations for H/V for photons 1 and 4. OK. But for Victor, he gets both an H and a V for ##\{\Phi^+\}##; and both H or both V for ##\{\Phi^-\}##. That seems odd.
I also am interested in comparing to the Megidish experiment, but I will take that discussion elsewhere.
2. We'll continue disagreeing on this point. There is no such thing as configuring a BS to generate only 2 Bell states. All 4 always are equal random options, and 2 is the most identifiable at this time (although they are working on boosting it past 2). I don't think you will find a strong reference otherwise. Note in fact that for the ##\{\Phi^+\}## state, the signature is ##HV## or ##VH##. And every reference shows something like Ma's (2) with all 4: 1/2(|Ψ+〉14⨂|Ψ+〉23 − |Ψ−〉14⨂|Ψ−〉23 − |Φ+〉14⨂|Φ+〉23 + |Φ−〉14⨂|Φ−〉23)
In fact, I think it is possible to experimentally prove all 4 states are present from the same BS source - although not all 4 at the same time. Some experiments configure their BSM for ##\{\Phi^+,\Phi^-\}##, others (such as this) for ##\{\Psi^+,\Psi^-\}##. You could switch from one configuration to the other, using a constant source. So all 4 must exist. I don't know myself what is done to change from one to the other.
And not that you are saying otherwise to this additional point: There are no entries in Ma's Fig 1 that relate to Victor seeing |HH> or |VV> (or |HV> or |VH> for that matter) while configured for a BSM. Entries so labeled are configured for identifiable Separable State Measurements. Look at caption for the column, and that becomes clear.
3. You're correct, it's a typo, thanks. Although I cut and pasted directly from the paper: |HV>23 and |VH>23 were instead incorrectly inserted as |HH>23 and |VV>23. I had to hand correct to what you correctly display. Never seen that before. Still doing it on my machine... which must contain an evil demon. (I assume yours didn't do that.)
Victor's BiSA relates the input space to the output space via a time evolution like so: $$\begin{aligned}|\Phi^+\rangle_{bc}&\longrightarrow\frac{i}{\sqrt{2}}\left(|HV\rangle_{b''b''}-|HV\rangle_{c''c''}\right), \\[6pt]|\Phi^-\rangle_{bc}&\longrightarrow\frac{i}{\sqrt{2}}\left(|HH\rangle_{b''c''}-|VV\rangle_{b''c''}\right), \\[6pt]|HV\rangle_{bc}&\longrightarrow\frac{i}{\sqrt{2}}\left(|VV\rangle_{b''b''}-|HH\rangle_{c''c''}\right), \\[6pt]|VH\rangle_{bc}&\longrightarrow\frac{i}{\sqrt{2}}\left(|HH\rangle_{b''b''}-|VV\rangle_{c''c''}\right).\end{aligned}$$The first two are explicitly reported by Ma. The second two are the same time-evolution applied to the separable states ##\ket{HV}_{bc}## and ##\ket{VH}_{bc}##. Hence the registering of signatures at b''c'' constitute a measurement in the basis ##\{\Phi^+,\Phi^-,HV,VH\}## at bc.
Victor's BiSA can't resolve ##\Psi## states. As can be seen by the time-evolutions$$\begin{aligned}|\Psi^+\rangle_{bc}&\longrightarrow\frac{i}{2}\left(|VV\rangle_{b''b''}+|HH\rangle_{b''b''}-|HH\rangle_{c''c''}-|VV\rangle_{c''c''}\right), \\[6pt]|\Psi^-\rangle_{bc}&\longrightarrow\frac{i}{2}\left(|VV\rangle_{b''b''}-|HH\rangle_{b''b''}+|VV\rangle_{c''c''}-|HH\rangle_{c''c''}\right).\end{aligned}$$Notice that a signature like ##VV_{b''b''}## (or any of the other three) does not uniquely select one ##\Psi## over the other, and so the apparatus cannot resolve measurements with a Bell basis spanning this subspace. It can however resolve measurements with a separable basis spanning this subspace. Hence the measurement basis I supplied.
This point is actually quite interesting to me.
From a theorerical perspective, is there a difference between Victor measuring on the ##\{\Phi^+, \Phi^-, HV, VH\}## basis and then discarding the ##\{HV,\,VH\}## results vs measuring in ##\{\Phi^+, \Phi^-, \Psi^+,\Psi^-\}## and then discarding the ##\{\Psi^+,\Psi^-\}## results?
It seems like @Morbert you are saying the two particle basis including ##\{\Psi^+,\Psi^-\}## can't be experimentally realized in Ma's set up, did I understand correctly?
Yes, Ma's apparatus cannot perform a measurement in the basis ##\{\Phi^+,\Phi^-,\Psi^+,\Psi^-\}##.
But since runs with measurement outcomes in the ##\{\Psi^+,\Psi^-\}##/##\{HV,VH\}## subspace are discarded in this protocol, it doesn't matter (though the protocol was of course motivated by this BSM limitation).
1. From a theorerical perspective, is there a difference between Victor measuring on the ##\{\Phi^+, \Phi^-, HV, VH\}## basis and then discarding the ##\{HV,\,VH\}## results vs measuring in ##\{\Phi^+, \Phi^-, \Psi^+,\Psi^-\}## and then discarding the ##\{\Psi^+,\Psi^-\}## results?
2. It seems like @Morbert you are saying the two particle basis including ##\{\Psi^+,\Psi^-\}## can't be experimentally realized in Ma's set up, did I understand correctly?
1. No difference at all.
2. That is true for Ma (2012), yes, but is changing. The current experimental record is at least 57.9%.
A BSM can normally be set to look for ##\{\Phi^+,\Phi^-\}## or for ##\{\Psi^+,\Psi^-\}##. You currently can't differentiate all 4 with equal success. They are working on methods to increase the detection capability above the common 50% threshold. One paper has demonstrated a theoretical concept that raises it to 62.5%. At 100%, all 4 Bell states would be discernible. So then, there is nothing anyone would need to call ##\{HV, VH\}##.
Bell-state measurement exceeding 50% success probability with linear optics (2022)
"As before in the standard scheme, we can still distinguish the states |Ψ±> with 100% probability. However, we get now in addition a subset of unique signatures for the states |Φ+> and |Φ−> in 25% of the cases (see Fig. 1 (d)). This means that the overall probability to correctly identify a Bell state for this scheme is p(c) = 62.5%."
Note that Morbert's method of defining the "unidentifiable" Bell states as ##\{HV, VH\}## is not "wrong". The sum of states he calls ##\{HV, VH\}## is exactly equal to the ones I call ##\{\Psi^+,\Psi^-\}## even though trial by trial, they would not be the same. Any one he identifies as ##\{HV\}## could be either ##\{\Psi^+\}## or ##\{\Psi^-\}##. Similarly, any one I identify as ##\{\Psi^+\}## could be either ##\{HV\}## or ##\{VH\}##.
For me, one method is more useful and matches theory "better". But obviously opinions vary. There is no question that Ma discards certain 4-fold coincidences, regardless of what you call them.
Demystifier said:
1. Let us illustrate this by a simple example. Suppose that, at a certain time ##t##, ##\psi(x_A,x_B)## has a form
$$\psi(x_A,x_B)=\psi_A(x_A)\psi_B(x_B) \;\;\; {\rm for} \;\;\; x_B>0$$
$$\psi(x_A,x_B) \neq \psi_A(x_A)\psi_B(x_B) \;\;\; {\rm for} \;\;\; x_B\leq 0$$
This should be considered as one wave function, written separately for ##x_B>0## and ##x_B\leq 0##. The full wave function, valid for all ##x_A,x_B##, is not a product. It is an entangled wave function. Any yet, for ##x_B>0## it looks like a product wave function without entanglement. So if the B particle happens to have the Bohmian position ##X_B>0##, then the rule says that the particle A has to move by velocity that does not depend on the position of B. But in order to obey this rule, the particle A has to know that ##X_B>0##. So, the motion of A "independently" on B actually depends on B. This demonstrates that motion always depends on positions of all particles, even when this dependence is not manifest.
2. And now we can finally discuss the entanglement swapping. It involves 4 particles, A, B, C and D. Initially the wave function has the form ##\psi_{AB}\psi_{CD}##, so A is entangled with B, and C is entangled with D, but there is no entanglement between A and D. Nevertheless, each particle knows positions of all other particles. In particular, A knows the position of D, and vice versa, but this knowledge does not have a direct manifestation. In other words, the motion of A depends on the position of D, and vice versa, but this dependence is not manifest. The entanglement swapping is a way to make this dependence manifest.
3. What seems to be confusing to DrChinese is how can suddenly the motion of A may start to depend on the position D, if there was no such dependence from the beginning? How can such a dependence be created without the interaction between A and D? And what exactly creates such a dependence?
4. The answer is that the dependence was there from the start, it was never really created. It is only that certain changes in the system changed the rules of the game (encoded in the change of the pilot wave), so that, at the time when B and C interacted, the dependence of A on D became manifest.
Yikes! I'm reaching back to post #1 in this thread!!
1. To be clear: The Bohmian spin observable - let's just call it spin - is some function of the particle's position and the positions/velocities/other properties of other particles. But for the experimental entangled spin rules to work, there must be something preferred about the relationship of A and B... correct? After A is measured to be "up", entangled B is never going to be measured as anything other than "down", correct? Assuming, of course, B later gets measured on that basis.
2. Switching to our swapping example: I admit I don't follow your reasoning. A and B are entangled initially, OK, but I don't see how anything about D relates to A. You refer to it as "not manifest", OK, that fits with 1. above. And you say A and D are not entangled. OK. But now D has been measured as well as A, and there is still nothing connecting them. Let's say A and D are measured on the +/- basis. We now should know that neither of the A and D outcomes are dependent in any way on the other, any more than B and C are mutually dependent.
3. Keep in mind that at this point, there is nothing in the future of B and C to indicate they will ever interact. In the related experiments, that decision (interact or not) is made by computer (or theoretically could be made by a person's free will). If you disagree, let's discuss.
4. I'll table this until I better understand the other points.
-DrC
Demystifier said:
1. ...or equivalently
$$ t_2:\; (M_A,A)_2 \mathrel{-} B \;\;\;\; C \mathrel{-} (M_D,D)_2$$
The notation ##(M_A,A)_2## denotes that the system ##M_A+A## is viewed as one system at time ##t_2##.
2. Finally, at time ##t_3##, we measure the system ##B+C##, so
$$ t_3:\; (M_A,A)_3 \mathrel{-} B \mathrel{-} M_{BC} \mathrel{-} C \mathrel{-} (M_D,D)_3$$
or equivalently
$$ t_3:\; (M_A,A)_3 \mathrel{-} (B,M_{BC},C)_3 \mathrel{-} (M_D,D)_3$$
This finishes the description at the fundamental microscopic level.
Following your advice from the post above #343: I'm/we're covering a bit much here, so I am breaking my responses into 2 posts.
1. So, let's talk a bit more about t2. As you say later, A and D can be destroyed - their measured value is recorded. Now please understand: I agree that your notation is functionally correct here, and have no issue with it at all. :smile:
In the Bohmian (BM) perspective, there is no further ability for anything anywhere to change the recorded values of A & D. And I think we've agreed that the spin observable of B and C on the +/- basis (same basis A & D were measured) is essentially set in stone. All of this matches perfectly so far with experiment as to usual PDC entanglement.
But there is a point here which BM makes a statement, but that oQM does not. According to BM, particles B & C have firm definite values for H/V polarization at all times - which is presumably an unbiased basis relative to +/-. When A & D were measured, did B & C take on specific values related to those measurements? Are the H/V values for B & C likewise set in stone as their +/- values are? Or are they free to change, perhaps influenced by particles/systems elsewhere (following the BM pilot wave concepts)?
2. Here I see things a bit differently than you present them. A & D are measured on the +/- basis. B & C are to be measured on the H/V basis. This is a significant difference! In oQM, there is no correlation at all between the future outcome of a H/V measurement and the same photon's known +/- polarization, right? I don't think BM posits otherwise.
My point being: the relationship you are drawing ## t_3:\; (M_A,A)_3 \mathrel{-} (B,M_{BC},C)_3 \mathrel{-} (M_D,D)_3## does not account for this difference in basis. And I think it should. We are getting ready to measure B & C and the only thing we are looking for now is which Bell state is to be revealed. Although there are 4 Bell states, basically what we want to know is:
How does it happen that the interaction between B & C can only lead to a Bell State in which A & D are suitably correlated (either |++> or |-- >) or anti-correlated (either |+- > or |-+>). This of course when B & C are not being even measured on the +/- basis.
We know that there must be physical overlap between B & C, that has been demonstrated experimentally (Megidish et al). So from the forward in time only (FITO) view provided by BM, something must be causing the result of the interaction to somehow lead to the proper Bell state. That process being going through a suitably oriented beam splitter and follow-on polarizing beam splitters, on a different basis than which A & D were measured. I'm trying to understand how any of this is consistent with a) having nonlocal influences from other systems outside the lab, and b) having definitely values for H/V polarization at all times.
Of course, I'm not sure oQM answers these questions either!
-DrC
or equivalently
3. However, at the emergent macroscopic level things look slightly different. The measurement outcomes encoded in ##M_A## and ##M_D## are stored on a computer, so they don't change much during the time. Also, after the measurement, the macroscopic system ##M_A+A## is practically indistinguishable from ##M_A## alone, i.e., the state of the particle ##A## after the measurement is practically irrelevant. The particle ##A## can even be destroyed, it doesn't matter as long as we keep the measurement outcome encoded in ##M_A##. Thus, for practical purposes, we can use the approximation ##(M_A,A)_2 \simeq (M_A,A)_3##. Likewise, we have ##(M_D,D)_2 \simeq (M_D,D)_3##. Hence, effectively, the microscopic state at ##t_3## implies an effective macroscopic description
$$ (M_A,A)_2 \mathrel{-} (B,M_{BC},C)_3 \mathrel{-} (M_D,D)_2$$
At the statistical level, this explains why the results of measurements in the past at time ##t_2## are mutually correlated when combined with measurement results in the future at time ##t_3##: ##(M_A,A)_2## is correlated with ##(B,M_{BC},C)_3##, and ##(B,M_{BC},C)_3## is correlated with ##(M_D,D)_2##, so it is not surprising that ##(M_A,A)_2## can be correlated with ##(M_D,D)_2##. Furthermore, at the macroscopic level we also have a time arrow, due to which the past causes the future, so the correlation can also be interpreted causally as
$$ (M_A,A)_2 \rightarrow (B,M_{BC},C)_3 \leftarrow (M_D,D)_2$$
Thus we see that, at the macroscopic level, we can say that the results of measurements in the past cause the result of measurement in the future.
I couldn't figure out where to stick this... :smile:
2.5 When I try to imagine a word that sums up what polarization state B (or C) is in during the time between t2 and t3 (maybe t2.5?), I'm not sure what it is. It can't exactly be in state |+> or |- >, because a photon in that exact state cannot participate in a swap. But it is not exactly entangled either - or is it? Because I don't think the Bohmian perspective has a reasonable description here, since it is asserting Bohmian particles are in exact states - albeit unknown - at all times.
3. I'll come back to this later, I want to see where we're at for 1. and 2 (and 2.5).
Recorded is the key word. This means that these values are carried by ##M_A## and ##M_D##. Not by ##A## and ##D## themselves.
Not really. The stone is ##M_{BC}##, not ##B## and ##C##. Without measurement, namely without ##M_{BC}##, spins in BM do not have any values at all.
As long as you will try to understand it without referring to the ##M##'s, you will fail. As long as you think that I talk about the ##M##'s only for the sake of pedantry, you are not getting it.
1. Are we going backwards? I said: "To be clear: The Bohmian spin observable - let's just call it spin - is some function of the particle's position and the positions/velocities/other properties of other particles. But for the experimental entangled spin rules to work, there must be something preferred about the relationship of A and B... correct? After A is measured to be "up", entangled B is never going to be measured as anything other than "down", correct? Assuming, of course, B later gets measured on that basis." You said "I agree with your points above".
2. What are you saying that is different? Surely, A and D are measured on +/- basis and the results recorded. Photons B and C are flying through the air, blissfully unaware of their potential future overlap in a BSM device (since no decision has yet been made as to whether they will overlap). Are we in agreement still?
3. I say (based on what I've read, see below - but I'm still somewhat unclear) that BM asserts that B and C are in a specific +/- state at this point. A measurement on the +/- will yield a certain value than cannot change. No other systems anywhere in the universe can change this expected result, and A and D certainly cannot as they no longer exist. Again, we're assuming a measurement on the +/- basis occurs. Which of course will not happen during a swap. But we could measure B and/or C on the +/- basis at any time instead, and get a certain outcome. So I am agreeing that a M(B) or a M(C) on the +/- basis would be required to see that expected outcome. But there is no M(BC) yet, because B and C have no possible relationship until the experimenter brings them together. Is there anything about what I've stated in this paragraph that does not match your perspective?
4. What I've read:
Norsen: "...one also has definite positions for each particle in the system." Presumably their spin observables are likewise definite, see 5 for more on that. Or?
Oriols, Mompart: "In contrast, this alternative interpretation permits us to conceive of each individual system as being in a precisely definable state, whose changes with time are determined by definite laws, analogous to (but not identical with) the classical equations of motion. Quantum mechanical probabilities are regarded (like their counterpart in classical mechanics) as only a practical necessity and not as a manifestation of an inherent lack of complete determination in the properties of matter at the quantum level." So here they say explicitly that there are definite determined properties at all times.
And to be clear: I am not trying to say that unperformed measurements have definite values. But the authors above are saying exactly that. If you disagree with them, that's fine. I just want to understand what your viewpoint is during the step by step evolution of a swap.
5. Now, please also note that Norsen addresses directly some of the issues I am raising about the relationship of Bohmian position to Bohmian spin. Here he discusses a pro and a con:
Against BM spin (Norsen quotes this, but it is not his position): “It has indeed been shown that Bohmian mechanics is equivalent to non-relativistic quantum mechanics with respect to its predictions concerning particle positions. However the scheme encounters major problems: in spite of a half-century of effort by its adherents, it has not been possible to incorporate spin into the theory in a convincing way...”. I.e. there seems to be a big fat hole in this area of BM.
For BM spin (Norsen quotes this as his position): "This type of view is perhaps motivated by the various “no hidden variables” theorems, such as that due to Kochen and Specker, which show quite clearly that it is mathematically impossible to assign pre-existing values to all relevant spin-components of an ensemble of particles such that the quantum mechanical predictions are reproduced.[6, 7] That is, it is known to be impossible to do, for all of the non-commuting components of spin, what the pilot wave theory, as sketched above, does for position. And yet, in fact, it is entirely false that the pilot-wave theory cannot deal with spin. Indeed, the truth is that the pilot-wave theory deals with spin in an almost shockingly natural – certainly a shockingly trivial – way."
And in fact Norsen does explain exactly what I describe above in his Fig. 6 (ibid). That section is explicitly about entangled pairs, our A-B and our C-D. I noticed that he does not mention points you raise about "recording outcomes", and he never says anything like your "Without measurement, namely without ##M_{BC}##, spins in BM do not have any values at all." Again, if you disagree with Norsen, that's fine. Your knowledge is easily deep enough that I care about your perspective regardless of Norsen.
In case I haven't already made it abundantly clear: It certainly seems as if the Bohmian assertions about entanglement swapping are missing something crucial (I've mentioned a couple of items). But I am not sure, hence why I am interested in your take. Norsen, Oriols and others simply wave their hands and claim it all comes out in the wash. Were I a comedian, I'd say it's laundry day. So... how do others explain swapping given it's FITO (forward in time only) evolution, and assertions of definite spin values for entangled systems? I'm hoping to at least get a solid understanding of how you view these details.
No, BM does not assert that.
Yes, but that value is not encoded in B and C alone. It's encoded in the whole universe, or more precisely, in everything what is entangled, or will be entangled, with B and C.
DrChinese said:
than cannot change.
Only if you assume that the rest of the universe cannot change.
A and D cannot, but there are other systems in the universe that can. You forget that ##M_A## and ##M_D## still exist, and they are entangled with B and C, respectively, so in BM they influence the behavior of B and C.
Then what happens during the swap?
Yes there is. I think the most important thing that you miss is the fact that ##M_A## remains entangled with B, and ##M_D## remains entangled with C, even after the particles A and D are destroyed.
Demystifier said:
1. No, BM does not assert that.
2. Yes, but that value is not encoded in B and C alone. It's encoded in the whole universe, or more precisely, in everything what is entangled, or will be entangled, with B and C.
3. Only if you assume that the rest of the universe cannot change.
4. A and D cannot, but there are other systems in the universe that can. You forget that ##M_A## and ##M_D## still exist, and they are entangled with B and C, respectively, so in BM they influence the behavior of B and C.
5. Then what happens during the swap?
6. Yes there is. I think the most important thing that you miss is the fact that ##M_A## remains entangled with B, and ##M_D## remains entangled with C, even after the particles A and D are destroyed.
1. OK, but certainly you are acknowledging here a different viewpoint than the quotes I provided from other writers. "...definite positions for each particle in the system", "each individual system as being in a precisely definable state". Again, assuming that spin is an observable precisely derived in BM based on a definite position/velocity. And it is diametrically the opposite view of spin entanglement as described by Norsen.
Again, if you say you part with Norsen on this, that's fine - just say so and I will stop referencing him. :smile:
2. What can you possibly mean by "or will be entangled, with B and C"? How on earth would BM know what will happen in the future? Even in a clockwork universe, that information is not available in the present. Whether B and C will ever meet in the future is a decision to be made later by a random (or pseudo-random) process. This has been experimentally demonstrated.
At least, not within the confines of the Pilot Wave concept. If I guess a number between 1 and 100 tomorrow, what I guess is not something that the rest of the universe knows now. Or... are you saying it is? If so, where does that show up in a formula?
3. I am of course assuming the rest of the universe can and does change dynamically while B is mid-flight. How can systems elsewhere in the universe change in any manner the certain outcome of a measurement on B's spin? Experiments have been performed after entangled particles travel over 100 km and there's no indication of "the rest of the universe" entering the picture.
4. I am befuddled by your treatment of M(A) as if it is a physical object appearing in the Pilot Wave formula in Norsen's (2). It's simply a series of bits on a computer somewhere. They are not entangled with anything related to B. And presumably they are static anyway, so there would be no dynamic influence to consider.
5. The swap is a series of measurements on the H/V basis. The particles A & D were measured on an unbiased basis, +/-. That's a crucial point, although we have really gotten to that yet (your t3).
6. Agreed, as mentioned in 4, this seems strange to me and I have never seen such language used to express ongoing entanglement as relates to BM. But if it's your personal viewpoint, fine, we'll take it from there.
And note: The same "difficulty" occurs in oQM! That difficulty being: How does entanglement end for A with A's destruction but nonetheless continue for its previously entangled partner B? The difference is that oQM does not assert a FITO (forward in time only) structure. It is silent, leaving folks everywhere puzzling to make some kind of sense of it.
Not that I can anyway. :smile:
I know that I said I give up, but the quote above is so so wrong, and absolutely the main source of your misunderstanding of BM, that I must try to explain it once again. The M(A) is absolutely the most important physical object appearing in Norsen's (2). If you can't understand that, you will never ever understand BM. You will forever think that BM can't explain the entanglement swapping experiment. And you will be right in a sense; without that, BM really can't explain this experiment (or, for that matter, any experiment that in oQM is described by a wave function collapse). So you have to choose. Either you have to reject BM entirely, or you have to reject your comment 4. above. I will try to explain why you have to reject your 4. But if you can't reject it, then the only option for you is to reject BM. There is no way to understand BM properly and accept your 4.
Good, now after this deliberately dramatic introduction, I can explain why is your 4. wrong. And not only wrong, but actually the wrongest thing one can say about BM. Your 4. is the opposite of the whole idea of BM.
First, bits on a computer are physical objects. According to BM, everything in the Universe is made of particles with definite positions. Hence, even bits are made of particles with definite positions.
Second, those bits are entangled with B. That's the whole point. To understand that, you must understand the quantum theory of measurement in BM, which is really the von Neumann theory of quantum measurement, so it is valid also in ordinary QM. Suppose that initially A and B are entangled, say described by a state of the form
$$ |A_1\rangle |B_1\rangle + |A_2\rangle |B_2\rangle$$
Next, assume that A is measured by the measuring apparatus M(A), in the basis ##|A_1\rangle,|A_2\rangle##. This means that the full wave function, including the apparatus, takes the form
$$ |M(A)_1\rangle |A_1\rangle |B_1\rangle + |M(A)_2\rangle|A_2\rangle |B_2\rangle$$
Finally, assume that the particle A is destroyed, that is, absorbed by the apparatus. This means that the full wave function takes the form
$$ |M'(A)_1\rangle |B_1\rangle + |M'(A)_2\rangle |B_2\rangle$$
Now you see that the particle B is entangled with the apparatus that measured A. I will repeat! The particle B is entangled with the apparatus that measured A. Once again, for the case you still don't get it:
The particle B is entangled with the apparatus that measured A!!!!!
And since the bits on a computer are a part of that apparatus, it follows that the particle B is entangled with the bits on a computer. Do you get it now?
Finally, from the assumption that those bits are static it does not follow that there is no dynamics by which they can influence the particle B. To build your intuition, here is an analogy from classical mechanics. Your house in which you live is static. And yet, this house strongly influences and guides how you move through the house, because you can't walk through its walls. When you bump into the wall, the wall does not move, which is related to the fact that the wall is much heavier than you. Likewise, the bits on a computer do not change when they influence the motion of particle B, which is related to the fact that the bits on a computer are more macroscopic than the particle B.
  • Wow
You have never seen such a language before, either in BM or oQM, because most texts don't mention the von Neumann theory of quantum measurement. To understand QM properly, you must start from that. Without that theory of quantum measurement, QM is indeed puzzling. After you learn some basics of it, QM starts to make sense. And when you add Bohmian trajectories after you learned the theory of quantum measurements, suddenly everything sits on its place.
But no, people want to understand BM, or oQM, without dealing with the theory of quantum measurements. Unfortunately, at some point, such an incomplete view of QM necessarily fails.
  • Skeptical
The fact that macroscopic objects are quantum objects that can be entangled with other microscopic or macroscopic objects is a key to understanding many other conceptual issues in QM. For a historical example of the Einstein-Bohr photon-box thought experiment see my https://arxiv.org/abs/1203.1139
Demystifier said:
1. Since I don't see how to explain my points without repeating what I already said, I give up.
2.The M(A) is absolutely the most important physical object appearing in Norsen's (2). If you can't understand that, you will never ever understand BM. You will forever think that BM can't explain the entanglement swapping experiment. And you will be right in a sense; without that, BM really can't explain this experiment (or, for that matter, any experiment that in oQM is described by a wave function collapse). So you have to choose. Either you have to reject BM entirely, or you have to reject your comment 4. above. I will try to explain why you have to reject your 4. But if you can't reject it, then the only option for you is to reject BM. There is no way to understand BM properly and accept your 4.
First, bits on a computer are physical objects. According to BM, everything in the Universe is made of particles with definite positions. Hence, even bits are made of particles with definite positions. ...
3. The particle B is entangled with the apparatus that measured A!!!!!
1. All good and no issue at all on this. As always, use of your time is your call. :smile:
2. I would absolutely take the stand that you, and you alone, are the only author I have read stating as you do.
In our conversations, I repeatedly quoted the writings of recognized experts in BM. Verbatim. Saying diametrically the opposite of your comments. And I have repeatedly acknowledged your expertise in the field, having long followed your prolific work. And I have repeatedly said: If you part with Norsen and/or others, just say so and I will be content to accept that. But you steadfastly refuse to reject the clear, concise, and unambiguous statements I have quoted. Exactly what do you expect me to conclude?
a. Do you or don't you agree with Norsen that all particle positions and related observables (such as spin) have definite values at all times?
b. Do you or don't you agree with Norsen that a pair of spin entangled particles are NOT entangled with every other particle in the universe - even if there is a pilot wave with influences from nonlocal systems? Norsen: "The pilot-wave theory being after all deterministic, these probabilities are quite reducible. In particular, which of the two joint outcomes occurs [for particle 2] depends on the random initial position of particle 1...". He does not mention anything else as being relevant. No further dynamics affecting spin are discussed, whether from the rest of the universe or anything else.
I appreciate that you may think my understanding is subpar, and you are quite correct. And yet, I don't stand on my own understanding in our discussions. I instead stand on the works of the greats in the field, and I read a lot. I follow entanglement experiments, probably a bit closer than you actually. And I quote the acknowledged works of others, something I have yet to see you do (and I mean quote, not reference). And in fact: some of my favorite books from decades ago were by Bohm. Specifically, "Quantum Theory" and "Causality And Chance In Modern Physics". Both quite influential to me. Since then, I have read many works by Bohmians, followers of Everett, etc looking at the strengths and weaknesses of a variety of Interpretations. So I am not coming here in 2026 with an "off the cuff" topic of discussion. I am quite serious. I would challenge Norsen exactly the same as you - he and I have had extensive debates in the far past and we disagree on many things. But I give him his due just as I give you your due.
3. "The particle B is entangled with the apparatus that measured A!!!!!"
i) Nope, wrong under generally accepted physics. I challenge you to demonstrate your claim by any generally accepted standard (and I would like to see specific quotes/references to something supporting your argument). To be clear: you are stating that what was initially 2 polarization entangled photons A & B are now replaced by a system consisting of a very large set of physical apparatus/bits in a computer that are "spin-entangled" (I guess) with photon B. And what, those millions of atoms are not entangled with anything else, just photon B?
Yes, I have read your assertions, but to be blunt: so what? I easily accept the Bohmian premise as plausible that there is a hidden unknowable pilot wave/guidance force that is driven by systems elsewhere. But that in no way corresponds to just saying X causes Y. There must be specifics to take things to that level. Yes, I am a person with atoms. That does not mean I am entangled with photon B, even if I look at the computer's recording of the result of the measurement on A. Just asserting what you assert is not an argument. Where is the support?
ii) And even if you were correct about i), that would still not answer the underlying question that Norsen answers one way and you answer oppositely: Is B in a definite +/- polarization state at that point? Norsen says B nonlocally changes to a definite spin state upon measurement of A's spin. That spin state remains static barring further interaction. So: Do you or don't you agree with his Figure 6 as he writes it? And note that he never mentions "bits on a computer". Did he just miss that significant detail that you see as so critical to our understanding? Because nothing of his I have ever read mentions anything like this. But admittedly, my readings of his are not comprehensive enough for me to be sure. Maybe you know differently.
Now be cautious before responding*, because there are a lot of experimental and theoretical traps in the literature here which must be navigated to answer my "simple" questions i) and ii). References can be provided, but I'm sure you already know: a) Photons A and B can be entangled even if not polarization entangled. b) And photons A and B cannot be maximally polarization entangled and also be polarization entangled in any manner whatsoever with any other system(s) of particles in the universe. c) Particles A and B can be spin/polarization entangled, while conceptually A could be entangled with another system E on some other commuting basis (say frequency or whatever). d) And of course the obvious killer that we have yet to even mention: every GHZ experiment outcome is a disproof of the realistic concepts of BM.
So is it really me that is naive? Because I actually think I have done a bit of homework and laid it out. :smile:
* @Demystifier Of course, whether you choose to respond or not: I completely understand and respect your choice. Nothing you say or do here will change the great respect I have for you and your work.
I do not agree with you that Norsen ever said that "all particle positions and related observables (such as spin) have definite values at all times". If you insist that he did, please quote the exact statement by Norsen, so that we can analyze what he really said, and what's the meaning of it.
I agree with that. I never said that the pair is entangled with every particle in the universe. Instead, it can be entangled with the rest of the universe as a whole. That's a big difference, see below.
No, that's not what I'm saying. To explain the difference between entanglement with every particle and entanglement with the whole, let us consider a toy universe with only 4 particles, called A, B, C and D. Consider a state of the form
$$|\psi_{ABC}^1\rangle|\psi_D^1\rangle + |\psi_{ABC}^2\rangle|\psi_D^2\rangle \;\;\;\; (1)$$
Clearly, the particle D is entangled with the system ABC as a whole, do you agree? But it does not mean that D is entangled with every particle in the system ABC. That depends on the states ##|\psi_{ABC}^1\rangle## and ##|\psi_{ABC}^2\rangle##. For example, assume that
$$|\psi_{ABC}^i\rangle=|\psi_{AB}\rangle |\psi_C ^i\rangle, \;\;\; i=1,2$$
Then (1) can be written as
$$|\psi_{AB}\rangle \left[ |\psi_C ^1\rangle |\psi_D^1\rangle + |\psi_C ^2\rangle |\psi_D^2\rangle \right]$$
Thus we see that D is entangled with C, and not entangled with A and B. And yet, if we think of ABC as one system (you can imagine that A, B and C are parts of the apparatus), it is still true that D is entangled with ABC, as seen explicitly in (1). Do you see the difference?
I agree with his Fig. 6. But note that, even though he never mentions "bits on a computer", in the caption of Fig. 6. he says: " ... the result of measuring the spin of particle 2 depends not only on the initial state but on whether or not the spin of particle 1 is measured jointly". So he says that particle 2 depends on measurement of particle 1. And measurement assumes a macroscopic apparatus which permanently remembers the measurement outcome, so implicitly he is assuming something having the same role as "bits on a computer", even though he does not use those exact words.
Or to make the long story short, there is no disagreement between Norsen and me. There is only a disagreement between your interpretation of Norsen and me.
No it isn't. GHZ is a disproof of local realism, not of realism as such. More precisely, GHZ shows that spins in various directions of 3 entangled particles cannot be predetermined properties of those 3 particles themselves, independently of the measurement settings. Instead, any realistic explanation of the experiment must include the realistic properties of the measuring apparatuses. Moreover, the behavior of the spatially separated apparatuses in the GHZ experiment is correlated, so any realistic explanation of such a correlation between the apparatuses must be nonlocal. But if you deny the possibility of nonlocal entanglement between the apparatuses, as it seems that you do, I can understand why the GHZ looks to you as a disproof of realism in BM. Nevertheless, in the GHZ experiment, the apparatuses get entangled. By measurements, each of the 3 apparatuses gets entangled with one of the 3 particles, so, since the 3 particles are mutually entangled before the measurements, after the measurements the apparatuses get mutually entangled too.
A common pattern seems to be you misread an established figure and then set this misreading against people here.
Sure, it could be. I'm certainly willing to acknowledge anything I portray incorrectly. However, I have a habit of providing exact relevant quotes with my own words following that. I recognize it takes time to find quotes from authorities and don't expect most posters to invest that time. But apparently, my quotes are not in question so much; I mostly see them being ignored.
So here are some easy ones regarding Bohmian mechanics, please tell me where my understanding deviates from the quote of what I consider to be a suitable authority...
1. Norsen on definiteness of particle positions (first paragraph): "...in addition to the usual wave function Ψ obeying the usual Schrodinger equation
(1)
one also has definite positions for each particle in the system. For example, for a system of N spinless nonrelativistic particles, the position X(n) of the nth particle will evolve according to
(2)
Now I read this to mean: All particles have definite positions. Further, there is a relationship between the positions of all particles in the universe; and there's action/influence upon each individual particle due to what he calls the "pilot wave". He does not mention the word "entanglement" to describe that relationship. I can't quote that, because Norsen doesn't say it. So I will read between the lines myself, and state: The pilot wave is not entanglement, it's the "pilot wave" or "guiding equation" (Goldstein). @Demystifier: "[Photon B] can be entangled with the rest of the universe as a whole." Am I misreading him? I say his statement is meaningless as it relates to the phenomena we call entanglement. Photon pairs emerging from PDC are maximally polarization entangled with each other, and nothing else. Stating that they might be influenced by particles elsewhere - which I happily accept as a reasonable BM hypothesis - does not change that in any manner at all.
And it certainly doesn't mean "the universe" affects the polarization of Photon B while it is midflight. Norsen never says nor implies otherwise, again I cannot quote what he doesn't say. I should point out: We all readily accept that every particle in the entire universe is generally accepted to be affected by gravitational attraction of every other particle; no one calls that "entanglement" either.
2. Goldstein [ibid] and Norsen [ibid] on spin entanglement use virtually identical examples. And neither mentions any influence on particle 2 [B in our photon example] from the "entangled rest of the universe". Goldstein: "...in an EPR-Bohm experiment particle 1 passes through its Stern-Gerlach magnet before particle 2 arrives at its magnet. Then the orientation of the Stern-Gerlach magnet for particle 1 will significantly affect the conditional wave function of particle 2: If the Stern-Gerlach magnet for particle 1 is oriented so as to “measure the z-component of spin”, then after particle 1 has passed through its magnet the conditional wave function of particle 2 will be an eigenvector (or eigenstate) of the z-component of spin (in fact, belonging to the eigenvalue that is the negative of the one “measured” for particle 1), and the same thing is true for any other component of spin. You can dictate the kind of spin eigenstate produced for particle 2 by appropriately choosing the orientation of an arbitrarily distant magnet." Norsen: "The pilot-wave theory being after all deterministic, these probabilities are quite reducible. In particular, which of the two joint outcomes occurs [for particle 2] depends on the random initial position of particle 1..." This effect is sometimes called quantum steering and to the extent it exists in an interpretation, is always nonlocal. Again, I happily accept this as part of the BM approach and in fact it demonstrates my point: the setting for particle 1 steers the outcome for particle 2. But midflight, nothing else can - else that apparent steering effect would not occur (that's experimental fact).
Now I read this to mean: After Particle 1's spin is measured, Particle 2's spin on the same basis is fixed (and will not change, regardless of dynamic changes elsewhere in the universe). This is of course what happens in actual entanglement experiments.
Norsen, Fig.6 diagrams this. Missing from the diagram and related text: a) the rest of the universe; and b) computer bits per Demystifier's "a macroscopic apparatus which permanently remembers the measurement outcome, so implicitly [Norsen] is assuming something having the same role as "bits on a computer", even though he does not use those exact words." If Norsen or Goldstein ever say anything resembling "bits on a computer" as being entangled with particle 2 [B in our example], I'd like someone to show me. I'm open. If this is such an important element of BM, how is it missing from Plato and every other summary of BM?
Because once the first entangled particle is measured, there is no ongoing entanglement from that particle to consider. Particle 1 might exist, might not, it doesn't matter to the future of particle 2 as to spin on that basis. And whether or not you choose to say Particle 1 is "still entangled" with Particle 2 after Particle 1 is measured makes absolutely no difference to the description of physics - Bohmian or otherwise.
Again, I'm happily open to be corrected from anyone who has a suitable author (hopefully not yourself), with a suitable reference (I'm not too picky), and an actual relevant quote (just as I provide). Or at this point, answer this (also with suitable quotes):
In BM: Does Particle 2's spin observable [photon B in our example] change midflight prior to its certain expected outcome upon its measurement? If so, what are the details that lead to a change and then bring it back to the predicted outcome?
-DrC
@DrChinese here is one quote for you by Goldstein et al in https://arxiv.org/abs/quant-ph/0308039 (page 18):
"In order to avoid inconsistency we must regard Bohmian mechanics as describing the entire universe, i.e., our system should consist of all particles in the universe: The behavior of parts of the universe, of subsystems of interest, must arise from the behavior of the whole, evolving according to Bohmian mechanics."
From this quote it may still not be obvious to you that it is related to entanglement, but Norsen is even more explicit in his book (T. Norsen, Foundations of Quantum Mechanics, page 200):
"The pilot-wave theory is manifestly non-local in the following sense: the velocity of each particle, at a given instant, depends on the instantaneous positions of all other
particles (at least when there is entanglement)."
Are you saying that pilot wave cannot describe entanglement?
