Yug Ahuja
- 3
- 1
I am trying to understand the physical and intuitive origin of the ##π^2## factor in the moment of inertia (πΌ=ππ2) from first principles, but I keep running into circular or unsatisfactory definitions in standard textbooks.
Usually, the [π2] factor is justified using one of two methods:
Finally, is there a way to understand π2 dependence without going circular, or by at least defining one of the things properly without using layman terms like rotational analogues and then throwing up formula. I mean a definition of something should be such that it is self explanatory and directly links to mathematical expression or it lays method by which we can derive the expression
- The Kinetic Energy Derivation: Substituting (π£=ππ) into (πΎπΈ=##\frac{1}{2}ππ£^2##) yields (##\frac{1}{2}(ππ^2)π^2##). While mathematically elegant, this simply groups variables; it doesn't give a dynamic, force-based intuition as to why the resistance scales with the square of the distance.
- The torque derivation: Using (π=ππΉ) and (π=πΌπ) to get (##\tau=mr^2\alpha##). I got a reasonable explanation for ##π^2## explanation from somewhere but it require prior understanding of the torque. I have still stated the explanation below When you try to rotate an object (like spinning a ball on a string), the distance from the pivot point ([π]) works against you twice:
- First Factor of [r] (Leverage/Torque): To make something rotate, you apply a force. However, what actually causes rotation is torque ((π=πΉΓπ)). If a mass is twice as far away ([2π]), the force we apply has less "rotational leverage" over it. You have to push twice as hard just to apply the same rotational action to that distant mass.
- Second Factor of [r] (Linear Speed): For a wheel to spin at a certain angular speed (RPM), the outer edge has to travel much faster than the inner part. If a mass is twice as far away ([2r]), it must travel along a circle that is twice as large. To keep up with the rotation, it has to move with twice the linear velocity ((π£=ππ)). Accelerating a mass to twice the linear speed requires twice the effort. Because these two factors happen at the same time, they multiply together to give ##π^2## dependence
