romsofia said:
In a "natural" frame you get $$[\partial_a, \partial_b] = 0.$$
What you wrote is what relativists would say comes from a "moving" frame. I've seen it when we start from a "moving" coframe usually written something like ##\theta^i = a^i_j dx^j, d \theta^i = -\frac{1}{2} C^i_{jk} \theta^j \wedge \theta^k ##. These ##C^i_{jk}## are functions called structure coefficients, and it does take some work to get them into this form.
The duals to this + commutation we get ##[e_i, e_j] = C^{k}_{ij} e_k##. Which is like something you start with.
It is just the definition of a non-coordinate basis.
romsofia said:
In a "natural" frame, you can write the Riemann stuff as $$R_{\alpha\beta}{}^\lambda{}_\mu \equiv \frac{\partial}{\partial x^\alpha} \Gamma^\lambda_{\beta\mu} - \frac{\partial}{\partial x^\beta} \Gamma^\lambda_{\alpha\mu} + \Gamma^\lambda_{\alpha\rho} \Gamma^\rho_{\beta\mu} - \Gamma^\lambda_{\beta\rho} \Gamma^\rho_{\alpha\mu}$$
I've never used Carroll, so not sure about his conventions and all that, but the above notation comes from Choquet Bruhat's intro GR book, and the arbitrary frame formula is exercise I.9.1 if you are able to get access to it.
Thanks a lot, I have found this book, my problem have a close relation with exercise I.9.1. and using 'tetrad' ##e_a^I## we will arrive at a strange result.
My definition of connection:
$$\Gamma_{abc} = \frac{1}{2}(g_{ab,c} + g_{ac,b} - g_{bc,a} + c_{abc} + c_{acb} - c_{bca})$$
So ##{\Gamma^a}_{bc} = g^{ad} \Gamma_{dbc}## is just the connection ##\omega^\alpha_{\mu\beta} ## he difined, with this connection the covariant derivative of the metric is zero;
If we use relation ##g_{ab} = {e_a}^I {e_b}^J \eta_{IJ}## and ##{c_{ab}}^d = 2 {e^d}_J {{e_{[b}}^J}_{,a]}## , We can find that the connection ##{\Gamma^a}_{bc}## is:
$${\Gamma^a}_{bc} = {e^a}_I {{e_b}^I}_{,c}$$
Or we can express it in such a form:
$$\partial_c{{e_b}^I}={e_a}^I{\Gamma^a}_{bc}$$
Then we can calculate the curvature of this connection:
$${R^a}_{bcd} = 2 {e^a}_{I} {{e_b}^I}_{,e} {e^e}_J {{e_{[c}}^J}_{,d]} = -{\Gamma^a}_{be} {c_{cd}}^e$$
So we can draw such a conclusion:
For a coordinate basis ##e_a##, the metric ##g_{ab} = {e_a}^I {e_b}^J \eta_{IJ}## is non-degenerate, but the curvature correspond to it is zero. Is this result a little strange
