Is 'local realism' a meaningful term in Bell's Theorem?
  • Context: Graduate
  • Thread starter Thread starter DrChinese
    Realism
153 replies · 23K views
Found it! --- NP stands for Nondeterministic Polynomial Time ...
NP-completeness difficult stuff.
But for this line of reasoning to confirm that QM and the MW interpretation of it (That MWI is an interpretation of QM may just be my opinion) is correct don’t we have to assume that the Classical view must be deterministic.
Has it been shown that Classical cannot be Nondeterministic, or is that something that is just assumed?
kvantti said:
Yes, you just "look" the situation from the inertial frame of the quantum system in question. In the MWI, different inertial frames are just special cases of different universes. In other words, every inertial frame can be thought to be it's own universe (or rather, a different view of the same universe; likewise different universes are just different views of the multiverse). It is rather complicated, because the multiverse is a multidimensional "object". No one knows how many dimensions. String theory suggests 10 dimensions.
A bit off-topic but I have to make sure, don't the extra dimensions in string theory just refer to the fact that the strings would have to move/vibrate in more than 3 dimensions? (Which to me sounds like the dimensions could be just as well thought of as some completely different property than spatial dimensions, like an ordinary string could vibrate spatially and by "colour", etc...)
kvantti said:
Particles are point-like in the way that they don't have any spatial size. In our most fundamental theory of reality (the quantum field theory) particles are quantas of energy of different quantum fields. How could energy have any "size"? The classical "size" of any particle is defined by its Compton wavelength.
Yeah, definitely concepts like "size" need to be viewed critically here, but not only that, also we must view critically any sort of concept of particles. And the whole concept of "identity". Not only when we imagine identity to such thing as "photon", but even if we think about the universe as if it's one big continuous "fluid" where particles exists as stable standing waves (or whatever), we have still tacked identity to this "fluid". It may seem very obvious that something must have an identity in objective reality, but it must be noted that this intuitive view has bitten ourselves in the ass so many times on so many issues, that I'm becoming convinced that "identity" is a non-sensical concept as far as metaphysics is concerned. For example, it is completely arbitrary and without any empirical evidence, to assume that locations of space or spacetime have any identity to them. It is odd that physicists ever expected it to be so.
And having said that, even though we "kind of" understand the above, we still naturally imagine QM-situations in terms of things that have identity to themselves (instead of being stable patterns onto which one can arbitrarily tack identity, like onto a "standing wave" or a "shadow"). The fact that we consistently find such behaviour as we could expect a quantum mechanical electron to cause, does not mean there must "really" be a metaphysical electron. It just means there is some process causing this behaviour. Just like the fact that we consistently find our shadow to follow us, doesn't mean there actually is such an object with identity as a "shadow".
As a more concrete point in case, we can talk about how a photon, if energetic enough, can turn into an electron, or more vaguely, how energy can turn into matter (or vice versa), but is it not much more proper to understand that all these "fundamental particles" are not in fact fundamental at all. It is not like the energy as one fundamental thing just magically turns into some other fundamental thing (that has "fundamental inertia"). It's more proper to understand these particles as emergent features of whatever causes them, and their behaviour is also, after all is said and done, governed by their underlying causes (and I think one important question is going to be "what is charge metaphysically?").
I see no problem seeing motion as an illusion... then again, I think the whole universe we perceive is an illusion of some sort. :biggrin:
Well, the problem with calling something an "illusion" is that it means one basically just refuses to give any cause to some phenomenon. Sure we should expect motion to be something different from what it readily seems, but even more so we should expect "time" to be something different than what it seems, because it is a concept that is derived from "motion". I get a rash from the interpretation that the flow of time is just "an illusion in a static spacetime", because that is the same as saying "reality is static and conscious experience is magic". I understand the need for the word in some cases but it really is very very dangerous word that ought to be avoided :)
That being said, what is very important to understand is that as long as one talks about the concept of spacetime, he must also remember that nothing moves in spacetime. We are so used to the idea of "motion" that otherwise astute people often confuse the concepts of "spacetime" and "motion" together in incoherent ways. For example when they talk about how a photon "moves back and forth" in spacetime.
It must be understood that if spacetime is what is used to describe motion, you cannot then assert that something is in fact moving inside spacetime, for you would need a new time dimension to describe that motion. The matter of the fact is that metaphysical spacetime and metaphysical motion are mutually exclusive concepts. We can only have one or another. And to assert that only our "consciousness" moves in spacetime is also an assertion about motion "within" spacetime, regardless of if you call it an "illusion" or not.
This is not just a minor mathematical problem that can be dismissed, but it in fact highlights very concretely the problems of such assumptions as the metaphysical existence of spacetime (strictly speaking, the observable predictions of relativity don't require spacetime to exist because relativity of simultaneity cannot be directly observed). I don't think anyone has been able to actually make any explanation about how the "illusion of flow of time" could be achieved if nothing is in motion in reality, but everybody are very willing to dismiss the whole problem as meaningless because you really don't bump into it until you get to the philosophy of the mind, which may seem unrelated to physics, but it is not.
(Let it be said that I understand our subjective experience is very different from its immediate "causes" in objective reality, which is why I say it is an emergent feature of its parts)
Not just full atoms, but whole molecules too! In the '99 a research team was able to observe the self-interference of a http://wwwcsif.cs.ucdavis.edu/~cs175/Images/Buckyball.png is an article about the experiment.
So we have little balls of matter interfering with themselves. Nice.
This is very interesting. Thanks.
-Anssi
Does anyone have more information about this?
-Anssi
Try http://www.physics.usu.edu/peak/phys_2710_fall06/Complementarity.pdf#search=%22double%20slit%20buckyball%22" . A good general description of various double slit experiments including the buckyball one, and does elementary calculations using DeBroglie wave length.
Yes, the extra dimensions first came up because they were needed to represent the one-dimensional strings. But the six extra dimensions can also thought to be the "landscape" in which the different universes of the multiverse exist:
world-science.net said:
String theory proposes that the many different types of subatomic particles are really just different vibrations of tiny strings that are like minuscule rubber bands. The catch is that it only works if the strings have several extra dimensions in which to vibrate beyond the dimensions we see.
Why don’t we see the extra dimensions? A proposal dating to 1998 claims we’re trapped in a three-dimensional zone within a space of higher dimensions. Other three-dimensional zones, called “branes,” could also exist, less than an atoms’ width away yet untouchable. The branes are sometimes called different universes, though some theorists say they should be considered part of our own because they can weakly interact with our brane in some ways.
http://www.world-science.net/exclusives/060330_multiversefrm.htm
Yeah its funny, we can only observe the properties particles exhibit (mass, spin, charge etc.) and make models of the interactions and relations of those properties. So we don't acutally observe the particles, just their behaviour.
As I quoted Lee Smolin on the other forum, "a point in spacetime is not defined by its location -- its defined only by what physically happens at it." This is just fancy way of saying that we can't assing any specific "location" to spacetime itself; only to events in spacetime.
Are you referring to some hidden variable theory?
Particles are quantas of energy according to quantum field theory. Why this explenation isn't satisfactory to you? When a particle decays to other particles, its just different field interactions changing the energy (of the quantum field) into another form. In the case of a photon, the electromagnetic interaction "splits" the quanta of the neutral spin 1 field into two quantas of the charged spin ½ field if the conditions are appropriate for this kind of interaction to happen. According to QED atleast. Charge is the probability for the charged spin ½ field (or the electron field) to interact with the neutral spin 1 field (the em-field).
Conscious experience isn't magic; the quantum state of a persons consciousness just differs at every area of spacetime, giving illusion of the "flow of time". The entropy of the brain increases when "moving forward" in time, or in other words: the quantum state of the consciousness is more disordered in the "future" areas of spacetime. And consciousnes doesn't "move" within spacetime (as you suggested before), but instead consciousness exists at every area of spacetime where the persons brain exist; just that in different areas of spacetime, the quantum states of the consciousness differ from each other.
Yes. Nothing moves in spacetime. Motion can be viewed completely as an illusion: when you observe some object moving, you really just remember the "past" position of the object differing from the "present" position of the object. When this happens continuously, you see the object "moving".
Yup, nothing moves inside a static spacetime continuum, not even consciousness.
It has been explained. I just never realized your point until now... and now I feel stupid. :biggrin:
Yeah, exactly
Nah, I'm not very fond of hidden variable theories, at least not when they still assume particles are at all times entities with spatial stability (i.e. "like tiny balls").
I'm just saying that we shouldn't look at any observed stable pattern as more than just that; a stable pattern. Any stable pattern, like a shadow of a building or a standing wave inside a room, could be understood as a stationary entity because there is a sense of stability to their existence, but physically we can't say they are entities that are just "sitting there", but instead there are stable patterns whose stability is a result of an active process.
And such appears to be the case for matter as well. Matter is not something that is just "sitting there". There is an active process that keeps what we call an atom (or a buckyball molecule) spatially stable.
It is possible that the relative motion between such spatially stable patterns is mechanically explainable by some model that also explains just why is there such spatial stability, and such models are likely to make very different assumptions about what exists fundamentally (as compared to the standard model), and may give QM phenomena a completely deterministic footing. E.g. the locations where we observe electrons (or phenomena associated to electrons) are not necessarily required to be such places where an entity called "electron" would have had to move in any Newtonian sense at all, and this assertion is, I believe, completely valid option for a realist.
So you could say my belief is that we just haven't figured out the proper model yet, but that we are capable of doing so by letting go certain particularly sticky assumptions about reality.
When you say "when this happens continuously", are you not invoking an idea of motion? (For there is no sense of something happening continously without pointing out continuous "moments" from spacetime)
Obviously it is very understandable idea that the "state of the brain is different at every area of spacetime" and it is only expressing the past at any particular "moment" we choose to point at in the spacetime, but even then, we cannot really say what is it - metaphysically - that is doing this choosing and pointing. Why do we ever feel like there is a "now" moment?
I believe the most popular way to understand spacetime is to just consider the future and the past to exist at all times (so to give a simple ontology for the relativity of simultaneity), and in such case all the states of the brain exist "all the time", and metaphysically there is no such thing as "now moment" at all except for our subjective experience. This is why Einstein said "time is just an illusion" etc...
But this view fails completely to account for what is it physically, that causes the "now moment" to exist in subjective experience. It must be something in the physical world causing this, yes?
For these reasons, I must consider the possibility that it really is "motion" instead of "time" that exists metaphysically. It is often stated that "for there to be motion there needs to exist time", but this is immediately invalid argument, because the semantical concept of "time" is what is derived from the fact that we observe motion. If things really are in motion and there really exists only present (not the past and the future), it would readily explain why the sense of "flow of time" exists in our subjective experiences.
Note that even if you consider it to be "time pointer" that "flows" in spacetime to give us the experience of "present moment", it is not meaningful at all to give any "speed" to this pointer. Regardless of its speed (or direction) through the static spacetime, the subjective experience "at the pointer" would be the same (for our sense of time depends on how reality is expressed physically in the brain). It is probably this fact that gives people confidence to the idea that time does not flow at all, but we should not forget that we would still need that "pointer" to exist, otherwise we have not given any explanation about why there is any subjective experience at all, and to me this just shows how the idea of time as a dimension is a non-sensical one and doesn't fit very well to ontological reality, even if it's a handy tool.
Consider the difference between "describing the motion of a physical system in an instantaneous manner, such as the brain in spacetime, and really experiencing the motion of a physical system; such as having a subjective experience. Consider this thought experiment:
If you take a snapshot copy of a physical brain and freeze all its motion (by some magic), does it still have a conscious experience of everything being still? No, for this would require thoughts (about stillness) to exist above physical motion.
If you wait for 10 minutes and take a snapshot of the state of the original brain, and modify the copy-brain manually into the same state, you have essentially inserted all the memories from that past 10 minutes into the brain, and if you now set the copy into motion, it surely would claim to have had a subjective experience of the past 10 minutes as if time was flowing smoothly.
But can conscious experience exist if time moves ahead in discreet steps? What if you do NOT set the brain into motion, but instead just project a new state onto it every 10 minutes? Would it still have a conscious experience of a smooth flow of time? What if you project a new state onto it once every year? Could you imagine the possibility, that while reading this, your experience right now of "this moment" is not real but is instead one that is "going to be updated into your brain a year from now"?
I think the more you think about these issues, the more inclined you become to consider the possibility that it is in fact motion that really exists, instead of a static spacetime block.
-Anssi
That is possible.
Well, spacetime is a continuum, so even if there is no motion, there is continuity. We observe this continuity as motion.
Because we experience the increase of entropy in the brain as "flow of time" and "now" is just an illusion of this process. Try to remember what you did 0,1 seconds ago. Confusing?
You don't need to derive "time" from the concept of motion. You can just say that "time is a thing that enables the state of a system to change". But then again, a state of a system cannot change without motion. :-p
I have thought the same from the perspective of the multiverse. In the multiverse, the quantum states of the universes actually are "snapshots" from the point of view of the observer. Every possible snapshot exists and these snapshots are connected with each other with the laws of nature. That is, when you have quantum states A and D, you can't get from A -> D without going thru B and C first. Same with the quantum states of the brains. The quantum states are separated by Planck times (the multiverse is a discrete system). This accounts for "continous" conscious experience aswel.
So, again, I see no problem from the perspective I see things. :wink:
The question is how is it that we experience an increase of entropy as flow of time? Perhaps this has more to do with relativity and philosophy than with QM, but nevertheless, the important point to pick up is that it is not really a satisfying explanation to say reality is a static spacetime block where nothing moves (where the whole concept of "now" is non-sensical), and that it is the continuity that we observe as motion. Of course I understand how this continuity describes motion, but that is not the same as really producing an experience of motion.
For reality to produce an conscious experience of motion, something in physical reality must be different "now" from "a moment ago" (even if these are misleading concepts).
Consider your own subjective experience. You have an experience that "now" is different from "yesterday", and surely your subjective experience is caused by something that exists in reality? Something "real" is causing your experience, right? Surely then something in reality is in different state "now" than it was "yesterday". Even if you consider yesterday still exists in spacetime, you need that pointer to experience the "now". It is not possible that in reality absolutely NOTHING is in motion or changes, because that would require your subjective experience to be something that is not part of reality.
So what I'm saying is that if you believe there is a spacetime, you have to commit to this idea absolutely before it is a valid ontological interpretation, and in that case you lose all sense of motion from reality, UNLESS you posit there is also pointer that moves in spacetime (so to make difference between today and yesterday for a given subjective experience), which then again is in conflict with the idea that there is no motion, but only a spacetime.
And to postulate that spacetime is static but pointer is in motion is not very elegant; why would there exist both, metaphysical motion and spacetime?
Yeah, that's the problem. Sure, it is not readily given that time is derived from motion, but what is given is that we can only expect to have either real time-dimension or real motion, but not both.
If we choose it is time dimension that exist, then the problem is, like you said, the state of the system cannot really change without motion. Of course the only system we really know to exist "in motion" is "subjective experience". Can it be different from one moment to the next if there is no motion?
But if we choose it is motion that exists, it becomes little bit clearer. We stroll around the Earth and observe motion. We may notice that each time a pendulum swings, our heart beats exactly 4 times, or a rotating wheel does exactly 5 revolutions. So we assume the "time" it takes for the pendulum to swing is constant (at least as compared to all the other physical systems around us).
So just now, by comparing the motion of different systems we have built a concept of time, and we might say "I'll run around the building in 50 pendulum swings". This doesn't mean there had to be "time dimension" underneath it all to make this running possible, for we could expect "motion" to be something that "just exists" in a fundamental sense. (Albeit it is still non-sensical to talk about the "speed" of this fundamental motion)
Does there exist a metaphysical "now" moment in MWI, or is reality still a set of static spacetime blocks?
If its latter, you still need something to change when subjective experience does.
I can't help but repeating myself: it's an illusion. The way we experience "the flow of time" is the only way we can experience it. For example, when your reading this text the entropy of your brain increases when it records the information you're reading. Because of the information your brain has recorded you have more memories of events, like reading this text. This gaining of new memories increases the entropy of your brains and gives an illusion of "flow of time". The fact that we experience "a present moment" is due to the fact that we can't remember the future; your brains haven't yet recorded future events. When the future events are recorded, you experience them as being in the "present" and after that, when your brains have recorded more events, in the "past".
Something is different between "a moment ago" and "now" (from the perspective of subjective experience): the amount of information stored in your brains.
AnssiH said:
Even if you consider yesterday still exists in spacetime, you need that pointer to experience the "now". It is not possible that in reality absolutely NOTHING is in motion or changes, because that would require your subjective experience to be something that is not part of reality. So what I'm saying is that if you believe there is a spacetime, you have to commit to this idea absolutely before it is a valid ontological interpretation, and in that case you lose all sense of motion from reality, UNLESS you posit there is also pointer that moves in spacetime (so to make difference between today and yesterday for a given subjective experience), which then again is in conflict with the idea that there is no motion, but only a spacetime.
You don't need a pointer. The "now" is at every point of spacetime. The "nows" of your brains (and thus your consciousness) just differ from each other.
Yes, it can. You just have to keep in mind that "subjective experience" is determined by the amount of information you have acces to and while the amount of information in your brains increases, you experience time "flowing".
The problem with only three dimensions is that the state of a three dimensional space can't change unless there is time; you would have only static 3D space. So, if you wan't to describe events in three dimensional space you need to use time, and the time component can be described as an extra dimension, giving total of four spacetime dimensions.
Nope, there is no "now" in the MWI. You could say that "reality is a static multispacetime block". This "multispacetime block" is the multiverse. This is a simplified way to see it and it doesn't describe all the properties of the multiverse.
It takes time to understand motion. But motion can exist without time.
Hmmm, we aren't making much progress... Let it be said, that I used to think of flow of time as an illusion much like you describe. I understand why people think this way. But some philosophy reveals that this view is not unproblematic at all. You must dig way deeper to really see the problems, and in particular form strong understanding about how we comprehend anything with semantical concepts and how we build those concepts in a mechanical sense.
So, let's see if we can clarify this a little bit from another angle. I'll try to proceed with careful steps. It doesn't matter if we disagree or not after this.
This is certain; We cannot claim "time must exist fundamentally, because otherwise there would not be motion".
We cannot claim this, because just like we can assert that "time" is what exists fundamentally (without cause), we can assert that "motion" is what exists fundamentally. The choice between is - to an extent - arbitrary. Just because our comprehension is based on concepts and classifications of reality, and because we need to use the semantical concept of "time" to express motion, does not mean reality works with semantical concepts also. We are forced to invoke the semantical idea of "time" to talk about "motion", but motion can still "really exist" without any fundamental entity like "time" dictating this change.
Otherwise we could also say that "numbers" or "vectors" must exist fundamentally, claiming that without numbers and vectors there could not exist "clusters of bananas" or "velocity addition", etc... Just that we need some concept to express something in reality doesn't make it of fundamental existence. (Note that any conscious experience is also a case of expression of reality, caused by the brain)
So we can establish that the choice between "time" and "motion" is somewhat arbitrary. Still agree?
Another thing that is almost certain is that "fundamental time" and "fundamental motion" are mutually exclusive; both cannot be fundamental.
I say "almost certain" because it is conceivable to imagine that time exists as a static dimension and it is read by a pointer/worldline that moves. It's conceivable but not very elegant, for various reasons.
If anything is allowed with motion, we could just as well expect it is the physical things, on which our subjective experience is based, that are in motion. If nothing is allowed with motion, this would include our subjective experience which certainly is "something". And more importantly, once we have described the structure of spacetime, our semantical concept of "motion" (of worldline) becomes meaningless as an explanation to the change in the subjective experience. The subjective experience could not detect which way this "motion of worldline" happens, because the worldline is not a homunculus entity (it is not "fundamental consciousness"). This well-known argument about the static existence of spacetime actually puts fair amount of mud on the idea that "time" is a prerequisite of motion.
So, to get any further with the issue, we must assume that "time" and "motion" cannot BOTH exist as fundamentals. Still agree?
At this point, people who have chosen the path of "fundamental time", are forced to resort to the claim that the flow of time in subjective experience is "an illusion". This they justify with the comfortable fact that reality is just an expression of the past in the brain at any given moment. But this claim does not so much explain anything as it ignores the problem. None of the states of the brain would be more "real" than any other state, yet in subjective experience one is, at a time, more real than others. Clearly this needs more words.
And here we get to the hard parts. It is difficult to explain it all briefly, but I'll try.
The issue is not so much about "how the expression of reality exists at any given moment", but to explain how is it that within subjective experience there is motion, if "nothing is allowed with motion". It is one thing to imagine the whole spacetime history of a brain, and another to understand a process of conscious experience occurring to that construction. When you have assumed that it is time that exists fundamentally, ontological descriptions of reality tend to get very muddy very quickly.
Considering the philosophy of the mind, it quickly becomes clear that it's better to understand consciousness in the sense that we are NOT conscious of "successive moments", but rather we are merely conscious of the "change" that happens. This becomes concrete in many cases. Any sensory stimulation must have a spatial AND temporal aspect to it before you can be conscious of it (the patterns in the neurons must actually change). The semantical concepts our brain builds are always juxtapositions of each others (They make sense without "fundamental meaning" only because there are "differences" to them; something is what something else is not). In many many ways, our subjective experience is about change, and for this reason it is absolutely impossible to really comprehend anything without invoking an idea of motion or change. You simply will not be able to describe subjective experience without invoking some idea of motion or change at some point. We are so used to change, that sometimes it takes considerable effort to just notice this conflict.
To say "...the entropy of your brain increases..." is invoking an idea of motion. To say "...the fact that we experience 'a present moment' is due to the fact that we can't remember the future" is invoking an idea of motion; it suggests one to imagine a metaphysical "moment" that is "real" at one particular "instant" but not at another instant.
At the face of it this all may seem like an indication that "time" could really be what exists fundamentally, just beyond our comprehension, but as you get closer and closer to understanding "static time" in an absolute sense (as in there is no motion anywhere at all), it merely clarifies the fundamental aspect of the problem of change within our subjective experience.
Subjective experience is caused by reality. Agree? If nothing changes in reality, nothing is causing change in subjective experience. This looks like a dead end.
Although, like I said, the correct choice between "fundamental time" and "fundamental motion" is not given. It could still be either one. But what is given is that if you build your model of reality around fundamental motion, things get very much clearer (Albeit any ideas about the "absolute speed" of that motion are still non-sensical).
And with current empirical knowledge, you can choose to do that. Like I said, it actually is NOT at odds with relativity, because relativity does not allow for direct observation of relativity of simultaneity. You can understand all the observable time effects as different relative speeds of the physical motion/processes (in different environments), although the more "descriptive" way to express this mathematically is probably much less elegant than Lorentz-transformation (Mathematical elegance is different from ontological elegance).
We still need to use the concept of time to "comprehend" motion semantically (to express it), but we must understand that it really is just a semantical concept, and reality does not work on semantical concepts. It just works under some fundamentals, of which we try to make sense by building semantical models of reality, that are always incorrect to some extent, because they are merely an expression of the real thing. Map is not the territory.
I hope that was not too confusing. It really is difficult to be brief with such a massive subject as this.
Yeah and I think I know why: you see things from a Newtonian point of view while I see things from the point of view of relativity. This conversation would go on and on without progress, because we just see things too differently. You see problems where I don't and vice versa.
I'm too tired to answer your whole post at the moment, I had three hours of sleep last night, and now I'm off to take a nap. Be back later etc.
Well I guess then we are just going to have to disagree.
Although, if you find the reality of static spacetime likely, why do you consider MWI to be simpler than this:
https://www.physicsforums.com/showthread.php?t=130623
Isn't it simpler to just assume that light (and everything) exists in spacetime in static sense just the way we find it to exist, instead of imagining a model of many worlds that would produce the same behaviour? After all, you have to think about the trajectory of light as "single object" in spacetime, then why couldn't it exist fundamentally just the way we find it?
That is basically same as saying "we don't know how things work, they just are the way they are". The static spacetime approach doesn't explain why we observe the world as indeterministic even though it should be deterministic from the point of view of a static spacetime.
The MWI is the simplest physical interpretation for explaining quantum mechanics. This is a fact. People don't see this because the change in paradigm is so huge, so incomprehensible, that they reject it straight handed. But the fact is that the MWI is a consequence of a very simple postulate: the mathematical formulation of QM describe the behaviour of a quantum mechanical system; not just probabilities of different behaviours (as in Copenhagean). From this postulate emerges the whole idea of the multiverse.
I like to think that the mathematical formulation of classical mechanics describe the way macroscopic systems behave. Same with quantum mechanics.
Well it's true that spacetime interpretation doesn't say anything about the indeterminism by itself (although it probably would be quite trivial to make all kinds of assertions about it that would be basically impossible to confirm), but as of the "we don't know how things work, they just are the way they are", that is the case with all models. Especially when we talk about ontological interpretations, they are literally just cases of selecting different "things" to exist fundamentally (like multiverse). This is what I critizised earlier in this thread and I certainly don't see reason to commit to any particular selection of "fundamentals".
Well I personally don't have any problems in making paradigm shifts, since I am convinced that any worldview that we are capable of is essentially a circle of beliefs; not fundamentally attached to any sorts of truths. And for the same reason I think it is just wrong to encourage anyone to commit to any interpretation, and whatever interpretation is the "simplest" really depends on what sorts of problems you are tackling (and to an extent how familiar you are with some interpretation).
For example, earlier you mentioned that Deutsch challenges doubters by asking "where else do the calculations happen if not in other worlds since there are too many degrees of freedoms for one universe" (or something like that). This particular idea about how many degrees of freedom there are is assuming that a photon experiences one particular moment in a Newtonian way (in which moment there are this or that many degrees of freedom). But it is not very difficult to understand the same system as if the photons bouncing "back and forth" in spacetime are affected by the "future" measurement of each others. The degrees of freedom all exist in single universe now, but it doesn't really make sense to say that the calculations happen in many worlds anymore. At any rate, the observable behaviour of the system is the same in either cases. This is true for any model; you can always build arbitrary number of mechanisms to explain any behaviour.
I believe this postulate would hold true for spacetime interpretation too...(?) The critical difference seems to be different terminology and different concepts to refer to time, and that with spacetime interpretation the idea about information transfer is different from "just particles"; it is rather a connection over all space in one universe instead of series of lines in many universes. Very similar, but so very different... :I
AnssiH said:
-- but as of the "we don't know how things work, they just are the way they are", that is the case with all models.
No, it isn't the case with all models. Some interpretations explain the physical behaviour behind quantum mechanical phenomenon, others don't.
The multiverse is a direct consequence of the postulate, not some tought up concept.
I'm not encouraging anyone, I'm stating a fact. The Occams razor decides which interpretation is the simplest.
It doesn't matter which quantum effects the quantum computer uses to calculate, photons or molecules, but it matters that a qubit can be in a superposition of state, ie. in the states |+1> and |-1> simultaenously. Either you interpret that qubits are in these states simultaenously in one universe or that they exit in only one state in one universe and in the other state in another universe, and that these universes superpose if the qubits are in decoherent state.
Nope, the postulate is specific to MWI only:
Wikipedia said:
Although several versions of MWI have been proposed since Hugh Everett's original work[1], they contain one key idea: the equations of physics that model the time evolution of systems without embedded observers are sufficient for modelling systems which do contain observers; in particular there is no observation-triggered wavefunction collapse which the Copenhagen interpretation proposes. The exact form of the quantum dynamics modeled, be it the non-relativistic Schrödinger equation, relativistic quantum field theory or some form of quantum gravity or string theory, does not alter the content of MWI since MWI is a metatheory applicable to all quantum theories and hence to all credible fundamental theories of physics. MWI's main conclusion is that the universe (or multiverse in this context) is composed of a quantum superposition of very many, possibly infinitely many, increasingly divergent, non-communicating parallel universes or quantum worlds.
http://en.wikipedia.org/wiki/Many-worlds_interpretation#Outline
It is the case with all human models about anything at all, not just QM interpretations. This is just elementary philosophy. A model is a set of "fundamentals"; something that is not caused but "just is" (and from which all the observable phenomena spring).
In the case of MWI, it doesn't explain how multiverse exists, it doesn't explain how photons exist, it doesn't explain why the universes affect each others the way they do. It says "they just do", which is what any other model says about their fundamentals.
Any explanation of any physical behaviour is at the bottom of it all an assumed set of fundamentals that are "not caused".
You can argue that some models explain more with simpler elements (note the history of the models of an atom, or the evolution from geocentric model of universe to heliocentrism to current ideas). Can we say that MWI explains more with less? How do we even measure that its fundamentals are simpler than those of other models? The meaning of "simplicity" is not unambiguous here.
And also, how can we make sure that MWI doesn't break reality into too small pieces? After all, it posits all this happens by things that we cannot directly observe, and these things also have functions that could also be broken into smaller and smaller elements. How do we judge where should the peeling end?
Also, any human idea is directly based on other ideas and vice versa, in a self-supporting fashion. This is why human understanding is "semantical" and capable of novel predictions. And this is also why any idea makes sense only if you have assumed a certain set of "truths". How can we measure that the particular set of assumptions - that make MWI possible - are true?
These are all important questions when we talk about ontology, and MWI is ontology more than "just physics".
And these above issues need to be understood at much deeper level than most people do. Most people do not appreciate what it means to claim something is "true". Even "true" and "false" are metaphysically non-sensical concepts, and I don't mean this in a naive way of "we cannot really know if this or that is true", but I mean the very method of classification of reality into "fundamental elements" is the only method with which an animal can make any predictions about its environment, but it is also always an arbitrary form of expressing reality. In many concrete ways that are not readily appreciated, just looking at an apple is a case of believing there is an apple there. Because you can only be conscious of your worldview, not the reality directly.
So, I just see it happening all the time that people assert something they believe in as "undeniable truth", without understanding it is undeniable only in so far that some other assumptions in their particular worldview are true. If the existence of god has been an undeniable truth your whole life, your proof of this is that world exists (for it could not without "the creator"). And it is fairly easy to see the circular fashion of the logic behind intelligent design, but all models are fundamentally like that. This is a restriction of semantical understanding.
Even when the postulate is that the formulation describes directly a QM system, you still have to interpret what are the fundamental elements whose behaviour the formulation describes. This is nothing more than an interpretation. In spacetime interpretation we could also say that the formulation "describes directly what really happens". Now, I hear you when you say "it is not the probabilities that the formulation describes", and I tend to agree; copenhagen says too much and is probably incorrect. But MWI doesn't make anything fundamentally differently; it just posits "these are the things that exist" and draws a relationship between those things and the mathematical formulation about the observable effects.
So I don't know how you can claim MWI is not a thought up concept. It includes many many many assumptions that it holds true, before it can get to the final conclusion about many worlds. I know this automatically because human thinking is like that. This should not be too difficult to see.
(And this is why it is immediately erroneous to claim that a working quantum computer proves MWI. Just because you understand its behaviour by the assumptions made by MWI doesn't mean it cannot work in any different fashion)
This is what I'm talking about. Little bit more philosophy into the picture please. Just what do you think are facts? And do you understand that Occam's razor can also be used by anyone just the way they please? I could say that by the Occam's Razor, I wish to cut out the many worlds and just have the one we can actually remember. And when you ask me to explain QM behaviour in single world, I can just claim that the nature of light, and everything, "just fundamentally exists" in advanced & retarded sense, until there exists a thermodynamically irreversible event. All I've done is selected another arbitrary set of fundamentals and no natural observer can demonstrate the difference.
...or you look at the nature of light and matter completely differently; i.e. understand their existence with different underlying concepts. (Note; this is not a hidden variable idea. This says more about reality than some hidden variable theory. It mostly says a photon is a particle as much as a rainbow is an object)
In the end I just want to stress that I am not refuting MWI as invalid, but I am very very worried about people getting emotionally attached to different sorts of models too much, and not really understanding why any model is necessarily just an arbitrary set of fundamentals, and cannot directly be shown true by the very nature that these models exist. For as long as you do not appreciate this fact, you do not abide to scientific philosophy, but to religious philosophy. You can never truly "unlearn" whatever set of assumptions holds your worldview together until you understand just how does your worldview exist. And if you can't do that, your thinking becomes rigid (and breeds reptiles of the mind, as Blake puts it ;)
There is a fine line between a model that describes phenomenon mathematically and a model that explains phenomenon physically.
If I would have to teach quantum mechanics, I would probably do it without intepretations. But then I'm basically just teaching the maths behind it.
Occams razor:
a model that is based on fewer assumptions, and gives the same experimental predictions as some other model that is based on more assumptions, is the simpler model out of the two and should be used to explain the phenomenon. In other words: the simpler the model, the better.
How can you interpret that in many ways? It may be that the MWI isn't the right approach to reality, but at the moment it is the simplest way to explain the quantum mechanical phenomenon. So if you don't want to set [model = reality], you can just say that "particles behave as they would behave if they would travel along every possible path from A to B."
I'm pleased to hear that. Although, I guess it is also important to say something about different interpretations, just not in too "factual" fashion. It should be stressed that it is pushing the conversation towards philosophy, and then you have to take into account the knowledge about knowledge.
Occams razor:
Yeah, that's what I oftentimes say, and even then I stress that it may be there are no particles in existent during the travel since we only see the reaction of the atoms. There are all kinds of paradigm shifts conceivable that could change the picture considerably, but still keep the same observable effects.
And about occams razor, I do think it has got some merit, but at some point it becomes unambiguous just what is considered the simplest model; it depends on how you judge "simplicity" or "elegance".
For example, when people believed that Earth is the center of the universe and all the planets and stars go around it, this was not just because of religious reasons or natural arrogance of man to place himself in the center of the world. This was because if you look up into the sky, the planets really do go around us!
So, the geocentric model was the one to choose. I'm not saying it was a stupid model at that point in time; it was the right one to choose from the experimental data, but it was a grave disservice to science to shut out alternative models.
There were experts who spent their whole lives studing geocentric model and attaching other models on top of it so that it was the basis of considerable amount if scientific models. When it turned out that every once in a while some planets move backwards for a while, their minds were so rigidly set into the geocentric model (which explained so much) that they thought the simplest way to explain this retrograde motion was to assume that some planets move in a figure of eight instead of in circles; that they perform a little backward orbit every year which to us looks like they go backwards. (You could for example posit that there are invisible planets rotating to opposite directions whose immense gravity causes the figure of eight)
And if you look at it, and you happen to assume geocentric model is true, you could validly argue that it is the simplest way to explain this. "We cannot just throw a wonderfully elegant geocentric model away due to one little observation; the model explains so much. The retrograde motion proves there are dark planets causing the figure of eight orbits"
And the way that progress happens is that the society unlearns; the old experts just die and young guns who have not invested into the old models perform a paradigm shift and decide heliocentric model is the way to go, albeit it means much of the investements of the previous generation need to be thrown away. This cycle is very natural to human thinking, and there likely are many kludges in modern models similar to "figure of eight orbits".
It has been observed that in very large galaxes the outer stars do not abide to Newtonian law of gravity: "every particle in the universe attracts every other particle with a force that is directly proportional to the product of their masses and inversely proportional to the square of the distance between them."
Namely, the outer stars move faster in their orbits than they should if they were to remain on stable orbits. This is now "proof" that there is invisible matter outside the galaxy pulling the stars (decided my Occam's razor), just like the retrograde motion was a proof of figure of eight orbits. The reason this is a proof is that Newton's law is "obviously true".
But it is not particularly hard to form a simple modification to the Newtonian law that would claim that at large distances the gravitational pull does not fall down "proportional to the product of their masses", and considering the possibility of quantum nature of gravity, it is kind of reasonable to expect there could be this sorts of effects.
The important question is; how do you really judge which one is more elegant way to go? To decide that the law of gravity is correct and thus there is invisible matter between galaxies, or to perform a deeper paradigm shift and look at gravity in a completely new way?
So, again, I'm not saying that the idea of dark matter is "definitely wrong". I'm just asking why do we consider it to be by far the most likely model?
Btw, I'm pretty pleased that the concept of "dark energy" is so vague about the nature of it; it implies that some sort of paradigm shift to gravity may well be in order, and the same paradigm shift could well place the idea about the birth of the universe (in big bang theory) into completely new light also.
All in all, the history of science is pretty fascinating thing, and looking at the way that scientific progress has happened in the past implies a lot about the modern theories and hopefully shows people better ways to recognize validity and invalidity between different ideas.
One fascinating pattern is how we have step by step placed ourselves further and further away from some priviledged position within the universe. Even now, although we do not consider ourselves to be at any sort of center point spatially, we kind of privilege ourselves temporally; we think we exist very near to the birth of the universe, when other galaxies are still visible and so on... Investigating a paradigm shift where our miniscule view of the universe only seems to imply a nearby birth event (by its local behaviour) might just be fruitful. (After all, it is hard to substantiate the idea that in the beginning of spacetime there exist an event which marks the creation of the whole spacetime, the end and all. This, if anything, is placing semantical concepts into conflicting positions)
If only the current experts had not invested their whole lifes into the big bang theory... :I
QM is flawed, is that a simple enough of a model for you?
Aren't all theories flawed, then, as none are perfect (or totally accepted as the true theory)?
...yes... Let's try this one more time;
All models are descriptions of the behaviour of semantical objects, not "real" objects. All we can do is pick up stable patterns, classify them into "objects" (arbitrarily). And apparently then confuse that model with reality.
You cannot be aware of anything but semantical objects. Anything you can think of is something that exists in your semantical worldview. Don't forget this.
There will always exist a number of valid TOE's. Some may be more elegant than the others, but that too depends on how you measure "elegance".
See, this is where I disagree. I think there is only one valid TOE (which, I think, hasn't been realized as of yet), and, whether or not, one of the present theories is just incomplete to be valid as THE one and only TOE, or an as-to-be-found TOE.
I probably should have been more specific with my post. I meant it will always be impossible to make any explicit ontological interpretation of any TOE. You could come up with math that describes the whole universe accurately, but you cannot find out what is the "metaphysically correct" way to interpret that math.
I'm not saying this merely on the basis of there already existing a great number of QM interpretations with no way to explicitly choose which is the "correct" one. I'm saying this because any ontological description or any "way" to understand any system ontologically is an expression of how semantical objects interact, not how "real" objects interact, and if you follow my arguments in this thread (starting from the first one) you should be able to figure out just why we shouldn't expect any object we perceive to be "real" fundamental object in any metaphysical sense. Not photon, electron, or anything. We are merely describing stable systems. Imagining that waves are real objects, instead of stable systems.
Labeling interactions and objects, perceived or not, is and, seems to be, one of the more complicating aspects with any 'system' (physics, religion, etc.) What is a 'real' object? What is a 'real' interaction?
A photo of a object or interaction isn't the object or interaction--it is a representation of that object or interaction. A person may be able to 'interpret' that photo of that object or interaction; but, it is still an interpretation--on a subjective level. Even if an event is seen by two people, such as an apple dropping from a tree, it can be (and probably would be) interpreted differently by those two people.
I think that is why math (in physics) and pure math is so well appreciated to some extent. It's hard to argue that 1 doesn't equal 1; but, anytime a representational object is exchanged for a numeric value, say, as in physics, such as t=t, which can become 3t=4t -1t, where t=time, an ambiguity can become incorporated where the interpretation is differing. Does having a '-t' mean, by some, that time travel is possible?
To me, that is one problem with MWI or string theory. It great for math and 'theory' (and maybe students like it for, it seems, lab time may diminished in that study area); but, labeling is extensive--and, therefore, interpretations of the 'labels' seems more varied--e.g. What does a membrane look like?
What is and, how many, interpretations can be made of even a 'real' particle?
Exactly, but the case is also the same without any photograph; when the person is actually looking at some system right in front of him. Think about how reality is expressed in the brain in the form of semantical objects, and how we have built such semantical concepts as "interaction" in order to be able to predict how things unfold (this occurs for obvious survival reasons). Think about how this semantical expression really correlates to actual reality, and how our thoughts are and always will be limited to handle only semantical objects, and nothing more.
Like, let's talk about gravity. Any dog or a cat probably assumes that "things fall down", which is enough to make predictions about how something is "about to fall down from the roof onto my head". At all times "down" and "falling" and even "acceleration" (of that given object) are nothing but semantical concepts and the same situation can be described in many many different ways, so to come up with the same prediction that the object from the roof will hit you in the head.
That object can be a rock, or a block of ice, or a sack of flour. All these can be handled as a single object by the math (and also by the semantical mind), while in metaphysical reality they are nothing like that, they are just stable systems. Super-darwinism.
Or think about a doughnut. We see it as if it is the doughnut that is the object here, but we could equally well say it is the hole and the surrounding space that is the object, and doughnut is the shape that is "missing" from the object. Either way we are talking about semantics, and it is merely the intuitive usefulness of looking at the doughnut as "the object" and the hole and surroundings as "the space" that we tend to do that.
Yeah. It cannot be argued that 1 is not 1 because we simply decided it is so, and numbers are not entities floating around in reality either, they are tools which we use to classify reality, we can do whatever we want with them.
Like in the example with object falling from the roof, a mathematician could also produce the correct prediction in many different ways, and each of these methods would seem to imply something about reality. But we could not choose which of the methods corresponds to the way the event occurs in reality. (With further observations we could shut some ideas out, but we would also probably introduce a number of new ontologies into the picture at the same time)
Let's take another example. We can describe the motion of waves on a pond with math, and find out where they interfere and how. We could say from the math that there "must be waves that actually travel over the surface of the pond", and we can also imagine the wave as an object with identity in our head, but in reality nothing but a shape ever traveled over the surface, the water itself just went up and down.
Likewise we could use math to describe a path of a tornado or how two tornados affect the paths of each others, so to predict where the semantical tornados end up at, but even though the tornados affect each others, they are not "real entities", they are just stable patterns. And this is the case when we describe anything, even photons.
So, it would be a mistake to interpret any math as if it describes any real objects. It doesn't say how reality is. It just describes semantical objects, and it predicts how we will find the semantical objects to behave.
Yeah, I have found that philosophically less aligned physicists tend to make rather arbitrary assertions about reality without even realizing it.
We naturally ask ourselves questions like "what does an atom look like", while we also abide to a model where it is the "electron" that gives off a "photon" which is what reveals the shape of any "thing". Noticed the conflict yet? Noticed how, strictly speaking, the atom cannot really "look like" anything? I think I put it down quite clearly here:
https://www.physicsforums.com/showpost.php?p=925018&postcount=39
(The latter parts of the post, from "Or think about an atom. What does an atom look like?" onwards)
I don't know, infinite number?
I'm not sure what you mean with "real particle" though. "Particle" is a semantical concept and QM phenomena quite explicitly shows they are not fundamental, but rather stable patterns/systems.
Stable pattern is handy as a semantical concept in that it allows the pattern to appear and disappear if the environment permits, like a tornado. Fundamental entity cannot do that unless we also imagine alternative dimensions where they go, like in MWI. It should have been clear when Einstein posited that mass equals energy, that mass really IS energy in stable interaction loop of some sort. It does not become "solid" in any real sense, it just performs certain functions which cause "solidity". If we find objects to disappear, energy has lost its structure, that's all.
And even when we talk about semantical electron, and even if it did not exhibit wavelike behaviour, could we really say that electron is a "real object", or is it rather that space is real and electron is a "hole" in it? Either way, we are juggling semantical concepts around, and reality does not work with semantical concepts, WE do, and we cannot get around that. Note how we are not only confused about reality of space & objects, but also time and motion... So very confused... :I
It seems to me you're stretching the term semantics until it ceases to mean anything coherent here. If this figure-ground perceptive change is "semantics" then so are the different was of seeing the Neckar cube, or any optical illusion. I think, haveing spent a lot of time doing just this kind of mental gymnastics that my understanding of "semantics" just doesn't relate to what seems to me to happen in my head when I do that. But perhaps you have a ready answer?
In biology, labeling works; in that, gross characteristics are categorized into phyla, species, etc. It's when something out of the ordinary is found that questions whether, what and how to assign it (aberration or new species).
Physics is the same, it seems, to a higher factor. Some things are accepted and definable, while a lot of others are theorized upon due to the inability to exactly define it (them) with enough validity. Some don't/didn't see classic physics as the total answer, so 'this' and 'that' theory are brought into play each with their own set of definitions and labels about this action or that caveat, each adding to the confusion with even more labels. I think that that is why conversations about physics often times gets into philosophy and even religion (how many religions in the world are there?). Too many unknowns and too many opinions about the 'too many' unknowns---and, I think, that it will continue until 'things' are more 'known'.
Yeah. Well, check out the first paragraphs of:
http://en.wikipedia.org/wiki/General_semantics
Perhaps I should talk about "general semantics" to cause less confusion, but I keep falling back to just "semantics" because language is so clearly just an instance of semantical understanding. language is semantical because our understanding is semantical. And yes, just being conscious of holding a coin in your hand or seeing an apple in your visual view is a case of semantical understanding. I'll try to break it down and I hope I can demonstrate why it is important for a physicist to understand this.
Sensory data causes spatial/temporal patterns to occur inside the cortex. This is where different objects are being recognized. But what does it mean to recognize an apple? Does there exist a metaphysical "apple neuron" whose firing means an apple has been perceived? Of course not. You must have first assumed there exists such things as "apples" in the world. The brain must form a worldview, which is assumptions about "what exists" and assumptions about their behaviour.
How does this learning happen then? I could say the brain classifies objects by their properties, but that would already be wrong, in that it would imply there really exists metaphysical objects that can be classified. Oh no, the brain only finds stable patterns, and assumes there are objects. We do not point at an arbitrary portion of a wall and call it an object, we classify reality into, let's say "sensible objects" (Like what rewebster said about labeling things in biology).
All this labeling and classification of the sensory data occurs because that is the only way to find "things" that exhibit persistent behaviour, and when we find such things, we can perform predictions. The brain can basically simulate reality. It perceives some situation, it recognizes objects (rolling rock, gushing water, fog in the wind...), and it can form some idea about what is going to happen. (Rock coming down on you will harm you, water might too, but fog won't, unless if it might be nerve gas, etc...)
At no point of this learning we had any actual "knowledge" about reality in our disposal. How could we have ever learned that there exists "ground" when we did not know what any of the sensory data means at all, when we did not know what is "visual" data or what is "audio" and what is "tactile"? Well, at root, the worldview is self-supported circle of truth. All ontological arguments are circular. All views of reality are a set of self-supporting assumptions. Not only that, all things we could ever perceive and form any semantical ideas of, were patterns that were distinguished by their differences from each others. Air could not be perceived if everything was air. There must also be an idea of "ground" so to give any meaning to "air".
This is why all our conscious understanding is semantical. Nothing has any metaphysical meaning to itself, and nothing we are conscious of is "reality". It is merely something we have a semantical idea of, and the idea itself exists only on the virtue of other ideas giving it some meaning. We do not even have any visual experience without a semantical worldview against which to interpret the data.
This is imperative to understand, so let's still imagine a world where everything was completely red. If everything was red, we would have no comprehension about colours at all. The red world would not look like "red" looks to us currently. We would not be conscious of any "red" things. The way we experience red now is arbitrary. Reality does not look by its colour the way we see it; there just exists different wave lengths of light. We could not consciously perceive red without being able to tell what is not red; without other colours existing.
So, just being conscious of an apple moving across your visual view will require a good amount of semantical interpretation of the data to occur. When the apple moves, a corresponding pattern moves across the cortex and only at the upper levels it will be recognized as an apple, and only by the virtue of some semantical assumptions about reality it can be assumed to be the "same apple" from one moment to the next.
And because we understand reality in terms of sensible objects, we tend to make the error of identity. It is useful to assume the apple really is the same from one moment to the next, even though this is completely arbitrary assumption. We assume the apple has got metaphysical identity, and we have an experience of our "self" having an identity (which I is caused by certain semantical assumptions also). As we break reality down into smaller components, we find that things like shadows, rainbows and tornados do not really have identity; they are just stable shapes which consist of different "stuff" from one moment to the next. But we still make the same error and ask "so what are the fundamental things then?" We assumed reality was made of "water, ground, air and fire" because we saw it fit to assume things really have identity to themselves.
The answer I can give is that there never was and never will be any fundamental "things". Reality consists of self-organization and there comes to exist stable patterns which interact and form new stable patterns in emergent sense, and at some point along that road there comes to exist the stable pattern that is our semantical prediction process, which is stable in evolutionary sense BECAUSE it can actually predict reality before reality itself catches up.
Many materialists fall to this fallacy of identity as well when they posit our identity is the matter we are made of. Here we come to the mind-blowing parts of the nature of our "self".
I said objects are recognized in the cortex. Many people naively imagine that we are the cortex then; whatever happens to the cortex is what we experience. This is almost right but in some important ways not quite. The cortex is not a metaphysical object either. It does not have identity to itself. It is just stable system, where in some arbitrary sense we can say there occurs so-called "object recognition", but it is not the cortex having a conscious experience, for the cortex is a "colony of things", like an ant colony. How does a colony conceive itself as one and have just one subjective experience? Why don't every neuron have a subjective experience of "reality hitting them"? Or if they do, which one is our "self"?
Note that a single neuron does not build a worldview in any sense, it is the whole colony that does. A single neuron doesn't have a model of reality in it; the whole colony does (in some arbitrary form). And this is an important hint; the colony has, by its structure, made an assumption that there does exist such a thing as "self". This "self" is entirely a semantical token in the worldview, which consists of nothing but "assumptions". The colony conceives itself as one.
There are many neurons, but only one worldview, only one interpetation process, and consequently only one subjective experience (it is possible, and there are cases, where there basically exists multiple worldviews inside one brain, which is the same as many "minds" inside one brain, which in some cases are both active at the same time and are capable of independent attention, like in the case if Kim Peek)
Furthermore, here I claim, that for conscious experience to occur the "learning system" must make semantical assumption about there existing such a thing as "self", and consequently interpreting sensory data in semantical form of "I see an apple".
We never were and never will be aware of reality hitting our cortex directly, for it is not reality we are conscious of, it is the semantical objects and ideas in the worldview instead! Think about that.
But it is important to notice, as you probably have many times while reading this post, that when I use semantical concepts to describe the above, I am moving in circles, and I cannot actually touch the "true reality" of what happens. No matter in which form you imagine the worldview to really exist, you are at all times merely imagining bunch of SEMANTICAL THINGS that exist in different configurations. This can be useful, but it is not reality.
This is why I can never exhaustively convince anyone about the above being true. If what I say is true, I can never convince you of it! Ain't that a bummer... I can only say there exists overwhelming amount of indications towards the above, and it basically solves the hard problem of consciousness as good as it can ever be solved. Semantical idea of the system that causes those semantical ideas is never true to reality of the system itself.
But I've already said enough, if you are interested of philosophical side of it, try;
(I still haven't had a chance to read this myself but I intent to, and judging from the first pages it is pretty spot on)
Or for mechanical side of prediction processes, try;
https://www.amazon.com/dp/0805078533/?tag=pfamazon01-20
(This I have read, and what is described could well be what gives rise to such system that can produce semantics and semantical predictions the way I described)
Phew... That was long but now I hope I put everything I have stated before into rather coherent whole, and I can just refer everyone to this post when I make confusing statements about semantics elsewhere ;)
AnssiH --could you paraphrase your post #148?
Just kidding---
now, how do you relate all this to physics and 'realism' in physics?
DrChinese
We lost a couple of the last posts---
could you repost your answer about the photons and electrons?
