TrickyDicky
- 3,507
- 28
Yes, it seems contradictory that GW are derived from linearized , Newtonian limit theory where point masses are assumed and the center of mass is completely accepted representation the body motion no matter how massive. and at the same time we are told that GW can't exist if massive bodies follow geodesic motion.Q-reeus said:So in the context of full GR treatment, when talking of 'small body' vs 'large body' re any departure from geodesic motion of co-orbiting masses, is this basically referring to mass as the only important determinant, or spatial extent? If the latter, wouldn't this imply it all hinging on 2nd and higher order extended body correction terms, making the rationale for GW generation quite different from the linearized theory where point masses are assumed?
Good point too.Mentz114 said:I suspect that for an incompressible solid extended body falling in the presence of tidal forces, the COM must follow a geodesic or there will be a torque around the COM, which would violate conservation of angular momentum.
Maybe it's possible to prove this, but I haven't come across it.
Yes that is exactly wha I mean, thanks. Connections can be derived from the vanishing of the covariant derivative of the metric tensor and we can introduce a special coordinate system, called a geodesic coordinate system, in which the connection vanishes for a body in geodesic motion.cosmik debris said:I'm guessing he means that the connection can be made to vanish for a body in geodesic motion.
