Monitor Flickering - Troubleshooting Tips
  • Thread starter Thread starter Emieno
    Monitor
The discussion revolves around troubleshooting monitor flickering issues experienced by a user, including problems with scrolling and color display. Participants explore potential causes and solutions related to display settings, refresh rates, and video card drivers.
  • One participant describes experiencing monitor flickering and slow movement when scrolling, noting changes in icon appearance.
  • Another participant suggests checking the refresh rate in display properties, recommending a lower setting if necessary.
  • A different participant proposes that if the flickering affects the entire monitor, it may be related to the refresh rate, while if it is localized to specific views, it could indicate issues with video card drivers.
  • There is a suggestion to verify the number of colors being displayed, with a recommendation to select a higher color depth.
Participants present multiple viewpoints on potential causes of the flickering issue, with no consensus reached on a specific solution or diagnosis.
Participants have not provided specific details about the operating system or hardware configurations, which may influence the troubleshooting process.
Emieno
I am not a computer geek, I don't know what has changed in my system either.
Whenever I scroll down or up the page or folders, the monitor looks like flickering, not smoothly as before, and it moves really slowly.
I tried changing monitor screen size smaller (800x600) or larger (1280x1024), but nothing changes at all. Also, all of the icons in my task bar look ugly since their colors don't fit.
Thanks :biggrin:
Computer science news on Phys.org
Also, the colors of all of the icons in my task bar do not look good because they are, let's say, over-spilled, faded, I mean.
Anyone can help me solve this problem ? Again, thanks a lot.
It could be worth checking the refresh rate on your monitor.
If you're using Windows, look at the display properties. I think it's under the "Advanced" button. Try changing to a lower refresh rate.
Also, check that you have enough colors - select 16 million or 32 million, not 256.
If its the entire monitor flickering, something might be wrong with the refresh rate. If its simply the folder view flickering or just the web page flickering, your vidoe card drivers have either corrupted or have been overwritten. Go into your settings and tell us what it says in settings above the # of colors to show. It should say something like *Your monitor* on *Your video card*. For mine, it says Plug and Play Monitor on NVidia Geforce FX 5950 (im too lazy to find the monitor drivers lol).
Tell us what it says there if you can.
  • · Replies 20 ·
16K
