Lagrange-Young equation in Fluid Mechanics
The discussion centers around the Young-Laplace equation in fluid mechanics, specifically addressing the relationship between surface tension, pressure differences, and the physical principles underlying these concepts. Participants explore theoretical aspects, seek clarifications, and engage in technical explanations related to fluid behavior and interfacial forces.
  • One participant questions why surface tension (γ) is considered a result of chemical forces, suggesting that pressure parallel to the surface should also be accounted for in the Young-Laplace equation.
  • Another participant explains that pressure acts only normal to surfaces and that there is no shear component of pressure in fluids.
  • A participant expresses uncertainty regarding the definition of ΔP, asking whether it represents the pressure difference between the inside and outside of a fluid element or a pressure change within the fluid.
  • One participant states that the formula γ = ΔP * area / circumference arises from energy minimization of a dividing surface, referencing the complexity of the derivation.
  • Another participant emphasizes that while fluids cannot support shear stress statically, they can exhibit shear stresses through viscous deformation over time.
  • A later reply clarifies that the inability of fluids to store elastic energy contributes to the absence of a parallel component in the context of the original question.
Participants express differing views on the nature of pressure in relation to surface tension and the Young-Laplace equation. There is no consensus on the interpretation of ΔP or the implications of shear stress in fluids, indicating that multiple competing views remain.
Some discussions involve assumptions about fluid behavior that may not apply universally, particularly regarding Newtonian versus non-Newtonian fluids. The complexity of deriving the Young-Laplace equation and the definitions of terms like ΔP are also noted as potential sources of confusion.
Nikitin
Young-Laplace equation in Fluid Mechanics
EDIT: I meant the Young-Laplace equation, of course, not the Young-Lagrange.. sorry!
Heya!
According to said equation, ΔP*area = γ*circumference, for an interface of spherical fluid-element.
Can I pls get some explanations?
1) Why is tension, or γ, purely a result of chemical forces? Isn't there a pressure parallel to the surface, just like there is a pressure inside the fluid-element? Because if there were, the equation should be ΔP*area + P*area = γ*circumference.
2) Is there a physical explanation for the formula? Why does γ=ΔP*area/circumference?
I am not familiar with the name Lagrange-Young equation, but it seems to describe how surface tension is related to the pressure difference over the surface.
Then it makes perfect sense. The force of tension at the boundary of some surface segment must stretch it, and the total "stretching" force over the entire boundary must be balanced by the force due to the pressure difference over the area of the segment.
Think about a balloon made of rubber. Because the rubber is stretched, it presses against that content of the balloon, thus the internal pressure is higher than the external. Now cut a piece of the rubber from the balloon. It will be acted upon by the pressure difference, tending to separate it from the rest of the balloon, so in order to keep it in place, you must apply force to its edges.
You're right to not be familiar with it, because it's called the Laplace-Young equation.. Sorry, I keep mixing lagrange and laplace. :P here's what I was talking about: http://en.wikipedia.org/wiki/Young–Laplace_equation
Anyway: I read the explanation offered by Cimbala & Cengel's fluid mechanics, and I think I got it now. Though I am unsure on what delta-P actually is: is it the difference between the pressure inside the fluid and outside, or is it the pressure-change inside the fluid?
The referenced article explains what ## \Delta p ## is.
Heya!
Pressure only acts normal to surfaces. There is no shear component of pressure. Any way you orient an area element within a fluid, the pressure only acts perpendicular to the area element. In a fluid, the viscous portion of the stress tensor has shear components on arbitrarily oriented area elements, but not the pressure portion.
Chet
The second question is easier to answer: it arises from energy minimization of a dividing surface. The detailed calculation can be difficult to follow, but a good reference is here:
http://www.sciencedirect.com/science/article/pii/0001868695002820#
Similarly, Young's equation is derived from conservation of momentum at the three-phase line.
I may not understand what you are asking in question (1): the interfacial energy is just that- the energy associated with an interface. Since fluids can't support a shear stress, there is no 'parallel' component. Solids can support a shear, so the interfacial energy of a solid-vacuum interface is not easy to define (Wulff constructions are commonly used). A good starting point is here:
http://www.virginia.edu/ep/SurfaceScience/Thermodynamics.html
I think that this needs to be qualified a little. Fluids can't support a shear stress statically, but can exhibit shear stresses by deforming viscously with time (i.e., with time in a Lagrangian sense). For example, fluid being sheared continuously between parallel plates causes a shear stress on the plates.
Chet
Chet
Yes, fluids flow in response to shear. Sometimes the flow is reversible, most often it is not. In any case, a fluid's inability to 'store' elastic energy is why there is no parallel component in the OP.
Edit: my comments above are restricted to Newtonian fluids only- viscoelastic fluids, bingham fluids, and other fluid phases possessing a yield stress violate what I said above.
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 36 ·
  • · Replies 19 ·
