Using the equations Wilson’s, Margules’, and van Laar’s, plot the
  • Thread starter Thread starter scott_for_the_game
    Plot
The discussion revolves around plotting vapor-liquid equilibrium (VLE) using Wilson’s, Margules’, and van Laar’s equations for a specific system at a given temperature. Participants seek clarification on the methodology for VLE calculations, including the use of fugacity coefficients and the interpretation of results.
  • Exploratory, Technical explanation, Debate/contested, Homework-related, Mathematical reasoning
  • Some participants inquire about the process of plotting VLE and express confusion regarding the use of fugacity coefficients.
  • One participant shares specific calculations for dew and bubble temperatures and compositions but questions the accuracy of their results using Raoult's Law.
  • Another participant suggests that the calculations may require the use of activity coefficients and fugacity rather than ideal assumptions.
  • There are discussions about the need for correct units (Kelvin vs. Celsius) in calculations and the implications of using Antoine's equation for saturation pressures.
  • Some participants express uncertainty about the differences between the three activity-coefficient models and their respective accuracies, questioning the necessity of each model.
  • There is a request for clarification on how to plot the results, specifically regarding the axes and whether new values for compositions need to be calculated.
  • One participant mentions the need for iteration in calculations, particularly in relation to fugacity, but does not clarify what specific values need to be iterated.
Participants do not reach a consensus on the correct approach to plotting VLE or the necessity of using fugacity coefficients. Multiple competing views on the methodology and the interpretation of results remain evident throughout the discussion.
Participants express confusion over the correct application of equations and the need for specific assumptions, such as temperature and pressure conditions. There are unresolved questions regarding the iterative nature of calculations and the dependence on the chosen model for accuracy.
Students and professionals interested in vapor-liquid equilibrium calculations, particularly those working with non-ideal mixtures and seeking to understand the application of different activity-coefficient models.
scott_for_the_game
Using the equations Wilson’s, Margules’, and van Laar’s, plot the predicted VLE for this system at this temperature, with and without the use of fugacity coefficients.
Anyone know how to do this or can explain to me how to do VLE. Or have a link for a worked example.
Cheers.
Cheers.
Presumably, you were to learn this in class or from a text. Do you have a specific question you're troubled by? If so, post the question along with what you've accomplished so far and where you're stuck.
(a) Find the dew temperature and composition for a mixture of y1 = 0.55 at 3.954 bar. (Answers. 371 K and x1 = 0.58)
(b) Find the bubble temperature and composition for a mixture of x1 = 0.50 at 3.954 bar.
(Answers. 371 K and y1 = 0.49)
(c) Using the Wilson equation and the constants listed, find the bubble pressure and vapour composition for a mixture of 30 mol% methyl acetate at 90C.
(Answers. 3.1 bar and y1 = 0.36)
Pc, bar Tc, K  Vc zc
Methyl acetate (1) 46.3 506.8 0.324 228.0 cc/mol 0.254
Methanol (2) 79.9 512.6 0.559 118.0 cc/mol 0.224
Antoine Constants (P is in torr)
A B C Range, C
Methyl acetate (1) 7.41791 1386.510 247.853 57 - 205
Methanol (2) 7.97010 1521.230 233.970 65 - 214
Constants A12 A21
Margules’ 0.8427 0.4043
Van Laar 0.8914 0.4718
Wilson 336.148 350.841
Vapour-Liquid Equilibrium Data at 3.954 bar Total Pressure,
Methyl acetate – Methanol
Temperature, C x1 y1
104.40 0.0000 0.0000
100.50 0.0880 0.1540
98.60 0.1980 0.2730
97.30 0.2960 0.3680
97.20 0.3980 0.4370
97.10 0.5150 05220
97.00 0.5380 0.5380
97.30 0.6260 0.5980
98.10 0.7320 0.6840
98.90 0.7970 0.7500
99.60 0.8340 0.7950
101.30 0.9130 0.8950
103.80 1.0000 1.0000
How would i solve each qu? Cause I don't get the right answer. I used Raoult's Law for the first two and didnt get close, is that right?
Are you working with the correct units (e.g. [itex]^{\circ} C \rightarrow K[/itex])?
So it needs to be Kelvin? Why's that?
ln P1sat = A - B/(Temp(K) + C)
BTW I copied the wrong table.. it should be constant temperature. Shouldnt make a difference though. I tried in Kelvin still don't get the correct answer.
1. Use the antoine eq to get the two Psat
2. Use P = P2sat + (P1sat - p2sat)xX1
3. Use y1 = (x1 x P1sat) / P
(i) In the antoine eq, it should be specified whether you need to use celsius or kelvin. Use the correct one to find Psat
(ii) The solution is non-ideal. So, you cannot use Raoult's law. You need to equate the fugacities and calculate the activity coefficients from the models
You may want to visit this website for an introduction to VLE
http://www.et.byu.edu:8080/~rowley/VLEfinal/VLE_home.htm
I found Chemical Engineering Thermodynamics by Smith & Van Ness very useful in understanding VLE. You might want to use that as a reference book.
Yeh I got that book, not impressed. Whats the deal with fugacity.. I hear you have to iterate to get the value? How do u do this?
Also what's the difference in using margules, van laar and wilson.. whichs one more accurate and if its marginal what's the point?
I don't understand. Iterate to get what value?
Have you read the chapter on Solution thermodynamics? That introduces the concept of fugacity of a species very clearly, IMO. If you're stuck somewhere and don't understand, post the specific question here.
The difference between the various models is explained pretty clearly in the text.
If you're stuck in a specific concept, then post your question here.
Listed below are the constants in three activity-coefficient equations - Wilson’s, Margules', and van Laar’s - for the system methyl acetate-methanol. In addition, the vapour liquid equilibria at one temperature are tabulated. Using the three equations, plot the predicted VLE for this system at this pressure, with and without the use of fugacity coefficients.
My question is what goes on the x and y axis.
Is it just the x1 and y1 composition on the x-axis and the P on the y-axis?
I'm confused on whether I use the x1 and y1 values given and graph is against the new P I obtain with the equations. Or do I need to calculate new values for x1 and y1?
Basically what I'm trying to ask is if your just calculating P with the 3 equations and plotting against the the x1 and y1 in the given data table.
I've got a feeling you have to calculate new x1 and y1 values.. but for instance with the margules eq you can calculate a new y1 but u have to use the given x1 to calculate gamma and P. So how would you get a new x1 value.
Or maybe I've got it all wrong.
there's qu's such as:
Where you need to iterate to obtain values. Does something as such need to be done for the plots?
Cheers.
29K
