Find F: R->R satisfying F(x+y)=F(x)+F(y) and F(xy)=F(x)F(y)
  • Thread starter Thread starter iN10SE
The problem involves finding a function F: R->R that satisfies the functional equations F(x+y)=F(x)+F(y) and F(xy)=F(x)F(y). Participants are exploring the implications of these equations and discussing potential forms of the function.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss various forms of F, including polynomial and linear functions, and question whether F can take on other forms. There is an exploration of the implications of setting specific values for x and y, and the use of the hint regarding positive real numbers.
The discussion is ongoing, with participants providing insights and questioning each other's reasoning. Some have suggested alternative approaches and highlighted potential issues with the logic presented. There is no clear consensus, but several lines of reasoning are being explored.
There is a mention of the lack of continuity or differentiability of F, which complicates the discussion. Participants also note the possibility of discontinuous functions that satisfy the given conditions, indicating that additional constraints may be necessary for a definitive conclusion.
iN10SE
Let F:R->R be a function such that, for all x,y belonging to R, we have F(x+y)=F(x)+F(y) and F(xy)=F(x)F(y). Prove that F is one of the following two functions:
i> f(x)=0
ii> f(x)=x
(Hint : At some point in your proof, the fact that every positive real number is the sqaure of a real number will be valuable)
Let f(x)=x^n. Then f(x+y)=f(x)+f(y) is not satisfied. So f(x) can't be a polynomial. Similarly f(x) can't contain e^x, logx, any trigonometric function.
Now let f(x)=ax, where a=!0,1.
then f(x+y)=f(x)+f(y)=2ax is satisfied but not f(xy)=f(x).f(y) as f(x^2)=a.x^2 but f(x).f(x)=a^2.x^2. NOw a = a^2 iff a= 0 or 1. hence the proof.
My confusion is (as I am new to prrof oriented maths.), I have actually never used the hint. So, did I skip any argument?
Thanks in advance.
The proffered proof shows some examples of what f(x) cannot be and gives two examples of what f(x) could be, but it does not prove that f(x) cannot be something else other than [itex](x \mapsto 0) \text{ or } (x \mapsto x)[/itex].
--Elucidus
thanks euclidian
ok...second try :
F(x+y)=F(x)+F(y)
put y=0
F(x)=F(x)+F(0)
so either F(x)=0 for all x
or F(0)=0 => F(x) has the form F(x)=xg(x) where g(x)=!0 for all x
now I have to show g(x)=1 for all x.
From the relations of F(x) and g(x), it can be derived
g(x+y)=(xg(x)+yg(y))/(x+y) and g(xy)=g(x)g(y)
put y=0 in second relation
g(x)=g(x).g(0)
g(x)=!0 for all zero, g(0)=1.
now I am stuck... but i GUESS i AM PRETTY NEAR?
The following piece of putative logic is troubling:
[tex]\text{If } F(0) = 0 \text{ then either } F(x) = 0 \text{ for all } x \text{ or there exists } g(x) \text{ such that } g(x) \neq 0 \text{ for all } x \text{ and } F(x) = x \cdot g(x).[/tex]
Take F(x) = sin(x). F(0) = 0 but F(x) is not always zero, nor does there exist g(x) so that g(x) is always nonzero and F(x) = xg(x).
It is possible to show that F(x) must be odd and F(0) = 0, but I don't think that implies that an x can be factored out of F(x).
--Elucidus
Thanks. but any suggestion on how to proceed then?
What is we substitute x=y;
then F(2x)=2F(x)
also F(x^2)=(F(x))^2
i think something to do with square may come from here
Caesar_Rahil said:
Not true, i can say F(x)=x . (sinx / x )
your g(x)= sinx / x
Yes but sin(x)/x isn't always nonzero.
--Elucidus
--Elucidus
Well when is it zero??
F(0)=0
F(1)=1 or F(1)=0
also F(2x)=2F(x)
Put x=1;
F(2)=2 or F(2)=0
you can try going on like that
Also if F(x) is differentiable (it is not given but still)
F'(x)=lim(h->0) F(x+h)-F(x) / h
= lim (h->0) F(h) / h
= constant
since F'(x)=constant
=> F(x) is linear => F(x) = kx +c
Put x=0,1;
you get F(x) = x or F(x) = 0
Proof still not valid though
At any nonzero multiple of pi.
--Elucidus
For any integer k, F(kx) = kF(x) and specifically F(0) = 0 (as mentioned) and F(-x) = -F(x) (which makes it odd).
If one let's F(x) = x + G(x) then
xy + G(xy) = F(xy) = F(x)F(y) = [x + G(x)][y + G(y)] = xy + xG(y) + yG(x) + G(x)G(y)
indicates that G(xy) = xG(y) + yG(x) + G(x)G(y) and when y = 1
G(x) = xG(1) + G(x) + G(x)G(1) from which we get
0 = xG(1) + G(x)G(1) = G(1)[x + G(x)] = G(1)F(x).
So either G(1) = 0 or F(x) = 0 for all x.
If F(x) is not identically 0 then G(1) = 0 and since F(0) = 0 then G(0) = 0.
If it could be shown that G(x) is either 0 or -F(x) then we'd be in business.
Additioinally for [tex]x \geq 0, F(x) = F(\sqrt{x} \cdot \sqrt{x}) = F(\sqrt{x})^2 \geq 0.[/tex]
So F(x) is nonnegative to the right of 0 and by radial symmetry nonpositive to the left of zero.
I'm not sure how to leverage this to a solution but I feel it's nearby but eluding me. I'm not even sure if any of this is relevant.
--Elucidus
Caesar_Rahil said:
F(0)=0
F(1)=1 or F(1)=0
also F(2x)=2F(x)
Put x=1;
F(2)=2 or F(2)=0
= constant
Put x=0,1;
I explored this approach as well, but F is not known to be differentiable (let alone continuous).
Secondly
[tex]\lim_{h \rightarrow 0} \frac{F(h)}{h} \text{ is not necessarily a constant.}[/tex]
--Elucidus
Try to start off by showing for any rational number of the form p/q (p,q integers), F(p/q*x) = p/qF(x). Then if F(1)=c, we have that F(p/q) = cp/q for any rational number. Verify what F(1) can be.
At that point you either assume F is continuous, or you make a very savvy argument (which eludes me to this point) to include the irrational numbers
--Elucidus
It's eluding me too. I think I actually looked at this before. By using my usual recourse when a problem is way too tough for me. I hunted through the sci.math forums. I THINK i found an entry by one of the brainiacs there that there ARE such functions which are not 0 or the identity. But they have to be constructed by axiom of choice type arguments and you really can't find a concise example of one accessible to a finite brain. That's just a vague recollection, so I could be wrong. But I think the OP might be omitting a condition on the function F that might make this a lot easier.
Consider [itex]F(\frac{p}{q} \cdot x)[/itex] when x = q (p, q integers). This shows that either [itex]F(x) \equiv 0 \text{ or } F(\frac{p}{q}) = \frac{p}{q}[/itex] (why?).
So F is either identically 0 or the identity on the rationals and if F is known to be contunuous, then F must either be identically 0 or the identiy on R.
The condition of continuity I believe is necessary to prove the claim. As Dick mentioned, I vaguely recollect that there are bizarre discontinuous functions that satisfy the premises that are neither identically 0 nor the identity.
--Elucidus
EDIT: The first sentence should say [itex]F(1) = 0 \text{ not }F(x) \equiv 0[/itex].
By the linearity and multiplicity condition, once you've prove F is the identity on the rationals (assuming it's non-zero, since that case is trivial), you can basically extend it to any algebraic number - F(solution to p(x)) must be a solution to p(x). The transcendentals are a bit more of a mystery.
There's a LOT more transcendentals than there are algebraic numbers, aren't there? Wish I could find a reference on this.
I've managed to prove that if F(1) = 0 then F is periodic with period 1 and is therefore F identically 0.
I also have that if F(1) is not 0 then F(x) = x for all rationals. But I haven't made the final jump to all real numbers yet (it may not be possible).
--Elucidus
--Elucidus
If F(1)=0 then F(x)=F(1*x)=F(1)*F(x)=0*F(x)=0. Why do you need periodic?
Using the properties given, F(1) non-zero means F(1)=1 and from that you can prove all algebraic numbers are mapped to themselves. I'm almost 100% sure you can't glean anything from the transcendentals this way, because all you can do is form rational polynomials with addition and multiplication, and the algebraic numbers are exactly those that you can find as roots to rational polynomials.
New idea: Suppose F(pi) = c. What other values of x have we determined F(x) for? Obviously any rational multiple of pi, and any linear combination of integral powers of pi. I think that's it. So you can probably choose a basis of R over Q (here's the axiom of choice), make an equivalence relation based on which guys are multiples of each other, and then on the set of equivalence classes define F to be whatever the hell you want by defining F(basis vector)
Because I was missing the obvious looking too deeply at a trivial case. :redface:
--Elucidus
I believe this is how those whacked out discontinuous extensions alluded to earlier are made.
--Elucidus
--Elucidus
Nice to know smart people have been looking at this and haven't found some obvious proof I've been completely blind to.
Oh bah, I should have been following this thread. :frown:
Elucidus said:
Additioinally for [tex]x \geq 0, F(x) \geq 0.[/tex]
Okay, so you've proven F maps positive numbers to positive numbers.
Since you can say something about positive numbers, doesn't that suggest you can you say something about the ordering of the real numbers?
Ooops. Guess I had a false recollection. Thanks for getting this thread on the right track again.
Sheesh. I've been so wrapped up in looking for a simple proof by contradiction that I completely missed monotonicity. This was that last piece I needed to complete the proof.
--Elucidus
It has been proven that F(0)=0 and F(1)=1 or 0
put x=-y;
F(x)+F(-x)=0
so F(x) is odd
BELOW PROOF WORKS ONLY IF X IS RATIONAL:
now, if x is Natural number
F(x)
=F(1+1+1+... x times)=F(1)+F(1)+...x times
=x F(1)
=x or 0
since F(x) is odd; so is true for all negatives natural numbers
let x=p/q
p and q are integers
F(p)
=F(p/q*q)
=F(p/q)+F(p/q)+...q times
=q * F(p/q)
F(p/q) = F(p)/q
F(p/q)=p/q or 0
so F(x) = x or 0
I am trying for irrationals
That's because it's a sneaky problem! If you know the pattern of generating counterexamples in similar situations, then it's just so utterly obvious that it works here. It just happens to be utterly false. :frown:
Spivak gives the following approach for the problem:
1) Prove f(1) = 1
2) Prove f(x) = x for rational x
3) Prove f(x) > 0 if x > 0
4) Prove if x > y then f(x) > f(y)
5) Prove f(x) = x for irrational x (Use the fact that the rationals are dense on R)
The question isn't insanely hard if you follow the above procedure.
1) Prove f(1) = 1
Yeah. I knew I needed (5) but blew it on (4). Monotonicity was staring at me, taunting me. I went and looked back at my scratch work and right there on page 2 is
[tex]u \leq v \Rightarrow f(u) \leq f(v)[/tex]
I will mention though that (1) and (2) should be
1) Prove that f(1) = 0 or 1.
2) Prove that if f(1) = 0 then f(x) = 0 for all x, and
that if f(1) = 1 then f(x) = x for all rational x.
--Elucidus
  • · Replies 20 ·
  • · Replies 17 ·
