Creating Reticles or Graticules: A Simple Process/Setup
  • Thread starter Thread starter vinoodd
The discussion revolves around the methods for creating reticles or graticules, focusing on processes such as photolithography and etching techniques. Participants explore various approaches, safety concerns, and the technical details of these methods.
  • Some participants suggest using photolithography followed by HF etching for creating reticles.
  • Concerns are raised about the precision of HF etching, particularly regarding the ability to achieve 10-micron lines.
  • Questions are posed about the feasibility of using a photographic solution on glass and a contact printing process to replicate images.
  • Safety issues related to HF are discussed, including the dangers of handling the chemical and the necessary protective measures.
  • Participants share experiences with HF, noting its hazardous properties and the importance of proper safety equipment.
  • Different types of photoresists are mentioned, with some participants discussing their effectiveness against HF etching.
  • There is a mention of using tougher epoxy resists for applications involving higher concentrations of HF.
Participants express varying opinions on the effectiveness and safety of HF etching, with no consensus on the best method for creating reticles. The discussion includes both support for and skepticism about the proposed techniques.
Participants highlight limitations regarding the precision of etching processes and the potential risks associated with using HF, but do not resolve these concerns.
vinoodd
Hello everybody,
I am in search of a simple process/setup with which we can make Reticles or Graticules.
Can anybody guide me Please...
Chemistry news on Phys.org
Photolithography followed by HF etch.
Dear chemisttree,
Thanxs for the reply.
However, can u pleasez explain the process in details? I really doubt whether HF etching is used in this process coz we see perfect 10 microns line in the reticle., and i don't think its possible to etch using HF that much perfectly.
Also, is there any way that we can coat a photographic solution (similar to the photographic film used in camera) in clear glass and expose it with a negative master - contact printing process, and process it like we do it with camera films and get an exact copy of the image?
vinoodd said:
Dear chemisttree,
But http://en.wikipedia.org/wiki/Etching_(microfabrication)#Wet_etching"
That is called http://en.wikipedia.org/wiki/Photolithography"
When you say HF, are you guys talking about http://www.glassetchingsecrets.com/acid.html" acid? That stuff is nasty. I have worked with this before and its quite dangerous.
Hi sciler, welcome to PF. They are indeed! I used to use 49% HF frequently in microfabrication work. I always used a fume hood, face mask, apron, sleeve covers, and two sets of gloves, and I had a tube of calcium gluconate taped to the hood. It is a very dangerous material to work with without the proper protective equipment.
Mapes, sorry if this sounds dumb. But what does the calcium gluconate do? I take it, its some kind of neutralizer or filter. Just a guess, please let me know.
In case you spill HF on yourself, calcium gluconate provides a calcium source for the voracious fluoride ions that's not your tissue.
Ok that's what I kind of figured. Thank you so much for giving me this information. I really appreciate it.
Just to reinforce - HF is one of the nastiest chemicals that isn't actually a weapon.
It's not just the acidity, it has some very nasty chemical properties, one of which is that it doesn't actually hurt when you spill it on you - supposedly it can burn through your hand before you notice.
My wife is a chemist and this is the one substance she is scared of.
Hafnium is not exactly weaapon but, it is metal which is used in making control rods in nuclear reactors and nuclear submarines which is excellent at absorbing neutrons and it has very high melting point.
Thanks!
And HF is not exactly a hafnium.
You know, HF is different from Hf, we don't use these capital letters without reason.
methods
mgb_phys, I have heard that too. Thats crazy how it can penetrate the skin to the insides and eat at the bone. I am with your wife, I am scared of it already also. I think I'll just stay away from it lol. Thanks for the info.
HF is freaking scary. I've heard tell that Calcium Gluconate isn't a complete protection and that if you do spill some on you:
1) apply the gluconate
2) CALL AN AMBULANCE
That said, a lecturer of mine told me he improperly disposed of a lot down a drain, and got fumed badly. He's still walking
I'm sure HF can make some nasty burns but to get all the way through your hand you would need to keep poring, a lot of it... and for some time, it's not that fast as the reactions aren't that fast. I'ts nasty as it kinda burns through many anorganics.
I've worked in photoetching for a short time, and honestly I've found lots more about it from wikipedia.
We etched metal films of up to 0.1mm with 0.1mm holes, lines any shapes. It's easy to do at home with nail polish but the precision drops by a mile.
Really, what kind resist did you use for photoetching with this acid?
Most standard microfabrication photoresists (e.g., AZ line, OCG825, novolac resin based) can handle dilute HF with no problems. With 49% HF, resist attack is a real problem. Tougher epoxy resists like SU-8 are sometimes used here.
Never worked with HF as it was metal film that we processed. It would have dissolved the titanium frame of the installation anyway :P .
