Deriving the Bernoulli EquationFluids
4 replies · 5K views · last reply
Saladsamurai
I am trying to follow along with the text's derivation of the Bernoulli equation and I am a little confused with a particular line. The images show an elemental streamtube control volume (CV) of variable area A(s) and length ds.
We assume that though the properties may change with time and position 's' they remain uniform over the cross section 'A.'
So treating as a 1-dimensional inlet/outlet CV we can write conservation of mass as:
[tex]\frac{d}{d\,t}(\int_{CV}\rho d\,V) +\dot{m}_{out} - \dot{m}_{in} = 0 \approx \frac{\partial{\rho}}{\partial{t}}d\,V + d\,\dot{m}[/tex]
Okay. I am missing somethings here:
(1) I am assuming that they set [itex]\dot{m}_{in} =\dot{m}[/itex]
and
[itex]\dot{m}_{out} =\dot{m} + d\,\dot{m}[/itex]
so
[itex]\dot{m}_{out} - \dot{m}_{in} =d\,\dot{m}[/itex].
Does that sound right?
(2) So the thing that is really bothering me is this. Where did the integral go? AND why did [itex]d/d\,t[/itex] turn into [itex]\partial/\partial{t}[/itex]
I keep getting jammed up on these total derivatives turning into partials. What does it all mean?
thanks :smile:
Two diagrams of a streamtube control volume: (a) a tapered tube with inlet area A and outlet area A + dA, showing density, velocity, pressure, shear stress, weight dW and a slant length ds with height dz; (b) pressure dp acting on the tube surfaces with resultant force dFs.
I have made another assumption that seems to explain where the integral went:
Since the control volume is of differential size, then upon integration we simply end up with 'dV.'
But I don't really like that. I can't seem to work out the math of it...maybe that's not right at all. I am just grasping at straws here...
Any thoughts on this one? Or is Bernoulli like so 1986 or something...
It's a bit messy, saladsamurai, I will cough up my old notes and see if I can make a good post explaining this, on Reynolds' transport theorem and such.
There is something strange about how they have set this up, so I need some time to think about it.
Okay! I understand the RTT just fine.
The left hand side of
[tex] \frac{d}{d\,t}(\int_{CV}\rho d\,V) +\dot{m}_{out} - \dot{m}_{in} = 0 \approx \frac{\partial{\rho}}{\partial{t}}d\,V + d\,\dot{m}[/tex]
is the RTT with mass as its 'dummy variable.'
It's whatever 'tricks' (simplifying assumptions) they are using to get the right hand side that are getting me jammed up.
Thanks for looking :smile:
