Calculating Total I2R Losses in a Conductor with Both AC and DC Currents
The discussion centers on calculating total I²R losses in a conductor carrying both AC and DC currents, specifically addressing the impact of skin effect on resistance and power loss. Participants explore various methods for combining the effects of AC and DC currents in their calculations.
  • One participant proposes two methods for calculating total power loss: treating AC and DC currents as independent or accounting for skin effect impacting both currents.
  • Another participant believes the effects are independent, noting that the heating of the wire is the only interaction observed.
  • A different participant asserts that only the AC current flows in the skin depth, suggesting that the first method yielding 1.07 watts is correct.
  • One participant references a source discussing skin effect in transformers and raises questions about deriving equations for arbitrary waveforms.
  • Another participant mentions that for simple wire, a breakdown of currents by frequency is sufficient, but acknowledges complexities in transformer design.
  • Further discussion includes a request for references regarding frequency independence, particularly at zero frequency, and mentions solving equations related to Maxwell's equations.
  • One participant shares a rule of thumb for calculating skin depth in copper wire using Bessel functions.
Participants express differing views on how to combine the effects of AC and DC currents, with no consensus reached on the correct method for calculating total I²R losses.
Participants note the complexity of the problem, including the influence of frequency and the skin effect, as well as the potential for increased losses in transformer design due to magnetic flux. There are unresolved mathematical steps and dependencies on definitions related to skin effect and current density.
This discussion may be useful for electrical engineers, physicists, and students interested in power loss calculations in conductors, particularly those dealing with AC and DC currents and skin effect phenomena.
Phrak
References are available to calculate skin effect, RAC/RDC given wire gauge and frequency. But my problem is a complication of this simple calculation.
Say I have a 1 Amp RMS AC current component and a selected wire size that gives me a skin effect of 7X the DC resistance. But I also have a hefty 10 Amp DC current component.
I'm interested in calculating the total I2R losses due to both the AC and DC currents.
How are these two combined?? For the sake or argument, the DC resistance of the wire is 0.01 Ohms.
1) I can treat them as separate and independent currents and get a small power loss:
P = 0.01 Ohms * 102 Amps2 + 0.07 Ohms * 12 Amps2 = 1.07 Watts.
Or 2) I can imagine that the 7X skin effect also impedes the DC current flow.
P = 0.07 Ohms * 102 Amps2 + 0.07 Ohms * 12 Amps2 = 7.07 Watts.
The results are wildly different between the two.
Which method--or a third method, is correct to first order? I mean, never mind the finer details. I just want to know what my power loss is to +/-20%.
I believe they are independent effects. Except for the fact that each effect heats up the wire, which increases its resistance some. That is the only interaction that I see.
The 1.07 watts is correct. Only the ac current flows in the "skin depth" on the outer surface of the conductor. If you go to stranded wire of the same gauge, the total skin depth resistance is less.
Bob S
This http://www.dartmouth.edu/~sullivan/litzwire/skin.html" is the only semi-useful link I've found on skin effect.
Its intent is to examine skin effect in transformers where wires are subjected to the magnetic influence of their neighbors, it’s pretty thick reading.
Given, without proof or motivation, is the resistive power loss due to non-sinusoidal waveforms as the Fourier sum of the power losses due to each sine wave independently.
P = RDC Σj I2j Frj)
Supposedly, this includes DC.
I could over-analyze this problem to death and include the influences of other neighboring wires 'n everything, or get back to finishing the project. But I do like overanalyzing. :)
Is it too difficult to derive the equation for skin effect of an arbitrary waveform, where at any given moment, the radial force due to a radial distribution of charge cancels the radial force due to the time-rate-change of magnetic field due to longitudinal current?
Hey Phrak,
I had to do this one in college. For the simple wire, a breakdown of the currents by frequency is sufficient.
When designing transformers / inductors, flux at gaps can increase the loss by cutting across the copper, but this is usually neglected unless you have a very large gap, and when this is a problem, I've never seen a definitive way to compute the loss.
- Mike
Mike_In_Plano said:
Hey Phrak,
- Mike
Thanks Mike. Do you have a reference source for the frequency independence that specifically includes f=0?
Secondly, after taking a short look at the simpler problem for a single frequency and single wire, I have to solve some sort of Bernoulli equation using about 3 or 4 out of 4 of Maxwell's equations that are both time and radially variant: Jz(r,t), Er(r,t), Ez(r,t) and Bphi(r,t). Does this sound familiar?
In Smythe "Static and Dynamic Electricity" third edition on pages 372-4 the equations for the ac current density vs. radius in a solid cylindrical conductor are written out using modified Bessel functions of order zero with complex arguments. He gives the effective ac skin effect resistance vs. frequency on page 373.
Bob S.
Electrical Engineer rule of thumb Bessel function for copper (wire)
skindepth in mm = 260 / [tex]\sqrt{f}[/tex] (in cycles per second)
Bob S.
Doh! Of course I meant Bessel rather than Bernolli.
...I finally found some cheats here http://home.swipnet.se/swi/bessel/bessel.html#Basic_theory" but he does kind of jump into the middle of it, unexpectedly beginning with the electric field wave equation in a conductive medium, that I'm not familiar with.
51K
