How Do You Solve These Trigonometric Equations for Relative Motion?
  • Thread starter weedannycool
6 replies · 2K views · last reply
weedannycool
i have 2 equations:
400cos [tex]\vartheta[/tex]a = 300 + Vacos45
and
400sin [tex]\vartheta[/tex]a = Vasin45
i have no clue, maybe square it.
thanks
Hi weedannycool! :wink:
weedannycool said:
… maybe square it.
Yes, of course …
what do you get? :smile:​
Also, you should replace cos45 and sin45 by sqrt(2)/2. I'm assuming the angles are in degrees.
One other thing. Instead of starting a new thread for essentially the same (but corrected) problem, you should continue the old thread, putting in the corrected set of equations.
right so i have the to equations squared. not positive with what i should to next though. is there a method for solving these.
thanks for the help so far
Mark44's approach replacing sin45 and cos45 with sqrt(2)/2 seems the most straight forward approach. You have 2 equations with 2 unknowns, theta-a and Va. The expression with Va*sqrt(2)/2 in the second equation can be substituted into the first equation. You are left with one equation with one unknown, theta-a. Trial and error to find theta-a. Plug theta-a into either equation to find Va. Theta-a will be in degrees, Va won't be.
