Math Substitution for Solving Equations | Attached Picture Included
  • Thread starter Thread starter COCoNuT
    Substitution
The discussion focuses on the mathematical substitution method for solving integrals involving trigonometric functions, specifically using the substitution \(2x = \sec \theta\). Participants clarify the relationship between secant and tangent functions, leading to the simplification of integrals such as \(\int \frac{x^3}{\tan \theta} d\theta\). The correct derivative for \(dx\) is established as \(\frac{\sec \theta \tan \theta d\theta}{2}\), and the integral ultimately simplifies to \(\frac{1}{16} \int \sec^4 \theta d\theta\). The conversation concludes with a detailed explanation of how to derive values for a triangle based on the substitution, aiding in the final solution.
  • Understanding of trigonometric functions: secant and tangent
  • Familiarity with integral calculus and substitution methods
  • Knowledge of derivatives and their application in integration
  • Ability to interpret and manipulate mathematical notation
  • Study the properties and applications of trigonometric identities, particularly \( \sec^2 \theta \) and \( \tan^2 \theta \)
  • Learn advanced integration techniques, including integration by parts and trigonometric substitution
  • Explore the use of LaTeX for clearer mathematical notation in discussions and presentations
  • Practice solving integrals involving trigonometric functions to reinforce understanding of substitution methods
Students and educators in calculus, particularly those focusing on integration techniques, as well as anyone seeking to enhance their understanding of trigonometric substitutions in mathematical problems.
COCoNuT
the problem is shown in the picture i attached.
wouldnt i use u = 2sec(\theta) as a sub?
Well, not "u= 2 sec θ" because there was no "u" in the integral!
But setting 2x= secθ will work very nicely (Notice where the 2 is!)
sin2θ+ cos2θ= 1 so, dividing both sides by cos2θ, tan2θ+ 1= sec2θ and then
sec2θ- 1= tan2θ.
That's the whole point of the substitution. If 2x= sec θ then 4x2 =
sec2 θ so 4x2- 1= tan2θ and you can drop the square root: \sqrt{4x^2-1}= \sqrt{tan^2\theta}= tan \theta.
(You might have been thinking of examples involving "x2- 4" where the substitution x= 2sec θ would give 4sec2- 4= 4(tan2 θ)
ok so the problem should look like \int \frac{x^3}{tan \theta} right now.
i don't know what to do next. i can't use u-du. can i use parts on this?
if you set 2x= sec \theta
then x= \frac{sec \theta}{2}
then would i have to take the derv. of that?
dx= 1/2*ln(sec(\theta)+tan(\theta))
then we would rewrite the problem as...(plugged in x=\frac{sec \theta}{2} for x)
\int\frac{(\frac{sec \theta}{2})^3}{\sqrt{4(\frac{sec \theta}{2})^2-1}} * 1/2*ln(sec(\theta)+tan(\theta))
hmm my way seems longer and harder...
can you help me with your way?
I'm not familiar with the notation "sec", but from what HallsofIvy wrote, I take it that sec θ is just 1/cos θ.
When I use this, and calculate dx=dx/dθ dθ, the integral simplifies to
\frac{1}{16}\int\frac{1}{cos^4\theta}d\theta
I don't know how to solve that, but maybe you do.
The thing that you're doing wrong is the derivative. There shouldn't be any logarithms in there.
Let's review what you got
2x = \sec\theta
\sqrt{4x^2-1}= tan\theta
dx = \frac{sec\theta tan\theta d\theta}{2}
so you will have:
\int \frac{(\frac{sec\theta}{2})^3}{tan\theta}\frac{sec\theta tan\theta d\theta}{2}
and working the terms:
\frac{1}{16} \int sec^4\theta d\theta
\frac{1}{16} \int sec^2\theta (1+tan^2\theta) d\theta
\frac{1}{16} \int sec^2\theta d\theta + sec^2\theta tan^2\theta d\theta
\frac{1}{16} [\int sec^2\theta d\theta + \int sec^2\theta tan^2\theta d\theta]
and you can finish it yourself, i believe...
use the fact that 1 + tan² = 1/cos² and write the integrandum as
(1/cos²(x) * 1/cos²(x))dx.
Then you also know that d(tan(x)) = dx/cos²(x)
So you get as integrandum 1/cos²(x)*d(tan(x)) and substitute the cos² by the above expression.
regards
marlon (sorry for the writing, i really should start using LaTex)
2x = \sec\theta
so you will have:
\frac{1}{16} [\int sec^2\theta d\theta + \frac{1}{16}\int sec^2\theta tan^2\theta d\theta]
my work:
found the anti-derv.
\frac{1}{16}(tan \theta) + \frac{1}{16}(sec \theta)^2
ok now this is the part I am confused on... i know i need to draw a triangle and do something with it...
triangle is attached, but nothing is filled in. i took notes, but i don't know what to fill the values for the triangle.
im thinking that the values are...
a(Adjacent) = x^3
h = 1/2
O = \sqrt{(4x^2-1)}
how do you know what the a,h, and o sides are? i just looked at my notes and copied how it worked(i should take better notes).
ok now that i filled in the triangle, now to sub it back for \theta
will turn to...
\frac{1}{16}(\frac{\sqrt{(4x^2-1)}}{x^3}) + \frac{1}{16}(\frac{x^3}{2})^2
and that is my answer, is the correct?
The second integral should have solution tan³(x)/3, i think you made a mistake there.
[\int sec^2\theta tan^2\theta d\theta]
is equal to tan³(theta)/3
regards
marlon
regards
marlon
i don't see how you got that, i did the problem agian and got the same answer
Marlon is right, your first integral is correct but not your second.
Let's work out the second integral with substitution..
u=tan\theta
du=sec^2\theta d\theta
so we will have:
\int u^2 du
Integrating:
\frac{u^3}{3} + C
Substituting back:
\frac{tan^3\theta}{3} + C
your result should be:
\frac{tan\theta}{16} + \frac{tan^3\theta}{48} + C
Now to change it back:
Look at what we had above:
so
\frac{\sqrt{4x^2-1}}{16} + \frac{(\sqrt{4x^2-1})^3}{48} + C
I just noticed this is a definite integral... oh well just apply the theorem :smile:
and forget about the constant.
sorry, you guys are right...
well anyway, with the correct results...
time to sub in theta...
\frac{\frac{\sqrt{(4x^2-1)}}{x^3}}{16} + (\frac{\frac{\sqrt{(4x^2-1)}}{x^3})^3}{48} + C
is that right? i drew a triangle and everything in my eariler post
Cyclovenom got a answer of \frac{\sqrt{4x^2-1}}{16} + \frac{(\sqrt{4x^2-1})^3}{48} + C
but i still have the x^3 in mines, what am i doing wrong? tan is o/a right? so i just subbed it in
On your triangle you should have on:
Hypotenuse: 2x
Opposite: \sqrt{4x^2-1}
Adjacent:1
Hypotenuse: 2x
Adjacent:1
sorry to keep on bothering you guys, but how did you get those values?
Well, you started with 2x = sec\theta so if you read above HallsofIvy post on how to get a value that will work for the \sqrt{4x^2-1} which will be tan\theta. You can build a Triangle with that info.
You know sec\theta = \frac{Hypotenuse}{Adjacent} and you got
tan\theta = \frac{opposite}{adjacent}
so \frac{2x}{1} = \frac{Hypotenuse}{Adjacent} and \frac{\sqrt{4x^2-1}}{1} = \frac{opposite}{adjacent}
Also:
\frac{1}{cos\theta} = 2x
cos\theta = \frac{1}{2x}
and:
\frac{\sqrt{4x^2-1}}{1} = \frac{sin\theta}{cos\theta}
\frac{\sqrt{4x^2-1}}{1}\frac{1}{2x} = \frac{sin\theta}{cos\theta}cos\theta
sin\theta = \frac{\sqrt{4x^2-1}}{2x}
\frac{Opposite}{Hypotenuse} = \frac{\sqrt{4x^2-1}}{2x}
Do you see it?
yea! thank you, i get it.
sec2θ- 1= tan2θ.
lol, i just figured out what you tried to tell me, I am a bit slow. wow, that helped a lot. my teacher goes really fast, and doesn't explain the little details and the book is just weird. i already solved 6 problems on my own(14 more to go) and got them all right. thank you agian, i love this forum
Well, I'm glad i was of help :smile:
Keep solving problems! :cool:
and feel free to ask for help anytime as long as you will learn from it.
  • · Replies 32 ·
