Is \( f(x,y) = \sqrt{|xy|} \) Differentiable at \( (0,0) \)?
2 replies · 3K views
Buri
Here's the problem:
Let f(x,y) = sqrt(|xy|) if x >= 0 OR -sqrt(|xy|) if x < 0. Show that all directional derivatives in the direction of h exist, but f is not differentiable at (0,0).
Here's what I've done:
Basically all I need to show is the directional derivative is not linear. Since if the differential exists then df_(0,0)(v) = D_v f(0,0), but the directional derivative will turn out to be not linear and hence it would contradict a result I have.
So I have that for h = (h1,h2) that the following exists:
lim [t->0] (1/t)[f((0,0) + t(h1,h2)) - f(0,0)]
= lim [t->0] (1/t)sqrt(|t²h1h2|)
But here's where I end up getting:
lim [t->0] [|t|sqrt(|h1h2|)]/t
The above is for th1 > 0. But this limit doesn't exist as when I take it from the left and then right I end up with the same expression but with a negative in front of one of them :S Can anyone help me out on this?
Thanks!
Suppose we take the derivative in a direction with angle [itex]\theta[/itex] to the x-axis and let [itex]m= tan(\theta)[/itex]. Then your (h1, h2) can be written (h, mh). Now we have [itex]f(h, mh)- f(0, 0)= \sqrt{mh^2}= \sqrt{m}|h|[/itex] for h positive and [itex]-\sqrt{m}|h|[/itex] for h negative. Of course, if h> 0 then |h|/h= 1 and if h< 0, |h|/h= -1 so we have [itex](f(h, mh)- f(0,0))/h= \sqrt{m}[/itex] in either case. Since that is a constant, its limit, as h goes to 0, is just that same constant, [itex]\sqrt{m}[/itex]. That shows that the directional derivative exists.
A function, f(x, y) is "differentiable" at (0, 0) if and only if
[tex]f(x,y)= f(0, 0)+ \frac{\partial f}{\partial x}(0, 0)x+ \frac{\partial f}{\partial y}(0, 0)y+ \epsilon(x,y)[/tex]
where
[tex]\lim_{(x,y)\to 0}\frac{\epsilon(x,y)}{\sqrt{x^2+ y^2}}= 0[/tex].
Here, it is easy to see that the partial derivatives as both 0 at (0, 0) so we must have [itex]\epsilon(x,y)= f(x,y)[/itex].
But then why is it that you don't take the limit as h goes from the right and then from the left of this one? To see if the right/left handed side limits exist?
Wait I guess the one h > 0 and the other for h < 0 are basically the right and left handed sided limits already? I guess I shouldn't have to "divide" them again.
And another question. I honestly don't understand anything of the rest since I have no idea what partial derivatives are yet. We've only covered the direction derivative and the the 'normal' derivative. But is my idea on how to finish the question okay? D_h f((0,0)) is non-linear, so the differential at h won't be able to equal D_h f(0,0) since the differential is supposed to be linear.
Thanks for your help.
