Basic Hydrogen/gravity/thermodynamics question from a noob.
  • Context: Undergrad
  • Thread starter Thread starter willdo
    Noob
The discussion revolves around the theoretical feasibility of using gravitational energy to electrolyze hydrogen for lifting weights. Participants explore concepts related to energy conservation, gravitational potential energy, and the efficiency of electrolysis, while considering various scenarios and assumptions.
  • One participant questions the altitude needed for a weight to drop in order to generate sufficient energy for hydrogen electrolysis.
  • Another participant asserts that conservation of energy indicates this is impossible, as differing elevations do not change the energy balance.
  • A participant discusses the bond energy of hydrogen compared to its gravitational potential energy, suggesting that lifting it higher does not yield enough energy for electrolysis.
  • Some participants note that the energy produced from dropping a weight varies with height, referencing hydroelectricity as an analogy.
  • There are claims that the energy required to lift a weight must be considered, as it offsets any energy gained from dropping it.
  • One participant suggests that if a weight could be lifted to a significant height, it might be possible to harness energy multiple times, although others challenge this idea.
  • Concerns are raised about the practicality of electrolysis at different altitudes and the energy requirements involved.
  • Some participants discuss the implications of terminal velocity and the potential for harnessing energy during a fall, proposing a multi-stage approach to energy extraction.
  • Others argue that the energy needed to lift the weight negates the energy gained from its drop, emphasizing the need for buoyancy in the atmosphere.
  • There are discussions about the limitations of using a more massive planet for this scenario, as increased gravity complicates the electrolysis process.
Participants express a range of views, with no consensus on the feasibility of the proposed energy harnessing method. Some agree on the principles of energy conservation, while others explore hypothetical scenarios that challenge these principles.
Participants mention various assumptions, such as neglecting friction and the effects of atmospheric pressure on electrolysis. The discussion also highlights the complexity of energy conversion and the limitations of current understanding regarding gravitational energy and electrolysis.
willdo
What altitude should a weight drop from to produce enough energy to electrolyse the hydrogen needed to lift it? Please keep it simple, i just want to know if it would work in theory.
Science news on Phys.org
Conservation of energy tells us this can't be done at all. Differing elevations doesn't change anything.
the simplest example would be to consider the energy it takes to break apart a single hydrogen molecule, its bond energy, and compare it to the energy it takes to lift the molecule a certain height off of the earth.
It turns out that the bond energy (about 724 zeptojoules) is actually larger than its total gravitational potential energy (about 209 zeptojoules), so even if you lifted it arbitrarily high above the earth, it would not gain more kinetic energy than its bond energy.
The bond energy of [itex]H_{2}[/itex], I looked up.
The gravitational potential energy I calculated from Newton's law of gravity
[itex]|U|= G\frac{M_{H_{2}}M_{E}}{R_{E}}[/itex]
It would be a different story if you were lifting it off of a more massive or more dense body, but Earth just isn't massive enough in this case.
Hope this helps:)
Ok, i just read the basics of "conservation of energy" yet, wether i drop a weight from 1 metre or 10 metres the energy produced is not the same.I am not knowledgeable enough to explain it but in Hydroelectricity the height of the waterfall matters very much...So, does it mean that the weight speeds up over a certain distance and then stops accelerating at some point? In which case, How can i figure that distance?
Edit:sorry jfizzix, we were writing at the same time...somehow this makes sense...
Edit2: Ok, i thought about it again and...what's stopping me from harnessing the energy produced more than once? (in theory of course i know it would be impractical)
example: if a weight attains it's maximum level of kinetic energy after 1000 metres (a wild guess, i have no clue what the real number would be like) and you carry this weight to 30000 metres, then you could harness the kinetic energy 30 times...no?
This is not correct, work is done by the atmosphere raising the weight attached to the hydrogen balloon.
Unfortunately electrolysis of water requires huge amounts of energy - to get a cubic metre of hydrogen needs 11.67MJ even at 100% efficiency.
Now 1m3 of hydrogen should lift about 1kg. A 1kg mass at 50km up (about as high as a balloon will go) has about 0.5MJ of potential energy.
So even if we could convert all of the potential energy to electricity, and all of the electrical energy to extracting hydrogen we would still not have enough by a factor of more than 20x.
You need a more massive planet.
The maximum kinetic energy is achieved by dropping the weight from infinity... so you only get to do it once.
Yes but if you could this would be plenty enough energy - escape velocity is 11.2km/s which would give 1kg 188MJ. The problem is that you can only use the Earth's atmosphere to power the ascent to the limits of the Earth's atmosphere, not infinity.
This is not possible even on a hypothetical massive planet. If you increase the gravity, you increase the pressure which will make it more difficult to electrolyze water.
Right, and the difference is a factor of 10 in energy.
The basic question is: how do you get your mass to that height? Lifting it by 10m needs also ten times the energy needed to lift it by 1 meter.
It is pointless, as you will need the same energy to lift it before you can drop it again.
I must say, this is great, this question has bothered me for a while, thank you all for making it easy to understand!
Just to make sure, how would that change if we started in water, say 10km deep? (assuming no engineering issue)
exemple: if a weight attains it's maximum level of kinetic energy after 1000 metres (a wild guess, i have no clue what the real number would be like) and you carry this weight to 30000 metres, then you could harness the kinetic energy 30 times...no?
T 02:52 PM
My idea was in the exemple, since the hydrogen keeps going up, there wouldn't be any need to get "back up". i since understood that it would be pointless regardless since the energy produced would be vastly insufficient unless i could reach some 1200km and there just isn't that much atmoshere to go
You are missing the point mfb, the energy to raise the weight is provided by the buoyant force of the atmosphere.
The following is a quote from wikipédia:
Based on wind resistance, for example, the terminal velocity of a skydiver in a belly-to-earth (i.e., face down) free-fall position is about 195 km/h (122 mph or 54 m/s).[2] This velocity is the asymptotic limiting value of the acceleration process, because the effective forces on the body balance each other more and more closely as the terminal velocity is approached.In this example, a speed of 50% of terminal velocity is reached after only about 3 seconds, while it takes 8 seconds to reach 90%, 15 seconds to reach 99% and so on.[end of quote]
If this is true then there should be reason to break down the harnessing of power into multiple stages (as always, no engineering issue) since every 3s one could harness 50% of terminal velocity 5x50% in 15s rather than 1x99% if we let it go...Basically, keep the acceleration at it's maximum the whole time so as to accumulate as much kinetic energy as possible.
Even for a properly shaped weight, the fall from 50km will last several minutes giving the oportunity to harness the energy many times, wouldn't the total energy harnessed be more important than the sole value of the object dropping without interference?
It does not. There is no such number at all, if you can neglect effects of friction. And friction just makes it worse. The calculations here all assume no friction, the ideal case to extract energy.
Concerning buoyancy: Electrolysis at ground level needs a bit more energy than combustion of hydrogen releases if you do it a high altitude - the difference is exactly the reason why buoyancy exists at all.
I don't think that's right - by far the largest energy requirement for electrolysis is breaking the chemical bond (which is invariant with pressure), not releasing the gas from solution. At what pressure would the latter become significant?
It's true that you would need a much larger planet and/or much thicker atmosphere which would create surface gravity (and pressure) which would not be survivable.
Note of course that I have not taken into account the recovery of chemical energy from the hydrogen by burning it in the upper atmosphere, but I think it is reasonable to assume that at best this would compensate for the inefficiencies within the system.
Isn't that what terminal velocity is? (sorry i just learned the name)
That's funny i wasn't counting it for the same reason (plus i woudn't know how)
Friction will lower the velocity, so you heat up the air a bit and can extract less energy in a useful way.
If you have too much friction, the velocity won't increase any more after a while, and you just waste energy.
Only a bit? We might be on to a winner here then, as long as we can get that combustion energy back down to ground level efficiently (how about spinning the weight that is dropped)?
Yes, but dropping a weight and catching it again at near terminal velocity is a very inefficient way of extracting potential energy. I have all along assumed that a more efficient method would be used, perhaps using an auto-gyro/turbine/flywheel kind of thing.
Ah! Could this be the answer to the following?
So the numbers you proposed earlier (0.5MJ produced from a 50km drop) were taking this into account and keeping the object in a constant accelerating mode?! If so, it's a little disapointing that the production result is so far below "the cost" but at least, it's a clear answer.
Any type of compression would need at least the energy difference you gain in the combustion process.
You cannot win against energy conservation. You cannot even get a draw.
Yes I'm afraid so: 1kg x 9.8ms-2 x 50,000m ≈ 500,000J is the gravitational potential energy of 1kg at 50km altitude so is the maximum you could ever extract from its descent to the Earth at 100% efficiency.
I could see this working on Jupiter perhaps - much larger mass, deeper atmosphere, although the high winds would be a problem (hmmm its decades since I read Larry Niven's The Integral Trees - I can't remember how the alien inhabitants of that planet got their power).
I don't think there is anything being compressed?
Of course not. This system gains energy from the atmosphere; each cycle the buoyant force does ALL the work raising the mass m to height h, inputting ## \frac{GM}{r^2}mh ## of potential energy.
I already said it, but I'll make it more clear. The atmospheric pressure increases as you go down. You can't have buoyancy without atmospheric pressure. Electrolysis of water takes two molecules and splits it up into three, so it increases the pressure. The Gibbs free energy for the reaction increases with pressure, so you need to supply more energy at the bottom. You will spend more energy in electrolysis than you can recover by running a turbine on the hydrogen going up, burning it at the top, and running a water turbine on the way down.
https://en.wikipedia.org/wiki/Gibbs_free_energy
What do you want to spin then, and why?
You cannot gain energy from the atmosphere (apart from wind energy and similar). Neglecting wind, solar heating and so on, the atmosphere is in its lowest energy state. There is no energy you can extract, unless you find a magical vacuum at sea level or a magical source of air in space.
A flywheel to store energy generated by a falling auto-gyro.
But the atmosphere with a hydrogen balloon at ground level is not in its lowest energy state.
Don't worry about energy storage, that is not the issue here.
Right, but you can extract this energy exactly once.
It is not necessary to consider the details. Just consider the initial state (with the hydrogen balloon, if you like) and the final state. The largest difference in potential energies you can get is to let the balloon rise up. Afterwards, there is no way to extract more energy from the atmosphere.
