Energy conversion in a hydroelectric dam
The discussion revolves around the conversion of internal energy of water into electrical energy in a hydroelectric dam, focusing on the mechanisms involved when the turbine is both starting up and running at a steady speed. Participants explore various models and explanations related to gravitational potential energy (GPE), kinetic energy (KE), and the work done against electromagnetic forces.
  • Some participants propose that the energy conversion process can be described as GPE of water converting to KE of water, then to KE of the turbine, and finally to electrical energy, particularly when the turbine is starting up.
  • Others argue that when the turbine is running at a steady speed, the conversion should be viewed as GPE of water being used to perform work against electromagnetic forces, rather than converting to KE of water.
  • A later reply questions the necessity of acceleration for water entering the turbine, suggesting that the power output could remain the same even if modeled differently.
  • Some participants highlight that textbooks may simplify the explanation, potentially leading to misunderstandings about the roles of GPE and KE in the energy conversion process.
  • There is a discussion about the pressure difference across the turbine and its role in driving the turbine blades, with some suggesting that the speed of water through the turbine does not change significantly.
  • One participant mentions that the description of energy conversion in textbooks may be overly simplistic or incorrect, particularly regarding the gain in KE of water or turbine blades.
  • Several participants express uncertainty about the terminology used to describe acceleration and energy transfer in steady-state conditions.
Participants do not reach a consensus on the correct model for energy conversion in hydroelectric dams. Multiple competing views remain regarding the roles of GPE and KE, as well as the implications of steady-state operation versus startup conditions.
Limitations include varying interpretations of energy transfer processes, the dependence on specific definitions of terms like acceleration and work, and the potential for confusion arising from simplified textbook explanations.
This discussion may be useful for students and professionals interested in energy conversion processes, hydroelectric power generation, and the underlying physics of fluid dynamics in engineering applications.
kimau79
(this is the first time I post. hope this is in the correct board)
So I want to know about how the internal energy of water has been converted into electrical energy when the turbine is rotating at a steady speed.
I have read several textbooks and they all give me several answers:
1. GPE of water ==> KE of water ==> KE of turbine ==> electrical energy
2. GPE of water ==> work done again electromagnetic force (force from water pressure) ==> electrical energy
I know that if the turbine is starting up, then answer 1 makes sense, but it does not seem valid when the turbine is rotating steadily (since it not gain KE). answer 2 makes more sense in that case, but I am just not sure whether GPE of water will turn into KE of water before becoming the work done against electromagnetic force.
So which one is correct? thank you
PS. in case the abbreviation is different, GPE refers to gravitational potential energy
Both are correct. The water pressure forces water through the dam's turbines at a certain velocity, performing work on them and producing electrical energy. The whole process converts the gravitational potential energy of the water into electrical energy. Note that for water to enter the damn it MUST be accelerated, turning GPE into KE.
Thanks Drakkith.
Just to clear things up, the energy conversion is
(when turbine starting up) GPE of water ==> KE of water ==> KE of turbine ==> electrical energy
(when turbine running at steady speed) GPE of water ==> KE of water ==> work done against electromagnetic force ==> electrical energy
Am I correct?
Not entirely. Both answers are simply parts of a more detailed answer. It goes like this:
1.Water with certain GPE falls down accelerated by the gravitational field, losing GPE and gaining KE.
2.High-speed water hits the turbine blades, performing work on them. It loses KE and the turbine gains KE(work is the transfer or change of energy in a system).
3.The rotating blades are slowed down by the generator. They perfom work(transfer the KE) on the generator, which gains(produces) electrical energy.
Or,
GPE of water =(work by gravity)=> KE of water =(pressure forces do work on the turbine)=> KE of turbine =(work by EM forces)=> electrical energy
Each of the two original answers skips some details, possibly because the authors thought the omissions to be obvious or unimportant. After all, if you simply wrote:
GPE of water =(some work is done here)=>electrical energy
it'd still be correct, if not entirely informative.
Thanks bandersnatch, that clear things a lot. But still I have a little bit more to ask. This is the complete paragraph from one of the textbooks I read:
textbook said:
The movement of the turbine blades is explained by the pressure difference between the two sides of a turbine - the inlet has an extra pressure due to water, while the outlet is at atmospheric pressure. This pressure difference gives rise to a force which drives the turbine blades. The work done becomes electrical energy.
It is incorrect to say that electrical energy is converted from KE of water in a turbine! In fact, the speed of water through a turbine is unchanged. The correct description is: the GPE of water is mainly used as work done on the turbine when the water pushes the turbine blades. A small amount of the GPE is lost as KE of water. A turbine is not a water wheel which is an old and highly inefficient technology - only water wheel makes use of the KE of water
One of the end-of-chapter exercises also stress again on that the conversion "loss of GPE of water ==> gain in KE of water (or turbine blades) ==> Electric potential energy" is INCORRECT (it should be "Loss in GPE of water ==> work done against friction ==> electric potential energy" according to what they say).
So according to what you mentioned, does the textbook make a mistake here? or just because they are playing with the wording? (they explanation to the answer is that since there is no "gain" in water or turbine blades during the process)
Thanks again.
Drakkith said:
... Note that for water to enter the damn it MUST be accelerated, turning GPE into KE.
Bandersnatch said:
1.Water with certain GPE falls down accelerated by the gravitational field...
I'm not sure I like the wording surrounding "accelerated", when in steady state mode. If one were to model the river as a pipe, with the same diameter as the turbine inlet, I'm pretty sure you'd get the same power output. The fact that water flows faster through the turbines, than the river flows, is just an artifact of the design.
hmmm... That's weird. In my system, the kinetic energy of the fluid doesn't change, until it reaches the turbine blades. So where did this extra energy at the turbine come from?
Elevation head is due to the fluid's weight, the gravitational force acting on a column of fluid.
So there is more energy available at the turbine, simply because there is a column of water sitting above it.
I suppose the horizontal flow of the river becoming more vertical is a change in direction, which implies an acceleration, but not a change in speed, nor mass flow rate.
Thanks again.
I would guess that no one has made any mistakes. It is simply difficult to describe in words, which can only be described mathematically.
P = ρhrgk
I was taking the water as standing still in the lake and being accelerated when it enters the dam.
Ok. That makes sense.
I think there are too many ways to model this problem in ones head. I've gone from hydraulic levers, to stacked bowling balls, to bicycle chains on a frictionless surface, to a tarp collecting rainwater in my back yard.
And now I've got your model in my brain... :mad:
Well, there you go. In my head I was envisioning something closer to a waterwheel design, hence the acceleration of water as it falls.
  • · Replies 31 ·
12K
25K
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 20 ·
