Ordinary Differential Equation - Comparing 2 Solutions
The forum discussion centers on solving the ordinary differential equation (ODE) represented by the equation {g}'(s) + μg(s) = {f}'(-s) + μf(-s). The correct solution is derived using integration techniques and the integrating factor e^{μs}. Two distinct solution approaches are presented, with one yielding the correct result and the other resulting in a sign discrepancy. The final correct expression for g(s) is g(s) = -f(-s) + 2μe^{-μs}∫_{-s}^{∞}f(s')e^{-μs'}ds'. The discussion highlights the importance of careful integration and variable substitution in solving ODEs.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with integration techniques, including integration by parts
  • Knowledge of integrating factors in differential equations
  • Proficiency in variable substitution methods in calculus
  • Study the application of integrating factors in solving linear ODEs
  • Learn advanced integration techniques, particularly integration by parts
  • Explore variable substitution methods in calculus for solving integrals
  • Investigate common pitfalls in solving differential equations and how to avoid them
Students and professionals in mathematics, particularly those studying differential equations, as well as educators seeking to understand common errors in ODE solutions.
AntSC
{g}'\left ( s \right )+\mu g\left ( s \right )={f}'\left ( -s \right )+\mu f\left ( -s \right )
Integrate up to get
g\left ( s \right )=-f\left ( -s \right )+2\mu e^{-\mu s}\int_{-s}^{\infty }e^{-\mu {s}'}f\left ( {s}' \right )d{s}'
As above
I've seen a few attempts at this, one that arrives at the correct solution, which is the method i used and had no trouble with. However, another attempt I've seen, which doesn't yield the correct solution is causing me much headache as i can't work out where it's going wrong. Some pointing out here would be really helpful. Thanks
Using the following integrating factor on the equation above
e^{\int \mu ds}=e^{\mu s}
e^{\mu s}{g}'\left ( s \right )+e^{\mu s}\mu g\left ( s \right )=e^{\mu s}\left [ {f}'\left ( -s \right )+\mu f\left ( -s \right ) \right ]
At this point i wrote
\frac{d}{ds}\left [ e^{\mu s}g\left ( s \right ) \right ]=e^{\mu s}\left [ {f}'\left ( -s \right )+\mu f\left ( -s \right ) \right ]
\left. e^{\mu {s}'}g\left ( {s}' \right ) \right|_{-\infty }^{s}=\int_{-\infty }^{s}e^{\mu {s}'}\left [ {f}'\left ( {-s}' \right )+\mu f\left ( {-s}' \right ) \right ]d{s}'
Then to skip a few steps i did by parts integration to get the following (can include missing steps if needed)
e^{\mu s}g\left ( s \right )=-e^{\mu s}f\left ( -s \right )+ 2\mu \int_{-\infty }^{s}f\left ( {-s}' \right )e^{\mu {s}'}d{s}'
g\left ( s \right )=-f\left ( -s \right )+ 2\mu e^{-\mu s}\int_{-\infty }^{s}f\left ( {-s}' \right )e^{\mu {s}'}d{s}'
Swapping limits and changing 's' for '-s' gives
g\left ( s \right )=-f\left ( -s \right )+ 2\mu e^{-\mu s}\int_{-s}^{\infty }f\left ( {s}' \right )e^{-\mu {s}'}d{s}'
As required
The other route wrote took the following path
\frac{d}{ds}\left [ e^{\mu s}g\left ( s \right ) \right ]e^{-\mu s}=\frac{d}{ds}\left [ f\left ( -s \right )e^{-\mu s} \right ]e^{\mu s}
\frac{d}{ds}\left [ e^{\mu s}g\left ( s \right ) \right ]=-\frac{d}{ds}\left [ f\left ( -s \right )e^{-\mu s} \right ]e^{2\mu s}
\left. e^{\mu {s}'}g\left ( {s}' \right ) \right|_{-\infty }^{s}=\int_{-\infty }^{s}-e^{2\mu {s}'}\frac{d}{ds}\left [ f\left ( {-s}' \right )e^{-\mu {s}'} \right ]d{s}'
e^{\mu s}g\left ( s \right )=\left. -e^{2\mu {s}'}f\left ( {-s}' \right )e^{-\mu {s}'}\right|_{-\infty }^{s}+ \int_{-\infty }^{s}2\mu e^{2\mu s}f\left ( {-s}' \right )e^{-\mu {s}'}d{s}'
e^{\mu s}g\left ( s \right )=-e^{\mu s}f\left ( -s \right )+ 2\mu e^{2\mu s}\int_{-\infty }^{s}f\left ( {-s}' \right )e^{-\mu {s}'}d{s}'
g\left ( s \right )=-f\left ( -s \right )+ 2\mu e^{\mu s}\int_{-\infty }^{s}f\left ( {-s}' \right )e^{-\mu {s}'}d{s}'
g\left ( s \right )=-f\left ( -s \right )+ 2\mu e^{\mu s}\int_{-s}^{\infty }f\left ( {s}' \right )e^{\mu {s}'}d{s}'
This is giving a sign swap in the final solutioin that is having my head spin. Can't see the route of this. Can anyone spot the mistake?
Swapping \int_{-s}^\infty ds' for \int_{-\infty}^s ds' is equivalent to making the substitution u= -s'. Then du= -ds'. When s'= -\infty, u= \infty and when s'= s, u= -s.
So \int_{-s}^\infty f(-s')e^{-\mu s'}ds'= \int_u^{-\infty}f(u)e^{\mu u}(-du)= \int_{-\infty}^u f(u)e^{\mu u}du
