Key Argument for Global Warming Critics Evaporates
The discussion revolves around the validity of satellite and weather balloon data in the context of global warming, particularly in light of recent studies suggesting that previous analyses may have been flawed. Participants explore the implications of these findings for the understanding of atmospheric temperature trends and the broader debate on climate change.
  • Some participants argue that recent studies published in Science indicate that previous conclusions drawn from satellite and weather balloon data about atmospheric cooling were based on faulty analyses.
  • Others contend that while surface thermometers show warming, satellite and weather balloon data suggest a cooling trend in the atmosphere, challenging the interpretation of the new studies.
  • A participant highlights that corrections to lower troposphere temperature trends are marginal and still indicate less warming than surface trends, questioning the narrative of atmospheric cooling.
  • Another participant discusses potential biases in radiosonde data, suggesting that systematic errors may affect the observed temperature trends.
  • Some participants express skepticism about the credibility of sources and the framing of arguments, indicating a concern over the integrity of the discussion.
  • There is mention of a diurnal correction needed for satellite measurements, which could reconcile discrepancies between satellite and surface temperature trends.
  • Several participants engage in a meta-discussion about the nature of the debate, including accusations of rudeness and the use of terms like "strawman" inappropriately.
Participants do not reach a consensus, as multiple competing views remain regarding the interpretation of the data and the implications for understanding global warming. Disagreements persist about the validity of the studies and the accuracy of the data sources.
Limitations include unresolved questions about the accuracy of satellite and weather balloon data, potential biases in temperature measurements, and the implications of corrections applied to the data. The discussion reflects ongoing uncertainties in climate science.
Ivan Seeking
Staff Emeritus
"Key Argument for Global Warming Critics Evaporates"
For years, skeptics of global warming have used satellite and weather balloon data to argue that climate models were wrong and that global warming isn't really happening.
Now, according to three new studies published in the journal Science, it turns out those conclusions based on satellite and weather balloon data were based on faulty analyses.
The atmosphere is indeed warming, not cooling as the data previously showed. [continued]
http://www.livescience.com/environment/050811_global_warming.html
There are a couple of inconsistencies here (or plain lies if you prefer that)
While surface thermometers have clearly shown that the Earth's surface is warming, satellite and weather balloon data have actually suggested the opposite, that the atmosphere was cooling.
Check here for the reality. See that the corrected low troposphere temperatures (black) only differ marginally to give a new trend of about 0,123 degrees per decade (old 0,115). Radiosondes are on 0,114, the surface trend in the same period (1979-2005) at around 0,172.
So the accurate situation is that the previous slight warming trend of the lower trophosphere has been corrected to be marginally more, but still less than the surface trend. See this
The correction pertained an artificiality in the tropics when the satelites pass the equator. This also means that the larger local difference on the northern hemisphere is not changed.
So the suggestion of erroneous cooling in the article is a plain wrong strawman. This is how the public is misinformed continuously.
Strawman: A weak or sham argument set up to be easily refuted.
These published reports are intended to be easily refuted? Have you considered reading them before dismissing them?
Why do you mask your links?
Ivan,
But we all know that global warming causes global cooling! http://www.livescience.com/forcesofnature/041217_sealevel_rise.html
It's too bad you're into harassing and insulting members rather than in having serious discussions. It could be fun and even illuminating. Oh, well. Good luck.
Ivan,
I'm not aware that "look here" is masking links, I still think it's a error not to allow for the feature, otherwise the graphs would have stared directly in your face, like here:
unmasked link: [PLAIN]http://www.ukweatherworld.co.uk/forum/forums/thread-view.asp?tid=23074&start=1
where you can follow the discussion about this in detail. With this information it may be clear that ...
...is a straw man (masked link).
Nobody has ever suggested that the lower trophosphere is cooling, although before the big 1998 El Nino the lower troposphere (MSU2 LT) was just about trendless.
BTW The lower stratosphere (MSU-4) is indeed cooling, which is undisputed by any party, whilst the global warmers love to explain this as caused by enhanced radiation due to more greenhouse gasses. So the reporter is mixing things up to serve his case. Needless to say that the slighter lower warming trend of the lower troposphere still refutes the enhanced greenhouse gas forcing hypothesis.
Radiosonde Daytime Biases and Late-20th Century Warming
The temperature difference between adjacent 0000 and 1200 UTC weather balloon (radiosonde) reports shows a pervasive tendency toward cooler daytime compared to nighttime observations since the 1970s, especially at tropical stations. Several characteristics of this trend indicate that it is an artifact of systematic reductions over time in the uncorrected error due to daytime solar heating of the instrument, and should be absent from accurate climate records. Although other problems may exist, this effect alone is of sufficient magnitude to reconcile radiosonde tropospheric temperature trends and surface trends during the late 20th century.
Amplification of Surface Temperature Trends and Variability in the Tropical Atmosphere
The month-to-month variability of tropical temperatures is larger in the troposphere than at the Earth's surface. This amplification behavior is similar in a range of observations and climate model simulations, and is consistent with basic theory. On multi-decadal timescales, tropospheric amplification of surface warming is a robust feature of model simulations, but occurs in only one observational dataset. Other observations show weak or even negative amplification. These results suggest that either different physical mechanisms control amplification processes on monthly and decadal timescales, and models fail to capture such behavior, or (more plausibly) that residual errors in several observational datasets used here affect their representation of long-term trends.
The Effect of Diurnal Correction on Satellite-Derived Lower Tropospheric Temperature
Satellite-based measurements of decadal-scale temperature change in the lower troposphere have indicated cooling relative to the surface in the tropics. Such measurements need a diurnal correction to prevent drifts in the satellites' measurement time from causing spurious trends. We have derived a diurnal correction that, in the tropics, is of the opposite sign from that previously applied. When we use this correction in the calculation of lower tropospheric temperature from satellite microwave measurements, we find tropical warming consistent with to that found in surface temperature and in our satellite-derived version of middle/upper tropospheric temperature.
these are the abstract of the article in question. These have been publish in the Science Express of August 11 2005.
http://www.sciencemag.org/sciencexpress/recent.shtml
Andre said:
Ivan,
It helps everyone to see where the information is coming from. To me it seems misleading considering that the source is everything. When I see a page full of links like this, here, and, as opposed to ****.edu, ***.noaa, ***.gov, etc, it makes me wonder. Frankly, this alone makes me suspicious of the credibility of the links. I would think that you would prefer to be up front with your sources.
Tide said:
Ivan,
Could you be more specific? I wasn't aware that I had insulted anyone.
I also see the word "strawman" used improperly as the norm here now.
Gladly - since you asked!
You: "Have you considered reading them before dismissing them?"
That's rude. Posturing yourself in a discussion or debate evades the issues and isn't exactly the pinnacle of professionalism in science.
You: "Why do you mask your links?"
In addition to being unwarranted and off-topic it implies deceit on the part of the poster and appears intended to call into question the veracity of the member without addressing the technical issues at hand. Besides, any regular user of the web knows she can plainly see the URL by passing the mouse pointer over the link and does so routinely.
If you are still unable to discern the offense in your comments then I advise some serious reflection and introspection.
In my experience, people tend to choose the path of ridicule, ad hominem attack and insult when they have run out of valid and legitimate debating points. Of course, I assume it's simply a momentary lapse in judgment in your case.
By the way, your lapse caught my attention because of your Oppenheimer quote: "There is no place for dogma in science"
Robert would have been the last person to stifle debate and adopt a dogmatic posture. This is particularly important with regard to climate change and one should recognize the importance of questioning the validity of the data, models and theory behind it.
Anyway look at the bottom of the graph.
http://home.casema.nl/errenwijlens/co2/jonesmsu52.gif
Perhaps notice the sources of the data. Unfortunately the predecessor of MSU-2LT, the dataset tltglhmam_5.1 is no longer on the net but I'm sure that Spencer and Christy (S&C) will make it available. You can have my set.
Unlike the global warmers like Mann and Jones having a hard time to reveal data, methods and dealing with critique, it may be noted that S&C have always given full access to all data, models and algoritms, and upon critique, acknowlegded the error, credited the discoverers and published prompt corrections.
I did.
It seemed relevant to me. And I'm not debating anything.
Well, I see this tactic used by people who are giving misleading information or trying to hide the source, so this always sets off an alarm for me.
When people who in all likelihood are good and honest scientist are called liars due to their published reports and most likely, highly qualified interpretation of those reports, I consider this a huge lapse in judgement. To call them strawmen is flat out laughable.
I think the word "lies" pretty much set the tone for dogma. :wink:
Well, this:
boldface part is plainly wrong. Period.
Previous data (MSU 2LT version 5.1) showed warming as well, only a little less. So introducing a wrong statement is an essential first part of the strawman. And what is the difference between a wrong statement and a lie?
Anyway, for all those who think that global warming is merely a mild dispute, the real war is imminent:
Newspeak versus science.
http://ccc.atmos.colostate.edu/blog/?p=30
Ivan,
Well, I see this tactic used ...
Well, then let's all stoop to their level! ;)
So, this Global Warming "problem" is really just bolangne? Most people you ask believe it's significant reality.
I don't think that it is bologna. Are we allowed to quote published journal articles on this website? Or is that a copyright violation? I would be happy to comment on some studies.
scrappy,
Please do! :)
Here we go again. The world is warming so we have to cut our greenhouse emissions
Remember there are several questions.
Is the world warming up?
Is this warming unusual and unprecedent?
To what extend can that warming be attributed to which causes?
Can we do anything?
Must we do anything?
It's interesting. We simply live as humans and therefore (so many suggest) the world has become "off balance", and somehow we are altering nature... as if we aren't "natural" just being human beings. We are not so significant that we can change the Earth beyond it's ability to do what it has done for eons!
I'm not condoning irresponsiblity here, but come on, people!
Andre, you are a breath of reality concerning this subject. You have demonstrated extreme patience in this forum.
I'm just floored by some of the things people are convinced of here. :bugeye:
Can we do anything?
Hi Andre,
I quite agree with your analysis of the situation,however "to answer a question one has to first know the question" which too often is not addressed.
"Is the world warming up"? relative to what time scale? If the period referred to is the past 10 years then the answer is probably yes.
"Is this warming unusual and unprecedent"? Compared to what? I feel there may well have been periods in the Earth's history when warming has been more "unuaual", however if you look at the last century, it probably is unusual.
"To what extend can that warming be attributed to which causes?"( you yourself have answered the first question here) If anyone can answer this at this moment in time then they deserve a nobel prize !
"Can we do anything?" Similar to the previous answer, however,IF AGW is present and IF carbon emissions etc are to blame we are taking a huge gamble by doing nothing. Once upon a time it was considered quite normal to dump effluent into rivers, canals and lakes (and the sea) until it was noted that the environment was becoming polluted almost beyond repair. Once again a big IF but can we really afford to take this chance of gambling with natural cycles.
"Must we do anything?" The big question, "must" sounds as if we are assuming that we are culpable. Had you said "should" i would say yes.
Nearly all the posts I read re GW, people are too quick too use the very limited, short term data we have to swing either on the pro or anti GW side. I was in the middle, now erring on the GW side. As for AGW, I think it is possible and cannot be ignored, purely from the point that if it is true it will actually be too late by the time it can be confirmed.
From a factual point of view I share your views, but wether I would share them in 5 or 55 years time remain to be seen.
Regards,
Paul D...Guernsey
That's the key question. Is it unusual? To know that you have to study paleo climate, which I have been doing for several years. In there is the key answer.
Now take for instance the current minimum Arctic Sea Ice. Is global warming on a http://news.independent.co.uk/world/science_technology/article312997.ece ?
A record loss of sea ice in the Arctic this summer has convinced scientists that the northern hemisphere may have crossed a critical threshold beyond which the climate may never recover. Scientists fear that the Arctic has now entered an irreversible phase of warming which will accelerate the loss of the polar sea ice that has helped to keep the climate stable for thousands of years. ... cont'd
Now what would you think if fed continously with this type of red alert messages? Is this really a fact? There seems to be no trace of doubt that we are on the brink of disaster. However, let's have a closer look into the recent history. Somebody found this old letter:
It will without doubt have come to your Lordship's knowledge that a considerable change of climate inexplicable at present to us must have taken place in the Circumpolar Regions, by which the severity of the cold that has for centuries past inclosed the seas in the high northern latitudes in an impenetrable barrier of ice has been during the last two years greatly abated.
Mr. Scoresby, a very intelligent young man who commands a whaling vesell from Whitby observed last year that 2000 square leagues (a league is 3 miles) of ice with which the Greenland Seas between the latitudes of 74° and 80°N have been hitherto covered, has in the last two years entirely disappeared. The same person who has never been before able to penetrate to the westward of the Meridian of Greenwich in these latitudes was this year able to proceed to 10°, 30'W where he saw the coast of East Greenland and entertained no doubt of being able to reach the land had not his duty to his employers made it necessary for him to abandon the undertaking.
This, with information of a similar nature derived from other sources; the unusual abundance of ice islands that have during the last two summers been brought by currents from Davies Streights (sic) into the Atlantic. The ice which has this year surrounded the northern coast of Ireland in unusual quantity and remained there unthawed till the middle of August, with the floods which have during the whole summer inundated all those parts of Germany where rivers have their sources in snowy mountains, afford ample proof that new sources of warmth have been opened and give us leave to hope that the Arctic Seas may at this time be more accessible than they have been for centuries past, and that discoveries may now be made in them not only interesting to the advancement of science but also tot he future intercourse of mankind and the commerce of distant nations."
President of the Royal Society, Minutes of Council, Volume 8. pp.149-153, Royal Society, London. 20th November, 1817..
Confirmed here:
...Whilst on this voyage in 1817, Scoresby visited Jan Meyen island, surveying the land, geology and wildlife and he found that the longitude and latitude were incorrect, naming the spot where they had landed, "Jameson Bay". He also noted a remarkable diminution of the polar ice, allowing penetration to within sight of Greenland's East coast.
So I don't even have to point at similar situations around 900 AD at the height of the Medieval Warming Period or the early Holocene thermal maximum, when the trees grew at the beaches of the Arctic ocean, high in northern Siberia.
This makes you wonder why this unprecedent scaremongering is so necesary. Journalists wanting firm catchy head lines? Scientists who want to secure their fundings for further studies? If they only would have known about the recent past, they would not even bother to worry. Yet with this kind of approach climate science is in a slippery slope upwards in a continuous circle until disaster seems imminent. However, with this kind of unfounded activism the world is heading for a completely different antropogenic disaster, spending googillions for nothing and be totally unprepared for the real problems that we're facing.
Thank you for that Andre, a fascinating excerpt from the RS you have found there.
After agreeing with just about all you say I have to be a little contentious with "what if the natural cycle is positively affected by human intervention?"
There are so many "ifs" that one can only make best judgements I know. Would you say that the recent (last 3 years) darmatically increased trend in global warming is similar to previous warmings, just a blip, unreliable in source or what ??
Regards
Paul D...Guernsey
Sorry Paul, for overlooking your question.
If you look at the last years, we actually see more or less a level off after the warmest year 1998. So the real warming happened in the last decade as of about 1990.
http://lwf.ncdc.noaa.gov/oa/climate/research/2005/aug/global.html#Temp
If 1998 was indeed the warmest or if 2003 had the warmest summer in Europe is unsure . There is a good case for 1540. Advise to have a good look at http://members.lycos.nl/errenwijlens/co2/errenvsluterbacher.htm
There seems to be no indication that anything unusual is happening. The panic for a sudden dramatic climate change is largely based on http://www.esd.ornl.gov/projects/qen/transit.html . It was a completely different story.
Three papers published in the Science last week purport to debunk an important argument advanced by skeptics of the notion of catastrophic, manmade global warming. The skeptics’ argument is that while temperatures measured on the Earth’s surface seem to indicate that global temperatures have increased at a rate of about 0.20 degrees Centigrade per decade (the original estimate was 0.35, may I not that is a 50% error, there's a big difference from a fight on a test and a one hundred) since the 1970s, temperatures measured in the atmosphere by satellite and weather balloons have shown only a relatively insignificant amount of warming for the same time period (about 0.09 deg. C/decade).
The implication of the skeptics’ argument is that whatever warming seems to be happening on the Earth’s surface, similar warming isn’t happening in the trophosphere. This unsimilarity is caused by the urban heat island effect.
It is well known that changes in land use will cause changes in average ground temperature. Cities are hotter than the surroundign countryside - the urban heat island effect. Croplands are warmer than forested lands, and so on. A high percentage of weather stations that were out in the countryside forty years ago are now surrounded by concrete and skyscrapers and asphalt and so on. Which makes them register warmer. These facts are very well known within the field, of course. There is no controversy.
http://eetd.lbl.gov/HeatIsland/HighTemps/UrbanProfile.gif
What is controversial about these heat islands is whether, and if so how much, this additional warmth affects trends in [global] temperature record. The current state of the science is that the effect on the global temperature trend is small to negligible—see below. So researchers take the raw temperature data from stations near cities and reduce them by some amount to compensate for the urban heat island effect. This reduction is calculated in different ways, depending on who does it. Most algorithms are based on population size. Population is proportional to the amount subtracted.
Sounds good but it isn't. R. Bohm studied Vienna in 1998. Vienna has had no increase in population since 1950, but it has more than doubled its energy use, and increased living and commercial space substantially. The urban heat island effect is much stronger, but calculated reduction is unchanged, because it only looks at population change.
It used to be assumed that urban heating was unimportant because the effect was only a fraction of total warming. The planet warmed about .3 degrees C in the last thirty years. Citites are typically assumed to have heated around .1 degrees C. The Chinese report that Shanghai has warmed 1 degrees C in the last twenty years. That's more than the entire global warming of the planet in the last hundred years. "Between 1987 and 1999, the mean nighttime surface temperature heat island of Houston increased 0.82 ± 0.10 degrees C." says D. R. Steutker, in Remote Sensing of Environment. Manchester, England, is now 8 degrees warmer than the surrounding countryside.*
The average temperature of Pasadena, Calafornia, went from 62 degrees F in 1930, to 65.5 F in 2000. LA has about 14,531,000 people. The average temperature of Berkeley, CA, with only 6,250,000 people, from 1930 to 2000 has increased .5 degrees F. Death Valley, CA, with no urbanization, from 1932-2000 has increased .15 degrees F. In smalltown McGill, NV, from 1930 to 2000, it went from average 48 to 47. Guthrie, OK went from 60.5 to 59.9. Boulder, where NCAR (National Center for Atmospheric Research, where a lot of global warming research is done), has gone down half a degree. Turman, MO went down two and a quarter! Charleston, South Carolina went up over half a degree, and New York City went up 1 degree. Cities in New York with less urbanization such as Syracuse, Albany, Oswego and Westpoint, went down 1.5, 1.2, 1, and .35 degrees. And if you go back allllll the wayyyy from 1826, to 2000, then you will find the line actually rises steadily... about 0 degrees F. Its a horizontal line. New York went up 5.2 degrees F, and Albany went down half a degree in 180 years.
We know CO2, the gas everyone is worrying about, has increased the same amount everywhere in the world. And its effect is presumably pretty much the same everywhere in the world. That's where the term "global" warming comes from. But New York and Albany are only one hundred and forty miles apart, you can drive from New York to Albany in three hours. Their carbon dioxide levels are identical. But somehow New York's temperature went up 5 degrees, a temperature increase that would kill many species, while across the street it got colder a little bit. In the last 180 years, New York has grown to seismic proportions, about 8 million people, whereas Albany has grown to quite less.
The urban heat island effect makes cities hotter than the surrounding countryside; and this is a local effect, completely unrelated to global warming. In this case, we used all raw temperature data, and it is tainted by the very scientists who claim global warming is a worldwide crisis. It is adjusted downward, but the question is: Is it adjusted down enough? It is never a good policy for the fox to guard the henhouse. Such procedures are never allowed in medicine, where double-blind experimental designs are required.
One of the new Science studies reported that the satellites had drifted in orbit, causing errors in temperature measurement. Corrections to the satellite data, according to the researchers, would increase the atmospheric warming estimate to 0.19 deg. C/decade -- more in line with the 0.20 deg. C/decade warming of the Earth’s surface. Another study reported that heating from tropical sunlight had skewed the balloon temperature measurements.
Ben Santer of the Lawrenhce Livermore National Laboratory, one of the studies’ authors, told USA Today that, “Once corrected, the satellite and balloon temperatures align with other surface and upper atmosphere measures, as well as climate change models.”
So is it really game-set-match in favor of the global warming alarmists?
University of Alabama-Huntsville researcher Roy Spencer, a prominent climatologist, factored the newly reported corrections into his calculations, his estimate of atmospheric warming was only 0.12 deg. C/decade - higher than the prior estimate of 0.09 deg. C/decade, but well below the Science study estimate of 0.19 deg C/decade and the surface temperature estimate of 0.20 deg. C/decade.
As to the claimed errors in the weather balloon measurements, Spencer says that no other effort to adjust the balloon data has produced warming estimates as high as those reported in the new study and that it will take time for the research community to form opinions about whether the new adjustments advocated are justified.
Climate expert Dr. Fred Singer of the Science and Environmental Policy Project says the temperature adjustments are “not a big deal.”
“Greenhouse theory says (and the models calculate) that the atmospheric trend should be 30 percent greater than the surface trend - and it isn’t,” says Singer. “Furthermore, the models predict that polar [temperature] trends should greatly exceed the tropical values - and they clearly don’t... In fact, the Antarctic has been cooling,” adds Singer.
:rolleyes:
Have a look here
See the dark blue line? That was the sceptics weapon. Now look at the light blue line. That's the correction made. Several of those corrections have been made like that, which never got any press.
What is going on?
More discussions http://www.ukweatherworld.co.uk/forum/forums/thread-view.asp?tid=23074&start=1
How long would it be until the Ice caps "Melted", if ever?
Teacher says 100 years, and I know for a fact he's wrong.
Hello again Andre. I am told that insulted you in another thread, just so you know. It wasn't intended in an insulting way, I was attacking the content of your posts, not you as a person. Thus, I haven't edited the content. But apparently it reads as an insult.
At present I take issue with this:
Andre said:
Well, this:
Your position on this leads me to ask: Have you read the articles that were cited from Science?
This is not intended as posturing on my part, it just seems from your comment that you haven't, as the thrust of the third abstract from Ian's post (and initially mentioned in Ivans link and titled "The Effect of Diurnal Correction on Satellite-Derived Lower Tropospheric Temperature" ) is precisely that the troposphere is warming in the tropics.
The entire basis for this paper is that corrections that should have been made, were not (as far as I understand the paper.) When the corrections are made, warming is demonstrated, and it is considerable. Get your hands on a copy of Science (September 2 issue), and look at figure one on page 1549.
Have you read the paper?
How do you know this?
Try it this way: How much ice have we lost on our ice caps in the last 20 years?
Who is scaremongering now?
Show me where *any* head of *any* country is talking about spending googillions to address climate change.
The recommendations from the concerned scientists and other groups are:
(1) Develop alternative energies (create jobs, reduce dependence on foreign oil)
(2) Reduce emissions at a steady pace (through hybrid technologies, hydrogen cells, in other words see #1)
(3) Sustain habitat (maintain biodiversity, which has benefits for health and tourism and other industries ... here's an abstract on how an unusual frog may help in the fight against AIDS:http://www.scienceagogo.com/news/20050829204919data_trunc_sys.shtml . Also, this maintains the carbon sink a little better.)
... How are these sorts of things "bad?" Or scaremongering?
Please find me a reference that demonstrates scaremongering coming from the "green" side of this debate. Not the news, or from politicians...
Find me an environmentalist who is scaremongering.
I guarantee you I can find scaremongering from the oil industry, designed to make it look like the greens are demanding outrageous changes.. Want me to?
  • Sticky
18K
  • · Replies 54 ·
13K
  • · Replies 184 ·
50K
