(101)Acceleration due to gravity
  • Thread starter Thread starter WPCareyDevil
    Gravity
The discussion focuses on calculating the distance an object falls due to gravity, specifically using the formula d = v_0 t + (1/2) a t^2. The object falls for 3.36 seconds, resulting in a final speed of 32.928 m/s and an average speed of 16.464 m/s. The correct height of the bridge is determined using the aforementioned formula, which accounts for the acceleration due to gravity at 9.8 m/s². The initial approach of summing distances for each second was incorrect due to the changing velocity during the fall.
  • Understanding of basic physics concepts, particularly kinematics
  • Familiarity with the equations of motion under constant acceleration
  • Knowledge of the acceleration due to gravity (9.8 m/s²)
  • Ability to manipulate algebraic equations
  • Study the kinematic equations for uniformly accelerated motion
  • Learn how to derive distance from velocity-time graphs
  • Explore real-world applications of gravitational acceleration in physics
  • Practice solving problems involving free fall and projectile motion
Students in physics courses, educators teaching kinematics, and anyone interested in understanding the principles of motion under gravity.
WPCareyDevil
[SOLVED] (101)Acceleration due to gravity
Ok, this should be really strait forward. Its only problem C that I am not getting correct.
An object is observed to fall from a bridge, striking the water below 3.36 s later.
(a) With what speed did it strike the water?
(b) What was the average speed during the fall?
(c) How high is the bridge?
a) 9.8*3.36 = 32.928 m/s - correct
b) Vi+Vf/2 = 16.464 m/s - correct
c) ?
Ok, acc due to gravity = 9.80m/s^2
So, in the first second, the object fell 9.8m. In the second second, it fell 19.6m. t=3 it fell 29.4m. t=3.36 it fell 32.928m.
Adding all of these would give me the total distance fallen (height of the bridge). The answer 91.728m is incorrect.
Am I attacking this the wrong way?
Thank you!
There is a formula for calculating the distance traveled due to acceleration... might want to give that a try
why not use x=ut+1/2at^2, where x is distance, u is initial velocity, a is acceleration and t is time.
Use the formula d = v_0 t + (1/2) a t^2
You know that initial velocity is 0. You know the time and you know the acceleration.
If the object travels for 1 second at 9.8m/s, then it will travel 9.8m. Unfortunately, the speed in this case is not constant but increasing.
I solved the problem with the above formula.
I was saying that it fell at 9.8m/s per second, thus it fell 9.8m in the first second, and then 19.6 meters in the second second, meaning it had fallen a total of 28.6m at the end of 2 seconds. I don't understand why this approach doesn't work, but all is well with the d=volt+ (1/2)at^2 formula.
I think your approach ignores the fact that velocity is changing (Because there is acceleration) and it may be ignoring any initial velocity the object has already attained in the previous seconds.
No, it fell less than 9.8m in the first second because it is only traveling at 9.8m/s for an instant. It would only fall 9.8m in one second if it were actually traveling at 9.8m/s for the whole second, but it (presumably) starts with zero velocity. You actually have to take the area under the velocity-time graph, so for the first second it travels .5*(9.8-0) m or 4.5m (and for constant acceleration, this turns out to be average velocity multiplied by time)
That makes perfect sense. Thank you all for the help!
  • · Replies 21 ·
10K
  • · Replies 22 ·
