Need Help with Gaussian Surface Problem: Electric Flux Calculation
This discussion focuses on calculating electric flux through a spherical Gaussian surface enclosing various charge configurations. The relevant equation used is φ = Q_enclosed/ε0, where ε0 is the permittivity of free space (approximately 8.85 x 10^-12 C²/N·m²). The user successfully calculates the electric flux for different charge combinations, ultimately determining that a fourth charge of -3.05 μC is needed to achieve zero electric flux. Key calculations include finding the net charge enclosed for each scenario and converting micro-coulombs to standard units.
  • Understanding of Gauss's Law
  • Familiarity with electric flux concepts
  • Knowledge of charge units, specifically micro-coulombs
  • Basic algebra for manipulating equations
  • Study Gauss's Law applications in electrostatics
  • Learn about the concept of electric flux in different geometries
  • Explore the implications of charge neutrality in electric fields
  • Practice problems involving multiple charges and Gaussian surfaces
Students studying electromagnetism, physics educators, and anyone preparing for exams in electrostatics or related fields.
FlipStyle1308
I just realized that I accidentally didn't post this in the homework help section...if any mods can move this, I'd appreciate it. Sorry for the trouble!
Hello. I need help solving the following problem:
Consider a spherical Gaussian surface and three charges: q1 = 1.60 μC, q2 = -2.26 μC, and q3 = 3.71 μC. Find the electric flux through the Gaussian surface if it completely encloses the following charges.
(a) only charges q1 and q2
(b) only charges q2 and q3
(c) all three charges
(d) Suppose a fourth charge, Q, is added to the situation described in part (c). Find the sign and magnitude of Q required to give zero electric flux through the surface.
I'm pretty sure that this problem involves the equation φ = q/ε0, but have no idea on how to incorporate the given values into this problem. Any help would be greatly appreciated. Thanks in advance!
Maybe writing the equation this way would help: \Phi = \frac{Q_{enclosed}}{\epsilon_0}
Hmm...would you be able to give me an example of how to plug in my values into the equation, such as for part (a). I can try figuring out how to solve it for the rest if I get a sample with part (a). (There are no examples for this problem in both my notes and the textbook, so I have no clue on how to plug in everything.)
Q_enclosed is nothing but the net charge enclosed within the surface. So, in case (a), what is the net charge enclosed?
So for part (a) it would be 1.60μC - 2.26μC = -0.66μC? Shouldn't the answer be in Nm^2/C?
Yes, and yes.
Okay, so (-0.66 x 10^6 C)/(8.85 x 10^-12 C^2/N x m^2) = -7.74576 x 10^16 Nm^2/C is my answer for part (a)?
The charge is given in terms of micro-coulombs, not Mega-, or million-coulombs. And it's ~ -7.4576.
Okay, I changed my mistake of not putting the - in when converting form micro to standard. Is the final answer -74,576.27 x 10^16 Nm^2/C?
No, it's -7.4576 x 104 Nm2/C.
Hmm...what did I do wrong?
Quite simple, but if were to do the same in a test, it would get you into trouble. ;) You didn't add the powers of ten correctly.
LOL okay, thanks! So I will follow the same format for (b) and (c). Any ideas on how to approach (d)?
(d): It just asks for another charge that would make the flux zero, i.e. net charge Q = 0, since \epsilon_0 is a constant.
So is my answer -3.05μC! Thanks so much for your help! =]
That's correct. Sorry for the late reply.
