1A current at 11 MHz into a toroidal circuit
  • Thread starter Thread starter jumpjack
    Circuit Current
The discussion revolves around generating a 1A current at 11 MHz in a toroidal circuit, specifically focusing on the design and calculations related to inductance, voltage requirements, and the properties of the core material. Participants explore theoretical and practical aspects of this electrical engineering problem.
  • One participant inquires about the appropriate device to generate a 1A current at 11 MHz in a toroidal circuit.
  • Another participant notes that the voltage required depends on the number of turns, suggesting that with 35 turns, nearly 1000 volts would be needed at 11 MHz.
  • There is a discussion about the terminology, clarifying that a "solenoid around a toroid" is simply referred to as a toroid.
  • Participants debate the calculation of voltage based on the number of turns, with one suggesting it could be around 8 kV for 100 turns.
  • There is skepticism regarding the purpose of the project, with one participant suggesting it may be related to "free energy," which is often viewed with suspicion in the forum.
  • Participants discuss the formula for voltage in relation to inductance and current, with one providing the equation V = 2πfLI and questioning how to derive voltage from the inductance parameter A_L.
  • Another participant raises concerns about the feasibility of using a solenoid at such a high frequency, questioning the practicality of mechanical actuation at 11 MHz.
  • Discrepancies in values for permeability (μ) and the correct approach to calculating inductance are highlighted, with suggestions to use data sheet values instead of approximations.
  • One participant presents a formula for energy in an inductor and discusses the complexities of AC current flow.
There is no consensus on the calculations or the purpose of the project. Multiple competing views exist regarding the voltage requirements, the terminology used, and the feasibility of the proposed setup.
Participants express uncertainty about the correct values for core material properties and the implications of using different formulas for calculating voltage and inductance. There are unresolved questions about the practical application of the circuit design.
jumpjack
I need to generate a 1A current at 11 MHz into a solenoid around a toroid like this:
http://cgi.ebay.it/TOROIDE-T200-2-ROSSO-1-30-MHZ-NUOVO-/280683303561?pt=Ham_HF_VHF_UHF_SHF&hash=item415a075289
Out Diameter= 5cm
In Diameter = 3 cm
wire diameter: 1mm
spires number: 100
Which device can I use/build to generate such a current inside this circuit?
That very much depends on the number of turns you intend to use.
The coil specifies an inductance of 12 nH per Turn squared, so for example with just one turn you'd only need about one volt @11 MHz to get you a one amp current. At 35 turns however you'd need nearly 1000 volts @ 11MHz.
Why don't you tell us what you're trying to build.
BTW. A "solenoid around a toroid" is just called a toroid. The term "solenoid" is used to describe a straight cylinder shaped coil and the term "toroid" is used to described the coil that is wound on a circle like a doughnut shape.
BTW. A "a solenoid around a toroid" is just called a toroid. The term "solenoid" is used to describe a straight cylinder shaped coil and the term "toroid" is used to described the coil that is wound on a circle like a doughnut shape.
Thanks for clarifications.
But then how do you name the core of a toroid?!? Doughnut does not look very "scientific" :-p
Back to physics... how do you calculate voltage from spires number?
I'd need 100 spires! Does it mean 3 kV?
That's why we give it the name toroid.
No it's proportional to the number of turns squared, so it more like about 8 kV
Once again. To avoid potentially wasting peoples time could you please tell us what you're trying to achieve with this exercise. :)
Sorry but I can't.
But which is the formula you used?
jumpjack said:
Sorry but I can't.
Yeah it's "free energy" related isn't it? Usually when people are have little idea what they're doing and are asking "not quite right" questions, then it's "free energy" related. Having little idea of what you're doing is actually a prerequisite for working on "free energy" you know. :rolleyes:[tex]L = A_L N^2[/tex]
Wrong.
Better luck next time. :wink:
I can't see V in this formula, so how do I get V from it and my data?!?
jumpjack said:
Wrong.
Well you'll have to forgive me. "Free energy" (as with other banned topics) really is one of the most common reasons why people are reluctant to divulge what they are trying to achieve.
[tex]V= 2 \pi f L I[/tex]
uart said:
Well you'll have to forgive me. Free energy (as with other banned topics) is one of the most common reasons why people are reluctant to divulge what they are trying to achieve.
Fuuny, forum engine automatically links "free energy" to REAL free energy rather than the one you're talking about! :wink:
thanks.
So let me see if I understood:
[tex]V= 2 \pi f A_L N^2 I[/tex]
N= spires number
What is Al?
[itex]A_L[/itex] is a parameter of the core and is given on the data sheet as 12 nH/N^2. (One nH is 10^(-9) H).
It's only valid if the core is not saturated, meaning that the flux density is less than about 250 to 300 mT for most ferrite cores and less then about 1000 to 1500 mT for most powdered iron cores.
The flux is equal to (L I / N) and the flux density is equal to the flux divided by the cross sectional area.
I found this for a toroid:
So is this correct?
[tex]L = (uN^2r^2)/D[/tex]
Hence:
[tex]V= 2 \pi fIuN^2r^2 / D[/tex]
So for 11 MHz and 1A:
[tex]V= 6,28 * 1.1 e^7 * u * 100^2 * (2 * 10^-2)^2 / (5 * 10^-2)[/tex]
I think I get 69 MV ?!?
What value are you using for mu? Your formula looks ok but I suspect you have the wrong value for mu. The inductance parameter "A_L" is basically just an indirect way of specifying mu.
Edit : No you've also got the wrong values for r and D. You'd do better to use the area (A) and length (l) values given on the datasheet than the *approximation* r^2/D anyway.
What would a solenoid be doing with 11 MHz anyway? I'm just an inexperienced newbie, but I'm having a really hard time believing that anything mechanical could actuate 11 million times a second.
Hi Jiggy. The term "solenoid" really just describes the geometry (long straight cylinder) of the core. Because long straight cylinder cores are naturally used for linear actuators, a lot of people use the term "solenoid" synonymously with "solenoid valve" or "solenoid actuator", but it doesn't have to be an actuator.
In this case the OP was actually referring to a "solenoid wound in the shape of a toroid", which doesn't make sense. He was really just referring to a toroid inductor all along. What he wants to do with it however is still anyone's guess. :)
Actually on datasheet I have internal radius, external radius and thickness.
I consider u=1.26 e-6 and ur = 800 (iron)
But doing calculations again I get around 6 MV anyway...
- That won't be pure iron. Powdered Iron cores can have [itex]\mu_r[/itex] anywhere from 5 to 500.
- The term [itex]r^2/D[/itex] is just an approximation for Area/Length. Use the correct expression which is [itex]A/l[/itex] as given on the data sheet.
So I have this formula:
X(t)= k0 u0 ur N I O cos (O*t) / (4 pi^2 r R)
I'd need x=9,8 , but if I could just obtain X=0,098 could be acceptable in a first instance.
k0=4,31E-10
u0=1,26E-06
ur depends on material: 800 iron, 5000 ferrite, 100.000 permalloy
N = spires
I = current
O = 2 pi f (f=frequency)
r = core thickness
R = core radius
none?
Energy in an inductor is equal to the current squared times the inductance all halved. (E=1/2*L*I*I) This is based on a one second interval. With AC it gets a bit tricky. You establish the 1 Amp current flow in one direction then reduce it to zero and then make it flow in the opposite direction. So wouldn't the equation now be;
E=1/2*L*I*I*f
L is inductance in Henries
I is current in Amps
f is frequency
Where are you going to get the energy to run through this inductor?
