1D Quantum Well - I'm getting something very basic wrong
5 replies · 2K views
neural_jam
Ok, so this example question is in my lecture notes:
"For a 1-D quantum well, 5nm width, 2eV barrier height, calculate the number of energy levels in the well."
So the equation given is a familiar one:
[tex]E_n=\frac{n^2 \pi^2 \hbar^2}{2 m L^2}[/tex]
and he also said [tex]E_n=2 \times 1.6 \times 10^{-19} J[/tex]
Now, in the lecture [tex]n^2[/tex] came out to be 134, but I keep getting ~1.9, so I'm using the wrong units somewhere or something, because otherwise it's a pretty simple 'plug and chug' exercise..!
also, I'm using
[tex]\hbar = 6.582 \times 10^{-16} eVs[/tex]
[tex]m = 0.511MeV[/tex]
Can anyone help? :-s
-Jam
Remember that the units of mass are
[tex][m] = eV/c^2[/tex]
And therefore with the values that you are using it should be
[tex]E_n=\frac{n^2 \pi^2 \hbar^2 c^2}{2 m L^2}[/tex]
Hi, thanks for the reply!
Unfortunately, if I put in the factor of [tex]c^2[/tex], then [tex]n^2[/tex] becomes ~[tex]2.13^{-17}[/tex], even further off the 134 that it should be :-(
Make sure that you use the same units for everything. That is if you use electron volts as you said in your first post then E = 2 eV. If you use Joules for E then you have to use Js for h, kg for m (without c^2 this time) and so on.
I get 133, which seems pretty close... it's probably just a silly math mistake. If you write out the details of your calculations (and please be consistent with the units ;-), someone can probably pinpoint where it went wrong.
Ah, thankyou! Yes, it was a silly mistake, I forgot to change [tex]E=2 \times 1.6 \times 10^{-19}[/tex] to E = 2, yes it works out fine now.
Thank you both, I have an exam tomorrow where this will likely be part of a question or two, so I'm very grateful for the help!
