1st order nonlinear differential equation
14 replies · 3K views
magnifik
this is the problem:
x2y' = (2y2 - x2)
here's what i have done so far:
dy = (2y2/x2 - 1)dx
(2y2/x2 - 1)dx - dy = 0
i used the substitution y = xv then found an integrating factor and got
dx/x - dv/(2v2 - 2v - 1) = 0
but i am stuck at this point..
i know ln(x) + C is the first part, but is there an easy way to find the second part? or am i totally off to begin with?
this is the solution:
[PLAIN]http://www4c.wolframalpha.com/Calculate/MSP/MSP50419e2227898a2f2f0000026hh297a4ebd6b3h?MSPStoreType=image/gif&s=33&w=154&h=47
i am at a loss for how they got to this point
i have tried it several times and seem to always get 2v2 - 2v - 1. do you get the correct solution using 2v2 - v - 1??
ok, i see how you got 2v2 - v - 1
now i have
dx/x - dv/2v2 - v - 1 = 0
[ln(x) + C] - [1/3(ln(1-v) - ln(2v+1))+C] = 0
multiply everything by 3
3ln(x) + 3C1 - ln(1-v) + ln(2v+1) + 3C2
stuck here :\
now i have
stuck here :\
Define C3=3C1+3C2. Remember that the RHS is 0 or a constant (let's make it 0, merging that constant with C3 as well). Then rearrange to solve for v.
combining the constants, i have
3ln(x) - [ln(1-v) + ln(2v+1)] = C
using some properties of natural log,
ln(x3) - [ln((1-v)(2v+1))] = C
which simplifies to
ln(x3/(-2v2 + 3v - 1) = C
(x3/(-2v2 + 3v - 1) = eC
trying to solve for v i get,
x3/eC = -2v2 + 3v - 1
not sure if this step is correct:
0 = -2v2 + 3v - (1 - x3/eC)
i'm assuming i do the quadratic formula to find the answer then use v = y/x to get y?? is this correct?
which simplifies to
0 = -2v2 + 3v - (1 + x3/eC)
Fixed that for you. And yes, that's what you got to do.
thanks for the help. much appreciated!
It's not a problem. I actually enjoy solving these problems.
I thought y = ux, not vx.
The only real difference is using a u instead of a v. It's similar to using t or x in your equations. It doesn't really matter, as long as it's uniquely defined.
ok...i tried to solve the quadratic equation but am still not getting the correct answer
x = -b + sqrt(b2 - 4ac)/2a
v = -2 + sqrt(9 - 4(-2)(-1-x3/eC))/-4
v = y/x
y = x[-2 + sqrt(9 - 4(-2)(-1-x3/eC))/-4]
i'm not sure how this would simplify to the correct answer, which is
[PLAIN]https://www.physicsforums.com/latex_images/30/3082166-0.png
hi magnifik! :smile:
(just got up :zzz: …)
i didn't "get" it :rolleyes:it was already there! :smile:
in the exams, you must write out everything in full
it'll stop you making mistakes, and even if you do make a mistake, you'll get more marks for following the right method …
in this case, your partial fractions are wrong: one of the ln should have a "2" in front of it :wink:
noooo :redface: … you've copied your own equation wrong … that + should be a - :cry:
tiny tim,
i believe the integral is correct - there should not be a 2 in front of anything.
and the + should not be a -, but i did, however, group them mistakenly after i already distributed a -1
