Chemistry, mL required to Concentration of HNO3
The discussion focuses on calculating the volume of a 50.0% by mass HNO3 solution required to prepare 500 mL of a 2.00 M HNO3 solution. The initial calculations incorrectly assumed the mass of HNO3 in the solution, leading to an erroneous molarity of 31.6 M. After correcting the calculations, the accurate volume required was determined to be 63.0 mL, aligning with the professor's answer key. The key equations utilized include the molarity formula and density conversions.
  • Understanding of molarity and its calculations
  • Knowledge of density and its application in solution preparation
  • Familiarity with stoichiometry and mass-to-mole conversions
  • Basic algebra for solving equations
  • Study the concept of solution concentration and how to prepare solutions of specific molarity
  • Learn about density and its role in calculating volumes of solutions
  • Explore stoichiometric calculations involving acids and bases
  • Review common mistakes in molarity calculations and how to avoid them
Chemistry students, educators, and anyone involved in laboratory work requiring precise solution preparation and concentration calculations.
Flip
How many mL of 50.0% by mass HNO3 solution, with a density of 2.00 g/mL is required to make a 500 mL of a 2.00 M HNO3?
initial Molarity X initial Volume = final Molarity X final Volume
(50 g HNO3)(1 mL/2.00 g)(0.001 L/1 mL) = 0.025 L
(50 g HNO3)(1 mol HNO3/63.012 g HNO3) = 0.79 mol
0.79 mol/0.025 L = 31.6 M
(500 mL)(2 M) = (31.6 M)V
V = 31.6 mLComments
I don't know if the process that I used is right. Which leads me to doubt the answer. Any help is much appreciated.
Generally not bad, although you did one serious mistake:
That would be true if you would start with pure acid, not with the solution. 50 g of the solution has volume of 0.025L, that's OK, but it doesn't contain 50 g of HNO3.
Thanks for the reply.
Ok so the volume I obtained is right, but the label is wrong? And the answer is around 31.6 mL?
No, this is a serious mistake (serious in terms of the way it changes final result).
Ok ok, so since it says 50 percent by mass HNO3 I assumed that it was part of a 100 percent solution. Meaning 100 grams. So I did the whole process again with the new calculations and got 63.0 mL.
Here is my work:
(50 g solution)(1 mL/2.00 g)(0.001 L/1 mL) = 0.05 L
0.79 mol/0.05 L = 15.8 M
(500 mL)(2 M) = (15.8 M)V
V = 63.0 mL
Which I found out later, from the answer key that my professor provided me with, was correct. Thanks!
10K
