Finding Velocity as a Function of Time for a Thrown Object at an Angle
The problem involves determining the velocity of a rock thrown from an initial height at a specific speed and angle. The context is projectile motion, where the rock's velocity is to be expressed as a function of time.
  • Participants discuss the need to find both the vertical and horizontal components of velocity, with some questioning how to approach the problem without numerical values. Others suggest using algebraic expressions and vector addition to represent the components.
The discussion is ongoing, with participants providing guidance on breaking down the problem into components and emphasizing the importance of understanding vector relationships. There is no explicit consensus on the final equation, and multiple interpretations of the approach are being explored.
Participants note that the statement about constant acceleration is incomplete, indicating that additional information may be necessary for a complete understanding of the problem.
MPH28
Okay so, a rock is throw from an initial height, ho, at a speed, vo, and an angle [theta] from the horizontal. Find the rocks velocity as a function of time.
Vxo=(Vo)(cos[theta])
Vyo=(Vo)(sin[theta])
Acceleration is constant.
Well I know that V(t)=Vo+at
But since the rock is thrown from an angle I got confused. Do I have to replace the Vo with the two equations for the x and y component of velocity? Since I can solve for Vo, but then it is equal to two different things.
Thanks!
Find the vertical component of the velocity and find the horizontal component of the velocity.
With the vertical component you can find out how long it takes for the ball to reach maximum height, where vf = 0
Then find out how high it rises and add the initial height from which it was thrown from and you will be able to get the total flight time.
How do I find out the components if I am not given any numbers?
You are not going to have a number as your answer. It sounds as if you will have an algebraic expression that includes the variable t for time.
You have the right start, certainly find the components in the x- and y- directions. Then treat them like vector and add them together. Note that your "acceleration is constant" statement is incomplete. You have a lot more information than that.
So is my final equation?:
v(t)=[(Vxo/cos[theta])+(Vyo/sin[theta])]+at
No. You'll need to draw a picture with the x- and y- component vectors. To find the magnitude, you'll need the pythagorean theorem. To find the angle (also a function of time), you'll need a trig identity.
