Projectile Motion: Solving for Time and Initial Velocity
The discussion focuses on solving projectile motion problems involving a cannonball fired at a 50-degree angle, landing 67 meters away. Key equations used include the range equation R = v^2 * sin(2*theta) / g and the time of flight equation t = 2*v*sin(theta)/g. The discussion emphasizes deriving these equations to find the initial velocity and time in the air, confirming that air resistance is negligible. The final expressions for distance and time are derived using trigonometric identities and calculus.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions and identities
  • Basic knowledge of calculus for derivatives
  • Proficiency in using kinematic equations
  • Study the derivation of the range equation for projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore advanced projectile motion scenarios, including varying launch angles
  • Investigate the application of calculus in physics, particularly in motion analysis
Students studying physics, educators teaching projectile motion concepts, and anyone interested in applying mathematical principles to real-world motion problems.
Unsettledchim
A cannonball is fired from the ground at an angle of 50 degrees. The ball lands 67 meters from where it was fired. Air resistance is negligible.
How long was the ball in the air?
With what velocity was the cannonball fired?
Xf=.5at2+Vot+Xo
Vf=at+Vo
Xf=.5at2+Vot+Xo
Vf=at+Vo
You will need the range equation:
R = v^2 * sin(2*theta) / g. Knowing theta and R (the range), solve for v.
The time in the air is given by t = 2*v*sin(theta)/g. You know v and theta, so solve for t. If you need me to derive these equations, let me know.
Thank you and yes that would be great if you could drive the equation
The total velocity can be written as components of the velocity in the x direction and in the y direction:
V(total) = sqrt(V(x)^2 + V(y)^2)
where V(x) = V(0)cos(theta) and V(y) = V(0)sin(theta)
In the x direction, the object travels the following distance (let's call it D(x), which is actually the range R in my last post):
D(x) = V(x)*t = V(0)cos(theta)*t
Our goal is now to find an expression for t, the time, and we can do that by examining the motion in the y direction:
D(y) = V(y)*t - (1/2)*g*t^2 = V(0)sin(theta)*t - (1/2)*g*t^2
Now take the derivative with respect to time and set it equal to zero. This will tell you the time at which the object's velocity in the y direction is zero. Practically, you're finding out when the object reaches the top of the parabolic curve (the greatest height in its motion).
D'(y) = V(0)sin(theta) - g*t = 0
Solve for t:
t = V(0)sin(theta) / g.
The time to complete the entire distance is obviously twice this:
t = 2V(0)sin(theta)/g.
Plug this t back into the D(x) equation to get:
D(x) = 2*V(0)^2*sin(theta)*cos(theta)/g
You can leave the equation in this form if you want, but making the trig substitution sin(2*theta) = 2sin(theta)cos(theta) makes it look nicer:
D(x) = V(0)^2sin(2*theta)/g
Thank you, that helped a ton, my physics teacher had not given us that equation.
  • · Replies 21 ·
