2nd order differential equation question
4 replies · 2K views
NEGATIVE_40
[tex]y''-3y'=4[/tex]
none
I've been looking at this problem for the last hour and have absolutely no idea on how to solve it.
My initial approach is this:
therefore [tex]r^2-3r=0[/tex] so [tex]r =0,~3[/tex]
giving a complementary solution of [tex]y_{c} = c_{1} +c_{2}e^{3x}[/tex]
Now this is the part where I think I might be making a mistake
[tex]y_{p} = 4A[/tex] (so I get any multiple of 4)
[tex]y_{p}' = 4[/tex]
[tex]y_{p}'' = 0[/tex]
So the particular solution is therefore [tex]0 - 3 \cdot 4 = 4[/tex] giving [tex]-12 = 4[/tex]
I can't think of another way to this, so any help would be appreciated :smile:
so ... my first particular solution would be [tex]y_p = Ax[/tex] ?
If I do this I get [tex]y_p = - \frac{4}{3}x[/tex]
so finally I end up with [tex]y= c_1 + c_{2}e^{3x} -\frac{4}{3}x[/tex]
which is the correct answer.
I think I understand what you said about the particular solution being a multiple of the complementary solution, but just to clarify.
Is this what you mean: I got [tex]c_1[/tex] being a part of the complementary solution (the r=0 part) , and you could mulitply this by some number to get A?
I think you got it, but just to be clear, let me reword it:
You have two complementary solutions, y1=e0x[/sub]=1 and y2=e3x. If you tried to use yp=A, it wouldn't be linearly independent of the complementary solutions because yp=Ay1.
that all makes sense. thanks for the help vela.
