2nd order differential - particular solution
3 replies · 8K views
W3bbo
[SOLVED] 2nd order differential - particular solution
a) Find the general solution of the differential equation:
[tex]\[2\frac{{d^2 x}}{{dt^2 }} + 5\frac{{dx}}{{dt}} + 2x = 2t + 9\][/tex]
b) Find the particular solution of this differential equation for which:
[tex]\[x = 3{\rm{ and }}\frac{{dy}}{{dx}} = - 1{\rm{ when }}t = 0\][/tex]
c) The particular solution in part b) is used to model the motion of a particle P on the x-axis. At time t seconds (t>=0), P is x metres from the origin O. Show that the minimum distance between O and P is
[tex]\[{\textstyle{1 \over 2}}\left( {5 + {\mathop{\rm Ln}\nolimits} \left( 2 \right)} \right)\][/tex]
N/A
[tex] \[<br /> \begin{array}{c}<br /> 2\frac{{d^2 x}}{{dt^2 }} + 5\frac{{dx}}{{dt}} + 2x = 2t + 9 \\ <br /> \\ <br /> x = e^{mt} ;\frac{{dx}}{{dt}} = te^{mt} ;\frac{{d^2 x}}{{dt^2 }} = t^2 e^{mt} \\ <br /> \\ <br /> 2t^2 e^{mt} + 5te^{mt} + 2e^{mt} = 0 \\ <br /> e^{mt} \left( {2t^2 + 5t + 2} \right) = 0 \\ <br /> t_1 = - {\textstyle{1 \over 2}} \\ <br /> t_2 = - 2 \\ <br /> \end{array}<br /> \][/tex]
Complimentary:
[tex]Ae^{ - 2t} + Be^{ - {\textstyle{1 \over 2}}t}[/tex]
Particular:
[tex] $\begin{gathered}<br /> x = at + b;\frac{{dx}}<br /> {{dt}} = a;\frac{{d^2 x}}<br /> {{dt^2 }} = 0 \\ <br /> \\ <br /> 2\left( 0 \right) + 5\left( a \right) + 2\left( {at + b} \right) = 2t + 9 \\ <br /> 5a + 2at + 2b = \\ <br /> 2b + a\left( {5 + 2t} \right) = \\ <br /> 2at = 2t \\ <br /> a = 1 \\ <br /> \\ <br /> 5a + 2b = 9 \\ <br /> b = 2 \\ <br /> \therefore \\ <br /> x = Ae^{ - 2t} + Be^{ - \tfrac{1}<br /> {2}t} + t + 2 \\ <br /> \end{gathered} $<br /> [/tex]
That's my solution to Part A, Mathematica agrees with me when I run:
Code:
In[1]:= DSolve[ 2y''[x] + 5y'[x] + 2y[x] == 2x+9, y[x], x  ]
Out[1]= y[x] -> 2 + x + e^(-x/2) * C[1] + e^(-2x) * C[2]
(Note y substituted for x, x substitued for t, C[1] for B, and C[2] for A.)
For part B, I got:
[tex] $\begin{gathered}<br /> x = Ae^{ - 2t} + Be^{ - \tfrac{1}<br /> {2}t} + t + 2 \\ <br /> 3 = Ae^{ - 2\left( 0 \right)} + Be^{ - \tfrac{1}<br /> {2}\left( 0 \right)} + 0 + 2 \\ <br /> 3 = A + B + 2 \\ <br /> 1 = A + B \\ <br /> \\ <br /> \frac{{dx}}<br /> {{dt}} = - 2Ae^{ - 2t} - \tfrac{1}<br /> {2}Be^{ - \tfrac{1}<br /> {2}t} + 1 \\ <br /> - 1 = - 2A - \tfrac{1}<br /> {2}B + 1 \\ <br /> \\ <br /> A = 1 - B \\ <br /> - 1 = - 2\left( {1 - B} \right) - \tfrac{1}<br /> {2}B + 1 \\ <br /> 0 = B \\ <br /> A = 1 \\ <br /> \\ <br /> \therefore \\ <br /> x = e^{ - 2t} + t + 2 \\ <br /> \end{gathered} $[/tex]
However this doesn't work with the last question (C), since the minimum of that function isn't located at ~2.84
Any ideas where I've gone wrong?
Thanks!
Find dx/dt and equate to zero and find the value for t that makes x a minimum(I got[itex]\frac{1}{2}ln2[/itex]).
sub that value into the Particular solution and it should work out.
I assume you mean dx/dt, not dy/dx.
N/A
[tex] \[<br /> \begin{array}{c}<br /> 2\frac{{d^2 x}}{{dt^2 }} + 5\frac{{dx}}{{dt}} + 2x = 2t + 9 \\ <br /> \\ <br /> x = e^{mt} ;\frac{{dx}}{{dt}} = te^{mt} ;\frac{{d^2 x}}{{dt^2 }} = t^2 e^{mt} \end{array}[/tex]
No, [itex]dx/dt= m e^{mt}[/itex] and [itex]d^2x/dt^2= m^2 e^{mt}<br /> [/quote][tex]\begin{array} 2t^2 e^{mt} + 5te^{mt} + 2e^{mt} = 0 \\ <br /> e^{mt} \left( {2t^2 + 5t + 2} \right) = 0 \\ <br /> t_1 = - {\textstyle{1 \over 2}} \\ <br /> t_2 = - 2 \\ <br /> \end{array}<br /> \][/tex]<br /> t is your variable- you trying to find values for m, the coeficient in the exponent.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Complimentary:<br /> [tex]Ae^{ - 2t} + Be^{ - {\textstyle{1 \over 2}}t}[/tex]<br /> <br /> Particular:<br /> [tex] $\begin{gathered}<br /> x = at + b;\frac{{dx}}<br /> {{dt}} = a;\frac{{d^2 x}}<br /> {{dt^2 }} = 0 \\ <br /> \\ <br /> 2\left( 0 \right) + 5\left( a \right) + 2\left( {at + b} \right) = 2t + 9 \\ <br /> 5a + 2at + 2b = \\ <br /> 2b + a\left( {5 + 2t} \right) = \\ <br /> 2at = 2t \\ \end{gathered}[/tex] </div> </div> </blockquote>[/itex]
[tex] I'm not sure why you would write it like that. 2at+ (5a+ 2b)= 2t+ 9 is simpler.<br /> <br /> [tex]\begin{gathered} a = 1 \\ <br /> \\ <br /> 5a + 2b = 9 \\ <br /> b = 2 \\ <br /> \therefore \\ <br /> x = Ae^{ - 2t} + Be^{ - \tfrac{1}<br /> {2}t} + t + 2 \\ <br /> \end{gathered} $<br /> [/tex]<br /> <br /> <br /> That's my solution to Part A, Mathematica agrees with me when I run:<br /> <br /> <div class="bbCodeBlock bbCodeBlock--screenLimited bbCodeBlock--code"> <div class="bbCodeBlock-title"> <i class="fa--xf fal fa-code "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1790607221#code"></use></svg></i> Code: </div> <div class="bbCodeBlock-content" dir="ltr"> <pre class="bbCodeCode" dir="ltr" data-xf-init="code-block" data-lang=""><code>In[1]:= DSolve[ 2y''[x] + 5y'[x] + 2y[x] == 2x+9, y[x], x ] Out[1]= y[x] -> 2 + x + e^(-x/2) * C[1] + e^(-2x) * C[2]</code></pre> </div> </div><br /> (Note y substituted for x, x substitued for t, C[1] for B, and C[2] for A.)[/tex]
[tex] Okay, so that is correct (since after finding "t<sub>1</sub>" and "t<sub>2</sub>" you actually used them for "m").<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> For part B, I got:<br /> <br /> [tex] $\begin{gathered}<br /> x = Ae^{ - 2t} + Be^{ - \tfrac{1}<br /> {2}t} + t + 2 \\ <br /> 3 = Ae^{ - 2\left( 0 \right)} + Be^{ - \tfrac{1}<br /> {2}\left( 0 \right)} + 0 + 2 \\ <br /> 3 = A + B + 2 \\ <br /> 1 = A + B \\ <br /> \\ <br /> \frac{{dx}}<br /> {{dt}} = - 2Ae^{ - 2t} - \tfrac{1}<br /> {2}Be^{ - \tfrac{1}<br /> {2}t} + 1 \\ <br /> - 1 = - 2A - \tfrac{1}<br /> {2}B + 1 \\ <br /> \\ <br /> A = 1 - B \\ <br /> - 1 = - 2\left( {1 - B} \right) - \tfrac{1}<br /> {2}B + 1 \\ <br /> 0 = B \\ <br /> A = 1 \\ <br /> \\ <br /> \therefore \\ <br /> x = e^{ - 2t} + t + 2 \\ <br /> \end{gathered} $[/tex] <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Yes, that is correct.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> However this doesn't work with the last question (C), since the minimum of that function isn't located at ~2.84<br /> <br /> Any ideas where I've gone wrong?<br /> <br /> Thanks! </div> </div> </blockquote> Unfortunately, you have left out the crucial calculations- why you say that doesn't work.<br /> With [itex]x= e^{-2t}+ t+ 2[/itex]. [itex]dx/dt= -2e^{-2t}+ 1[/itex] and that equals 0 when [itex]e^{-2t)= 1/2[/itex] so t= ln(2)/2. Putting that into [itex]x= e^{-2t}+ t+ 2[/itex], we have [itex]x= 1/2+ ln(2)/2+ 2= 5/2+ ln(2)/2, exactly as given.[/itex] </div> </div> </blockquote> </div> </div> </blockquote>[/tex]
My apologies, the way the question uses x for the function and t for the arg threw me off and I confused the derivative with the original equations.
Thing is, the minimum point on the plot is below zero, but isn't a negative distance still a positive displacement? So the minimum points would be zero and around 0.75. So isn't the question a little wrong in this respect?
But yours (and now my) answers are in line with the answer given, so thanks.
