3 blocks no friction forces question
The discussion revolves around calculating the forces acting on three blocks with varying masses. The initial calculations led to confusion regarding the forces exerted between the blocks, particularly between the 4 kg and 8 kg blocks. It was clarified that the force exerted by the 8 kg block on the 4 kg block is 13.14 N, with an equal and opposite force acting on the 8 kg block. The correct approach involves considering the net forces acting on each block to resolve the discrepancies in the calculations. Ultimately, understanding the interaction forces between the blocks is crucial for solving the problem accurately.
cmwilli
[PLAIN]http://img834.imageshack.us/img834/6920/captureqt.jpg
f=ma
Fsum=Fl + Fr=(m1+m2+m3)a
26+-8=(2+8+4)a
a=18/14=1.28571
f=ma
f=4(1.28571)=5.14268N
I know this is incorrect. The force of 4kg block pushes on the 8kg the same as the 8kg pushes on the 4kg, but the way I calculated it doesn't work with that but I know of no other way.
You are right that the resultant force acting on the 4 kg block is F=4a=5.143 N. See the figure: What forces act on this block?
ehild
The homework systems seems to disagree.
Call the blocks from left to right A,B,C
The way the teacher explained it in class, the force of C acting on B is the same as the force of B acting on C. But the way I calculated it Fc=4a but Fb=8a
Look at the 4 kg mass. There are two forces acting on it: the force from the 8kg mass (F8) ponting to the right, and Fr=8 N, pointing to the left. The resultant force points to the right, and it is F8-Fr=4*a. So F8=4a+Fr.
ehild
Is the correct answer then 13.14268N?
Yes, the 8 kg mass exerts 13.14 N on the 4 kg one, and a force of the same magnitude and opposite direction is exerted by the 4 kg mass on the 8 kg one.
ehild
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
