What Determines the Minimal Value in the Quadratic Form Equation?
  • Thread starter Thread starter nhrock3
    Function
The discussion focuses on determining the minimal value M in the quadratic form equation q(x,y,z) = 4(xy + yz + zx) such that q(x,y,z) ≤ M(x² + y² + z²). To ensure the bilinear form B(x,y,z) is positive definite, all eigenvalues must be positive, necessitating the calculation of the characteristic polynomial. The characteristic polynomial derived from the matrix representation leads to eigenvalues λ = M - 4 and λ = M + 2. The solutions indicate that for M to maintain positive eigenvalues, specific conditions must be met. The discussion emphasizes the importance of the characteristic polynomial in finding the minimal value M.
nhrock3
q:R^{3}->R is defined by q(x,y,z)=4(xy+yz+zx)
find the minimal M\in R so q(x,y,z)\leq M(x^{2}+y^{2}+z^{2})
why in the solution the calculate the caracteristic polinomial
why if (t+2) is in power 2 then we have -2 in two members of
the formula q(v) ??
our polinomial doesn't separated into different lenear member
so in order to find its jordan form we need to find the minimal polinomial
etc..
but in the solution they said it straight forward why??
why did they coose in the end to put eigen vaule iside?
why its minimal?
we could put a vector which not is 0.5
is it true that the as the eigen vectors would diagonolise A
so is their orthonormal basis whould show Q as in sum of squares
correct?
You want your bilinear form B(x,y,z)\equiv M(x^2+y^2+z^2)-q(x,y,z) to be positive definite. This is equivalent to all eigenvalues being positive. Therefore you need the characteristic polynomial. So you actually need to compute
P(\lambda)=|B-\lambda id_3|
B is given by
\begin{pmatrix} M & -2 & -2\\ -2 & M & -2 \\ -2 & -2& M \end{pmatrix}
So, you compute the characteristic polynomial of
\begin{pmatrix} M-\lambda & -2 & -2\\ -2 & M-\lambda & -2 \\ -2 & -2& M-\lambda \end{pmatrix}
Now, let's call t\equiv M-\lambda
Then you get the characteristic polynomial
(t-4)(t+2)^2
which has solutions t=4,t=-2, which means
\lambda=M-4, \lambda=M+2
Now, you go figure out for which M all eigenvalues are positive ;)
nhrock,
The image in your first post (at http://i42.tinypic.com/2a8hlpg.png) was way too large, and had a huge amount of whitespace at the bottom. Please edit the image using Paint or another image editing tool so that it is no larger than about 1200 x 800 pixels.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
