How can I design a 30-second lag time timer using a 555 timer?
  • Thread starter Thread starter big_tobacco
    Time Timer
This discussion focuses on designing a 30-second lag time timer using 555 timers or a 556 timer. The proposed solution involves configuring the timers in monostable mode, with one timing out at 30 seconds and the other at 40 seconds to control an LED output. For larger loads, the use of a time-delay relay is recommended. Participants also suggest considering alternatives from Microchip and ATMEL for more complex applications.
  • Understanding of 555 timer and 556 timer configurations
  • Knowledge of monostable timer operation
  • Familiarity with momentary switches (PTM/PTB)
  • Basic electronics concepts, including relay and triac operation
  • Research 555 timer monostable configuration techniques
  • Explore time-delay relay options for larger loads
  • Learn about Microchip and ATMEL timer alternatives
  • Experiment with breadboarding circuits for practical application
Electronics enthusiasts, hobbyists designing timing circuits, and anyone interested in practical applications of 555 timers and relay systems.
big_tobacco
Hello,
Please could you help me with this problem;
I need to design a timer whereby I briefly trigger it (using a push to make/push to break switch connected to a 6 v supply), there is a pause of 30 seconds and then it triggers with an output, say an LED - this stayes on for about 10 seconds then automatically extinguishes, after it has extinguished it then shuts off. It's only until I trigger the PTM/PTB switch again that the sequence begins all over.
Please, please help...I was hoping to possibly use a 555 timer(s) or something very simple.
Hope you can help :cry:
Regards
Push to make/push to break? I assume you mean a single pole single throw momentary switch?
If so, I would use 555 timers, or a single 556. Configure them monostable. Make one time out at 30 seconds, the other at 40 seconds. Hook the LED between the outputs, or buffered outputs.
Welcome to PF big_tobacco. I agree with Averagesupernova in using a couple of 555s or a 556 to generate your pulses but if you have any kind of large load to consider, you might want to use a
http://www.factorymation.com/s.nl;jsessionid=0a010c491f434401fa96817849d4a900c5c8249efc4a.e3eSc3aPaxmLe34Pa38Ta38NaNb0?sc=2&category=100" .
Maybe something from the Microchip http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=1009&mid=10&lang=en&pageId=74" families?
The ATMEL equivalent is the http://www.atmel.com/dyn/products/devices.asp?family_id=607#791" family.
They *are* simple--it's just that it's simple software instead of simple hardware.
EDIT: But yeah, if you have any kind of large load, go with the time-delay relay as dlgoff recommends. On the other hand, depending on what sort of expertise you have, you *could* drive a triac or relay.
Brilliant, thank you very much for your help. I think this weekend I'll crack out the bread-board and give these a try!
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
11K
14K
