Question About Shear Stress Naming Convention
The discussion centers on the naming convention of shear stress \(\tau_{ij}\) in the context of a cylindrical shaft subjected to torque. Participants clarify that the indices \(i\) and \(j\) represent the normal direction and shear direction, respectively, and emphasize the importance of analyzing differential elements rather than the entire cross-section. The shear stress induced by a clockwise torque \(T\) on a shaft aligned with the z-axis is specifically identified as \(\tau_{z\theta} = \tau_{\theta z} \propto T\). Misinterpretations arise when attempting to apply definitions to the entire cross-section instead of focusing on differential elements.
  • Understanding of shear stress and its notation, specifically \(\tau_{ij}\)
  • Familiarity with cylindrical coordinate systems
  • Knowledge of torque and its effects on materials
  • Basic principles of stress analysis in mechanics
  • Study the mechanics of materials, focusing on shear stress analysis
  • Learn about differential elements in stress analysis
  • Explore cylindrical coordinates in the context of mechanical engineering
  • Review torque effects on circular shafts and related shear stress equations
Mechanical engineers, materials scientists, and students studying mechanics of materials who seek to understand shear stress naming conventions and their applications in cylindrical structures.
Saladsamurai
Question About Shear Stress "Naming" Convention
I cannot seem to find this in any of my texts.
For a shaft of circular cross-section, how do you name the shear stress \tau_{ij} caused by a Torque?
That is, how do you assign the indices i j ? Is it the plane that contains the cross-section?
That is the only way I can make any sense of it.
Silly question, but it is driving me nuts.
Why would it be any different than normal?
None of your text show a 3D infinitesimal element?
http://ic.ucsc.edu/%7Ecasey/eart150/Lectures/Stress/Fig3.6.jpg
In this naming convention, the taus are the off diagonal elements.
I always remember it as...and this is just me...
\tau_{ij} = in the "j" axis direction, perpendicular to "i" axis.
Since this is a cylindrical shaft, wouldn't it be easier to use cylindrical coordinates? That could be the origin of the OP's question...
That doesn't change things because a differential element in cylindrical coordinates looks like a square.
It really is the same thing, but if cylindrical coordinates are what one wants to deal with then how about this...
http://web.mse.uiuc.edu/courses/mse280/Handouts/Example_Stress_Cyl_Coord.pdf
Perhaps I am either wording this incorrectly, or I am more confused than I thought.
I was told by my instructor that when speaking of a shear stress \tau_{ij} that i is the direction normal to the plane, and j is the direction of the shear.
That description doesn't make sense to me. But that might be because I am applying that definition to the entire cross section instead of just a differential element.
Let's take an example. If a torque T is applied clockwise to a cylindrical shaft whose longitudinal axis coincides with the z-axis. How do we name the shear stress that is induced?
If you look at the entire cross section, z is normal to the plane but in which direction do you say the shear acts? Does it even make sense to ask that question since it acts in ALL directions tangent to any radial distance?
If you look at a differential element at the top of the shaft then we can certainly assign a direction to the shear, i.e., to the "right" in the x-direction.
Is my question any clearer? Is that definition that I was given in naming tau correct? I think it only makes sense when talking about an element of the shaft.
Thanks :smile:
"That description doesn't make sense to me. But that might be because I am applying that definition to the entire cross section instead of just a differential element."
Stress states are defined for differential elements so that equilibrium is met.
You tried to define a single stress state for the entire cross sectional area. This resulted in some craziness that certainly didn't jive with your intuition.
The torque induces a shear stress \tau_{z\theta}=\tau_{\theta z}\propto T, as cristo indicated.
That's what I thought :smile: My confusion stemmed from my misinterpretation of the definition.
