3D Equilibrium Statics Problems
The discussion focuses on solving a 3D equilibrium statics problem involving the calculation of reactions at point O due to tensions in cables BA and BC, specifically T(BA) = 700 N and T(BC) = 800 N. The problem emphasizes the use of vector analysis to determine the force components and their projections. It highlights the geometric relationship between the triangle OBC and the force components, indicating that there are three reaction components at O, with My being zero due to the alignment of forces.
  • Understanding of 3D equilibrium statics principles
  • Proficiency in vector analysis and projections
  • Familiarity with tension forces in cables
  • Knowledge of geometric relationships in triangles
  • Study vector projection techniques in 3D statics
  • Learn about calculating reaction forces in static equilibrium
  • Explore the principles of force components in cable systems
  • Review geometric relationships in triangle problems related to statics
This discussion is beneficial for students and professionals in engineering, particularly those focusing on structural analysis, statics, and mechanics. It is also useful for anyone preparing for exams involving 3D equilibrium problems.
tamara1025
I'm so stuck on this problem. I got it completely wrong on my test because I don't even know where to start. All i recall is that we mus use the vector approach? The problem states:
For the figure shown, calculate the reactions at point O due to the tensions in the two cables BA and BC. T(BA)=700 N, T(BC)=800 N. Assume that the tree is rigidly fixed to the ground.
Vectors or not, there has to be a similarity between the geometrical triangle OBC and the force components on the cable BC. To get the force components in terms of ijk, you need to project OC onto the x-axis. Let's call it OC'. Then the geometric distances BO, OC', and C'C are in the same ratio as the force components of the 800 N force. There should be as many as 3 reaction components at O that are forces, and three that are moments, although My will be zero by inspection because the forces both seem to pass through it.
10K
