Efficient 3D Inverse Fourier Transform on FORTRAN Code with Chi Array
The discussion focuses on optimizing a 3D Inverse Fourier Transform (IFT) implemented in FORTRAN using an array called Chi. Participants recommend utilizing the FFTPACK library for efficient computation, emphasizing that rewriting FFT algorithms is unnecessary outside of educational contexts. Key improvements include manipulating arrays en masse to enhance performance and reducing redundant calculations in initialization loops. The suggested code modifications can significantly speed up the execution of the IFT process.
  • FORTRAN programming, specifically array manipulation
  • Understanding of Fourier Transform concepts
  • Familiarity with FFTPACK library for Fourier Transforms
  • Basic knowledge of complex numbers and their operations
  • Implement FFTPACK for 3D complex to real transformations
  • Learn advanced array manipulation techniques in FORTRAN
  • Explore optimization strategies for numerical algorithms
  • Study performance profiling tools for FORTRAN code
Researchers, physicists, and engineers working with numerical simulations in FORTRAN, especially those needing to optimize Fourier Transform computations.
Ben Wilson
Hi, I have a FORTRAN code with an array called Chi that I want to run an inverse FT on. I have defined two spaces X and K which each consist of 3 vectors running across my physical verse and inverse space.
My code (If it works??) is extremely slow and inefficient (see below). What is the best way of doing a 3D IFT computationally?
CODE
!Real & Inverse Spaces
do i1 = 1, 2*No_x +1
x_x(i1) = -L/2.d0 + dx*(i1-1)
x_y(i1) = -L/2.d0 + dx*(i1-1)
x_z(i1) = -L/2.d0 + dx*(i1-1)
xi_x(i1) = (i1-(No_k+1))*(2.d0*pi/L)
xi_y(i1) = (i1-(No_k+1))*(2.d0*pi/L)
xi_z(i1) = (i1-(No_k+1))*(2.d0*pi/L)
end do
chi = blablabla
!chi is a function of xi
!3d IFT
do r1 = 1,2*No_x +1
do r2 = 1,2*No_x +1
do r3 = 1,2*No_x +1
chi_ift(r1,r2,r3) = 0
do i1 = 1,2*No_k +1
do i2 = 1,2*No_k +1
do i3 = 1,2*No_k +1
chi_ift(r1,r2,r3) = chi_ift(r1,r2,r3) + chi(i1,i2,i3)*exp(imagi*xi_z(i3)*x_z(r3))
end do
chi_ift(r1,r2,r3) = chi_ift(r1,r2,r3) + chi(i1,i2,i3)*exp(imagi*xi_y(i2)*x_y(r2))
end do
chi_ift(r1,r2,r3) = chi_ift(r1,r2,r3) + chi(i1,i2,i3)*exp(imagi*xi_x(i1)*x_x(r1))
end do
end do
end do
end do
Reply Reply to All Forward More
Click to Reply, Reply all or Forward
Definitely you should use a standard library like FFTPACK. Unless it is a classroom exercise you should not be rewriting FFT algorithms.
Well, for popular algorithms, what Dale said.
Other than that, you need to learn to manipulate arrays en masse, a-la-matlab, whenever possible. This tells the compiler that assignments can be done in any order and without having to carefully traverse one index at a time, or switching from evaluating one array and then another and loop again.
You initialization do-loop above, can be made at least 3 times faster by not having to repeat the calculations; an even faster if you forget the loop altogether:
Code:
n=2*No_x+1
iarr(1:n) = (/ (i1-1, i1=1,n) /)
x_x(1:n) = -L/2.0 + dx*iarr(1:n)
x_y(1:n) = x_x(1:n)
x_Z(1:n) = x_x(1:n)
xi_x(1:n) = ( iarr(1:n) - No_k )*2.0*pi/L
xi_y(1:n) = xi_x(1:n)
xi_z(1:n) = xi_x(1:n)
Likes Ben Wilson
Code:
n=2*No_x+1
x_y(1:n) = x_x(1:n)
x_Z(1:n) = x_x(1:n)
i'll give this a whirl
hey I'm a really crummy programmer. Which subroutine do I use and how do I implement it (given I'm doing a 3d complex to real transform)?
  • · Replies 18 ·
  • · Replies 54 ·
17K
