3D Harmonic Oscillator Circular Orbit
The discussion centers on the radial probability density in the context of a 3D harmonic oscillator, specifically referencing Binney's text. It clarifies that the radial probability density is indeed the square of the normalized wavefunction, |ψ(x)|², but includes an additional factor of r² due to the integration over spherical coordinates. This factor arises from the volume element in spherical coordinates, which incorporates r²dr. The integration process separates the angular and radial components, confirming the necessity of the r² factor in calculating probability. Overall, the explanation aligns with the mathematical framework of quantum mechanics.
unscientific
I found this in Binney's text, pg 154 where he described the radial probability density ##P_{(r)} \propto r^2 u_L##
Isn't the radial probability density simply the square of the normalized wavefunction, |ψ(x)|2? Why is there an additional factor of r2?
When you integrate a function over a volume in spherical co-ordinates you integrate over r2sin(θ)drdθdø . The sin(θ)dθdø goes into the angular function and the r2dr into the radial function. I believe this is where it comes from.
Likes 1 person
Probability = ##<\psi|\psi> = \int \psi^*\psi d^3r = \int \psi^*\psi r^2 dr d\Omega##
Where the wavefunction corresponding to the ket ##|\psi>## is ##u_L Y_l^m##
I think that's right.
Correct.
  • · Replies 22 ·
