Understanding Bed Leveling and Z-Calibration for 3D Printers
  • Thread starter Thread starter fog37
    3d
This discussion clarifies the concepts of bed leveling and Z-calibration in 3D printing. Bed leveling ensures that the extruder tip maintains a constant vertical distance from the print surface across all X and Y coordinates, rather than being level with the ground. Z-calibration is achieved through a 9-point test, ensuring the extruder tip is approximately 100 microns above the print surface. The origin point for the extruder tip is typically set at the front left corner of the print bed, although this is largely arbitrary as slicer software compensates for its location.
  • Understanding of 3D printer mechanics and operation
  • Familiarity with Z-calibration techniques
  • Knowledge of CNC software and its coordinate systems
  • Experience with bed leveling tools, such as micrometer gauges
  • Research the use of spring-loaded micrometer gauges for bed leveling
  • Learn about different Z-calibration methods and their effectiveness
  • Explore CNC software settings for defining the origin point
  • Investigate the functionality and setup of autoleveling sensors in 3D printers
This discussion is beneficial for 3D printer operators, hobbyists, and technicians looking to improve print quality through proper bed leveling and Z-calibration techniques.
fog37
TL;DR
leveling 3D print surface for correct printing
Hello,
I am dealing with bed Leveling and calibration (I guess they are the same process) of my new 3D printer and I realized I am shaky on a few basic concepts:
  • Leveling: bed leveling does not mean that the building platform is leveled with respect to the ground, which is what a bubble level would measure...The print bed becomes correctly leveled when the extruder tip remains at a constant vertical distance Z away from the print surface as the extruder tip position, ideally for all possible X and Y coordinates, is moved across the printing surface and over all its points. The print bed may not be "leveled" using the bubble level but be "leveled" relative to the transverse motion of the extruder tip which, I guess, has its height automatically adjusted as the tip is scanned over the surface to maintain it at a constant height...Is that correct?
  • Z-calibration: I know that, for Z=0, the extruder tip is not actually touching the print surface but should be at nonzero vertical distance (~100 micron across all (X,Y) points on the bed). That is the Z-calibration which I think is accomplished via a 9-point test: the vertical extruder tip distance is checked and adjusted for 9 different and I guess all points in the area enclosed by those 9 points will also be Z-calibrated automatically...
  • Origin: where should the extruder tip be located with it is located at the origin O, the position with coordinates (X,Y,Z)= (0,0,0)? Should the origin O be at the center of the print bed? Or at the front left corner of printing bed?
Thank you!
Computer science news on Phys.org
fog37 said:
Summary:: leveling 3D print surface for correct printing
Hello,
Thank you!
Levelling is usually done by attaching a spring-loaded micrometer gauge instead of extruder, and checking if it reads the same across whole bed. You can adjust bed level with set bolts, planing/sanding or epoxy coating, depending on details of your construction.
Most CNC software place origin in front left corner of the bed. It is a bit arbitrary though.
Thank you trurle. I guess the origin O location, the home position, does not matter because the slicer accounts for that.
My printer has an autoleveling sensor...
