Troubleshooting 3D Vector Work: Solving Angle and Displacement Confusion
  • Thread starter Thread starter hehedxd
    3d Vector Work
The discussion focuses on solving a physics problem involving work done by a force vector along a displacement vector. Participants clarify that the displacement is calculated as the difference between the initial and final position vectors, specifically from A(1,-4,5) to B(2,-1,3), resulting in a displacement vector of (1,3,-2). The work done is determined using the dot product of the force vector and the displacement vector, emphasizing that the angle between them is not necessary for the calculation. The conversation highlights the importance of correctly identifying the vectors involved and using the dot product to find the work done. Ultimately, the participants reach a consensus on the method to solve the problem effectively.
hehedxd
A 5 N force which is along the direction vector (2,3,4) moves an object from A(1,-4,5)
to B(2,-1,3). What is the work done?
Dot product
W = F x d
I'm having trouble finding the angle and displacement
hehedxd said:
Homework Statement:: A 5 N force which is along the direction vector (2,3,4) moves an object from A(1,-4,5)
Relevant Equations:: Dot product
W = F x d
The displacement is ##A## to ##B##, isn't it? Do you really need the angle?
How would you find the displacement?
Also what do you do with the direction vector?
I would ask myself how do I get from ##A## to ##B##. I assume we are talking about a straight line path here.
I don't know what a "direction" vector is. There is a force vector and a displacement vector here.
Using 'x' is misleading. You want a _dot_ product.
Hint: you don't need to find any angles.
So i disregard the first vector given in the problem and get the dot product of a and b?
No, you need the dot product of the force and displacement vectors:
$$W = \vec F \cdot \vec d$$
A and B are the starting and stopping points of the thing being pushed. Work is done by the force acting over that displacement.
What is the displacement vector @hehedxd ?
I think its the vector along which the force acts.
No, the displacement vector is the difference between the final position vector and the initial position vector. You have both given as A and B. Can you compute it?
Likes PeroK
No can you help me
The initial position vector is ##\vec A=(1,-4,5)## and the final position vector is ##\vec B=(2,-1,3)##. The displacement vector is ##\vec s=\vec B-\vec A##. Can you compute it?
ok I got s = (1,3,-2) thanks
Great! Now, what you want is ##W=\vec F\cdot\vec s=Fs\cos\theta##.
The problem statement is telling you that the force is in the direction of the vector ##(2,3,4)##, so we know that the angle between ##\vec F## and ##\vec s## is the same as the angle between ##(2,3,4)## and ##\vec s##.
Can you find that angle?
Wait I thought we didn't need angle.
I was going to find the vector that represents the force and use dot product
To find the angle, you could always first compute the dot product! :wink:
Sure, you can also do that.
Yes, I was trying to lead him to that!
Ok thanks I got it now
Likes archaic
  • · Replies 19 ·
  • · Replies 56 ·
  • · Replies 38 ·
