4 four momentum energy component direction
In summary, four-momentum is a vector with four components: three spatial momentum components and one time energy component. The energy component points in the timelike direction, which signifies the direction of time in a 4D spacetime continuum. The components of a vector refer to the weights of the unit basis vectors, and the directions of the basis vectors represent physical quantities. This unifies energy and momentum, as the conservation of the momentum four-vector includes the conservation of mass, energy, and momentum. While it may seem like a mathematical trick, it accurately represents the relationship between energy and time in relativity.
whatif
87
I have been reading about four momentum. There are four component vectors, three spatial, momentum, components and a time, energy, component. They each have a direction. I understand direction for the momentum components, being in the direction of the respective spatial components of the velocity of an object. I understand that as a component vector the energy has direction. However, I do not understand how to interpret the direction of the energy component and I have not seen an explanation. Does it mean that energy is in the direction of time and if so, is that meant to be so obvious that no one seems to explain it? Alternatively, is it just a mathematical attribute that works and has no particular physical association?
Yes, the mass-energy component points in the timelike direction - although that's actually sort of backwards - it's probably better to say the we identify the timelike component with the mass-energy.
An easy way to see that the mass-energy component points in the timelike direction is to consider an object at rest. The four-momentum is tangent to the object's worldline and the three momentum components are zero; therefore the fourth component must point in the direction of the worldline.
No. The components of a vector are not vectors. They are numbers. They don't have a direction.
You seem to be confusing components of a vector with basis vectors. When we choose a coordinate system to describe spacetime, that coordinate system defines four basis vectors at each point. These are (at least for the case of flat spacetime and inertial coordinates that we're discussing) four mutually orthogonal unit vectors, i.e., they each have length 1 (note that we are here using units where ##c = 1##, which are the natural units to use in relativity) and they point in four mutually orthogonal directions. It's fairly simple to show that three of those directions must be spacelike and the fourth must be timelike. The three spacelike basis vectors point in three mutually orthogonal spatial directions, like the basis vectors of a standard Cartesian coordinate system in ordinary 3-dimensional Euclidean space. The timelike basis vector points into the future.
Given a set of four basis vectors, any vector at all can be expressed as a weighted sum of the four basis vectors. The weights of each basis vector in the sum are the components of the vector. (Note that this means that a vector's components depend on the coordinates you choose.)
The 4-momentum is a vector, so it can be expressed this way just like any other vector. The three spatial components (i.e., the coefficients that multiply the three spacelike basis vectors) are the components of the 3-momentum (i.e., ordinary momentum), and the time component (i.e., the coefficient that multiplies the one timelike basis vector) is the energy.
Likes Imager and lomidrevo
Reference https://www.physicsforums.com/threads/4-four-momentum-energy-component-direction.964058/
Thank you. I understood that it is in the timelike direction. My difficulty is interpreting what that physically means, especially coming from thinking that energy is a scalar quantity. I do not have the same problem with momentum.
I do not think so. It is a question of language. I would think that a weighted vector is a vector. I am not arguing. If the word ‘components’ of vector must conventionally strictly refer to weights of the unit basis vectors then I will go along with that.
If you accept the concept of spacetime, as a 4D continuum of time and space, then time has a direction. And vectors representing physical quantities will have four components. The four-momentum, for example.
You can think of four-vectors as a mathematical trick, but I think that's an overly Newtonian viewpoint. You cannot convert momentum from one frame to another without using the energy (time component). And, in fact, the conservation of the momentum four-vector encapsulates the conservation of mass, energy and momentum, which are three separate conservation laws in Newtonian mechanics. From that point of view, it's a unification of energy and momentum.
Yes, that is what the word "components" means. I don't think there is a conventional term for the "weighted vectors", but since your main concern seems to be with direction, not magnitude, you can just think of the directions of the basis vectors and it will come to the same thing.
It means that the timelike basis vector points into the future, just as I said before. "Into the future" is a direction since we're talking about spacetime.
So are each of the components of momentum. But energy times the timelike basis vector is, as you note, a vector quantity (for which there is not, as I noted before, a conventional name that I'm aware of), just as each momentum component times its corresponding spatial basis vector is a vector quantity. All of these things work the same in relativity.
I am neither claiming it is not discounting that it may be (and I would not mean that disparagingly). It may be that it is too difficult for me to interpret what that physically means but it is noteworthy to me that no one attempts to explain it like some do with momentum.
You are implying that the energy component must be treated as a vector. I have to take your word for that because I am not experienced to know the intricacies of different coordinate systems. On the face of it, at my basic level of understanding, mass (rest mass) is invariant between frames, spatial velocities can be transformed so that momentum (spatial component) can be transformed and time always points in the same direction so that energy can, in principle, be treated as a scalar quantity. Is that just wrong?
That corresponds to a yes to my first question. I accept that. My question was prompted because energy having a direction into the future is a somewhat nebulous concept to me, together with that not being explicitly addressed when introduced, prompted my question.
whatif said:
I am neither claiming it is not discounting that it may be (and I would not mean that disparagingly). It may be that it is too difficult for me to interpret what that physically means but it is noteworthy to me that no one attempts to explain it like some do with momentum.You are implying that the energy component must be treated as a vector. I have to take your word for that because I am not experienced to know the intricacies of different coordinate systems. On the face of it, at my basic level of understanding, mass (rest mass) is invariant between frames, spatial velocities can be transformed so that momentum (spatial component) can be transformed and time always points in the same direction so that energy can, in principle, be treated as a scalar quantity. Is that just wrong?
You really need to sort out the difference between a component of vector, which is a number, and a vector, which is an array of numbers.
As has been said before, energy is the zeroth or time component of the energy momentum four-vector, but that does not make energy a vector. Nor does it give energy a direction.
Likes lomidrevo
No, it doesn't. The timelike basis vector points into the future. That doesn't mean the energy points into the future. You could say that the vector you get when you multiply the energy times the timelike basis vector points into the future, but that vector is not the energy. Energy doesn't have a direction, and "the direction of time" (i.e., "into the future") is not the energy, or the direction of the energy.
Yes.
Not by themselves; you have to transform all four components of a 4-vector together. See further comments below.
No, it doesn't. More precisely, the timelike basis vector doesn't always point in the same direction. Nor do the spatial ones. It might help to work through this in more detail.
In ordinary Cartesian coordinates in ordinary 3-dimensional space, you can rotate the coordinates, which changes the directions in which the basis vectors point. The components of all vectors change when you transform them from one set of coordinates to the other.
In 4-dimensional spacetime, a Lorentz transformation--a change of inertial frames--works similarly: it changes the directions in which the basis vectors point. But now we have to include the timelike basis vector in this; in other words, changing inertial frames changes which way the timelike basis vector points, as well as the spatial ones. Actually, a pure Lorentz transformation--what you'll often see called a "boost" in the literature--only changes the direction in spacetime of one spatial vector, the one that points in the direction of relative motion between the two frames.
But there is a key difference, intuitively speaking, with a Lorentz transformation. Note that I said above "direction in spacetime", not "direction in space". A pure boost does not "mix" directions in space: it only changes the direction in spacetime of one spatial basis vector, leaving the other two spatial basis vectors alone. But it also changes the direction in spacetime of the timelike basis vector. You can see an illustration of how this works here:
https://en.wikipedia.org/wiki/Minkowski_diagram#Minkowski_diagrams_in_special_relativity
If you look at the first diagram on the right in that section of the article, the black axes are the ##t## and ##x## axes (the ##x## direction is the direction of relative motion) before the transformation, and the blue axes are after the transformation. Note that the axes "tilt" towards each other, instead of staying at 90 degrees in the diagram as a normal spatial rotation would do. That's because the geometry of spacetime is not Euclidean, it's Minkowskian (the minus sign in the metric). But the point is that both axes change direction in spacetime (spacetime here is just the diagram as a whole) in the transformation, so both the ##t## and the ##x## components of vectors have to change.
The term "scalar quantity" is ambiguous. Strictly speaking, a "scalar" in relativity (more precisely, a "Lorentz scalar") is a quantity that's just a number (no direction) and doesn't change when you change frames. So rest mass is a scalar, on this strict definition, but energy is not. Energy is just one component of a 4-vector, and transforms like all vector components when you change frames.
Likes PeroK
Yes, energy is in the direction of time. Often it will be described as the timelike component of the four momentum or the 0th component where previously that component has been associated with time.
In different reference frames the time basis vector points in different directions. So energy is not a scalar, it is a component of a vector. In relativity, the term scalar is reserved for things that are invariant under a change in the coordinates. So the components of a four-vector are not scalars since they do change as coordinates change. Clearly energy is different in different frames, so it is not a scalar.
I apologise. I am just so used to treating vectors as things with magnitude and direction, and a vector being comprised of other vectors added to together (components), a common definition and usage, and not having the restriction on what is meant by the word component.On the other hand, a book about spacetime physics by Taylor and Wheeler that I think a colleague of yours suggested I read, seems to use language somewhat aligned to the way I am using it especially under the title “What is a 4-Vector?” and in a diagram that uses arrows to show the direction of the momenergy vector being the direction of the world line; including the case when momentum is zero.
I am glad to hear it and I think I am getting the picture. I asked the question because other literature seemed to suggest otherwise and I did not know how to interpret it.
If you look at the first diagram on the right in that section of the article, the black axes are the t'>tt and x'>xx axes (the x'>xx direction is the direction of relative motion) before the transformation, and the blue axes are after the transformation. Note that the axes "tilt" towards each other, instead of staying at 90 degrees in the diagram as a normal spatial rotation would do.
I get the Minkowski diagram. I get the point you are making about transforming 4 vectors. It did not quite address the point I was trying to make and raises more questions but that energy does not have direction is enough.
Thank you.
Thank you, but I am clearly getting different opinions about that.
Likes PeroK
As you go from flat geometry to curved geometry you start to have to distinguish more carefully some distinct concepts that can get mixed up.
A vector is a geometric object which is a member of a vector space. A vector space has notions of addition of two vectors and multiplication of a vector by a real number to get a vector and multiplication of two vectors to get a real number. A vector space can be equipped with (orthonormal) basis vectors and then any vector in the space can be formed as a linear combination of the basis vectors. The real numbers that multiply the basis vectors are called components. Sometimes, sloppily, the product of the component and the respective basis vector is also called a component, but I believe that should be called the projection. Because the usage I s sloppy it can be hard to tell if someone is referring to the real number or the product of the real number and the basis vector.
I suggest the acid test is a measurement of energy which gives a single number of Joules or electron-volts. That's not a vector.
A measurement of momentum, however, has three components (or projections) and therefore momentum is a three-vector.
I've never heard of energy being called a one-vector, although I guess there's nothing to stop someone coining that term.
Dale said:
RFrom https://phys.libretexts.org/Bookshelves/Relativity/Book:_General_Relativity_(Crowell)/4:_Tensors/4.2:_Four-vectors_(Part_1) there is a whole section titled “Energy is the timelike component of the four momentum”. I am sure that many other references state something similar, but this one is an easily accessible and very good book by an author I trust.
On the other hand, the energy of a particle can be defined as the scalar product of the particle's four-momentum and the observer's four-velocity. And a scalar product has no direction.
Likes PeterDonis
That presupposes energy does not have a direction and so side steps my question. As a novice to relativity I am not making that assumption. There are explanations that indicate that that energy has direction. If I were to make that assumption it would seem to contradict anyone that expresses that four momentum points in the direction of the world line; including Taylor and Wheeler.
On the other hand, there is a kind of logic with using arrows to show momentum and direction. I imagine this is deceptive. I assume momentum has direction, but the energy ‘arrow’ is only representative of magnitude.
That also goes somewhat to my question. To a novice, like myself, it may appear energy is being treated as a one vector and I ask myself what the point of that would be. That goes to why I do not discount a mathematical ‘trick’.
You should read again all the responses given to you. You are still confused about the difference between a vector, which has a magnitude and a direction, and a component of a vector, which is just a single number. Energy is the timelike component of the momentum 4vector. No mystery there...
Likes PeroK
I do not think so and I do not see how that has any relevance to what I wrote about the “acid” test. I am ready to accept that energy does not have direction. Let me tackle this another way:
Taylor and Wheeler write that 4 momentum has the same direction as the world line of an object. A reference frame shows the world line of that object. Where/”while” that object is spatially stationary it only goes in the time direction. The object has no spatial momentum and only rest mass energy. Taylor and Wheeler use arrows to show 4 momentum and, in this circumstance, they show an arrow pointing in the time direction only and associate the rest mass energy with the arrow. Why does 4 momentum just point in the time direction in this circumstance? Are Taylor and Wheeler right or wrong?(e.g. perhaps 4 momentum points in the direction of time and the just the magnitude of 4 momentum is just the energy of 4 momentum in this circumstance).
whatif said:
I Taylor and Wheeler use arrows to show 4 momentum and, in this circumstance, they show an arrow pointing in the time direction only and associate the rest mass energy with the arrow. Why does 4 momentum just point in the time direction in this circumstance? Are Taylor and Wheeler right or wrong?
##E \ne (E, 0, 0, 0)##
The left-hand-side of that equation is defined as the energy. You could define the energy of a particle as ##(E, 0, 0, 0)##, but that would not be the standard definition of energy. That would be your own definition of energy. Whenever any other physicist talks about "energy", you would say "magnitude of energy" etc. It would simply be different terminology.
Likes SiennaTheGr8, lomidrevo and Ibix
The length of that arrow is always the rest mass. In a frame where an object is at rest, this is also the total energy of the object.
It always points in a time direction - the direction used by its rest frame. In the case where the diagram shows its rest frame, then, it points in the direction the diagram uses as time.
PeroK's last post sums it up neatly. In most coordinate systems the energy is the number multiplying the time-like basis vector. It is not itself a vector. It is always positive, so does not even have a direction in the sense of possibly being negative.
Likes PeroK and lomidrevo
They are correct. But energy is still only the 0th component of that 4-vector. I don't think that they would claim in text that whole 4 momentum ("including direction") represents energy of the particle.
You are on the right track here...
That clears it up nicely.
That is correct, I never said they did and going back they actually wrote the right thing. However, they had diagram that was suggestive of energy being a vector and they did treat some things as obvious that to me, were not so obvious.
Now, I could ask what sense is to be made of kilograms moving in the time direction. If I am taking things to be obvious and not requiring explanation then 4 momentum has units of mass. The component of the time direction is the energy of the object; energy being the sole contributor to the time component. Momentum and energy were united as a 4 vector by mathematically giving them the same units. However, relativity theory still distinguishes between momentum and energy (as it does between time and spatial distance). While I appreciate the distinction between a component and a vector direction, lack of an explanation somewhat blurs the distinction between the vector time direction and its component, in my mind, (not whether it is a component but whether energy is a vector direction of 4 momentum). Energy is not momentum just as spatial distance is not time, despite distance and time being measured it the same units for the purpose of unification. The derivation of energy as the time component has nothing to say that it is not a vector, as far as I can see. It may justify energy being called a one vector, not that I am advocating it, or it may justify calling it a mathematical trick.
This might lead us back to square one so just saying and let's not go there.
whatif said:
That reference does not seem to have anything to say about energy having direction.
It says “Timelike component”. How you want to interpret that wrt your question is up to you. It is reasonable to say that the timelike component is a real number with no direction and it is reasonable to say that a timelike component is a projection on the timelike basis vector so it points in the direction of time. Choose your preference as you will.
The four momentum is ##P=(E,p_x,p_y,p_z)=E\hat t+p_x \hat x+p_y \hat y + p_z \hat z##. You can say that ##E## points in the ##\hat t## direction just as you might say that ##p_x## points in the ##\hat x## direction.
  • #31
Energy and momentum are different quantities, of course. The reason why 4 vectors are introduced in relativity, is not just to have a common units. What is far more important is that time and space individually do not transform properly under Lorentz transformation. You have to transform them together. Hence it becomes natural to talk about spacetime, and to define position 4-vector, where the 0th component represent the timelike coordinate of an event. But you still keep in mind that space and time are not the same, as you know intuitively. The same applies to energy and momentum. They cannot be properly transformed individually, but if you define a 4-vector, which you construct using the classical 3D momentum of a particle plus using its energy as the 0th component, the whole new beast will transform properly under Lorentz transformation. I don't see any reason why we should regard energy as having any direction...
Likes PeroK
  • #32
If you understand spatial basis vectors, then specifying three spatial basis vectors, for instance the spatial basis vectors of an observer "at rest" in some coordinate system in the Minkowskii space of special relativity, uniquely define one time-like vector that is orthogonal to all three spatial vectors.
Hopefully the notion of orthogonality is familiar. Formally, two vectors are orthogonal if their dot-product is zero. And hopefully the notion of the dot-product of four-vectors is familiar. If not, I would guess a review is in order, I'm not sure how to explain things further without using these concepts.
A note on terminology here, to avoid confusion. We usually say "space-like" vectors as an adjective when we talk about four-vectors rather than "spatial" vectors. Then a "purely spatial" four-vector would be a four-vector with no component in the time "direction".
The mathemtics then are that specifying three space-like vectors mathematically defines a unique time-like vector that's orthogonal to all of the space-like vectors. Similarly, if we define a time-like vector, we can determine three space-like vectors that are orthogonal to the time-like vector, and to each other. However, this set of space-like vectors with this property is not unique because of the existence of spatial rotations. Performing purely spatial rotations of the three space-like vectors will generate a different set of space-like vectors that meet our orthogonality conditions.
Thus specifying a set of three space-like vectors automatically specifies a time-like vector that's orthognal to all of them.
You hopefully recall that simultaneity is relative in special relativity. If not, you need to study the issue, it's important. The fact that different observers, those moving with different velocity, have different notions of simultaneity is closely related to the fact that the time-like four-vectors that are associated with these observers are different vectors. The name of the time-like four-vector associated with an observer may also be useful, it's called the observers four-velocity vector.
Making a vectors purely spatial basically implies that we set the time-component of the vectors to zero if we assuming Minkowskii coordinate conventions. As a consequence of defining what it means for a vector to have no time component, we have implicitly defined the notion of what a time-component is, and how to set that time component to zero. This specifies a notion of simultaneity, and the notion of simultaneity depends on the observer, in particular the state of motion of the observer.
Mathematically, the notion of dot-product comes first, and we use the notion of dot-product of an arbitrary vector with a basis vector to define the meaning of a component of a vector. A components of an arbitrary vector, accordign to the mathematical defintion, is the dot product of the arbitrary vector with the basis vector.
Your intuition is probably working backwards from the formal mathematical definition, assigning physical significance to the "vanishing" of the time component. This is exactly backwards from the mathematical approach, which treats vectors as abstract entities with abstract properties, and the "frame of reference" of an observer is a physical interpretation of the mathematical representation of a set of mutually orthogonal basis vectors associated with the observer.
The relativity of simlultaneity means that the notion of making the "time-component" of a vector "vanish" depends on the choice of basis vectors used. The mathematical description starts with the basis vectors, and allows one to define an observer as a set of basis vectors. The intuitive notion usually goes backwards, one defines an "observer" intuitively first, then finds set of basis vectors associated with that observer.
  • #33
You no doubt saw declarations like ##\vec{A}## has components ##A_x## and ##A_y##.
But you never saw expressions like ##\vec{A}=A_x+A_y##.
Instead, you'd see ##\vec{A}=A_x\hat{i}+A_y\hat{j}##.
The reason is because you can't, as you claim above, add components to get vectors.
You have vectors, you have components, and you have magnitudes.
  • #34
You appear to be using the word component in the sense that I originally used it, which lead others to claim that I was confusing a component (magnitude) with a vector. I was taking that on board when writing that the reference did not seem to have anything to say about direction. I am not yet convinced that you are wrong but it is not because I am confusing a component with a vector.
  • #35
I don’t think there is a wrong or right in this. I think that it is sloppy or not. The term “component” to my knowledge when used precisely refers to the real number that multiplies the basis vector. But it is pretty common sloppy language to refer to the product of the real number and the basis vector the same way. It is sloppy, but pretty reasonable and not too problematic. So in that sense we can say that energy points in the time direction, referring to ##E\hat t## rather than ##E##.
Certainly, if you asked in which direction ##p_x## points most people would be ok saying the ##\hat x## direction.
