Calculating the final speed using Force/Time Graph
The discussion focuses on calculating the final speed of a golf ball struck by a club, using the Force/Time graph provided. The mass of the golf ball is 0.1 kg, and the average force applied during the 80 milliseconds of contact is 50 Newtons. The impulse-momentum theorem is applied, leading to the conclusion that the final speed of the golf ball is 40 m/s, derived from the area of the triangle under the Force/Time graph, which equals 4 N-s or 4 kg-m/s.
  • Understanding of the Impulse-Momentum Theorem
  • Knowledge of calculating the area of geometric shapes (triangles)
  • Familiarity with basic physics concepts such as force, mass, and acceleration
  • Ability to perform unit conversions and understand Newtons and kilograms
  • Study the Impulse-Momentum Theorem in detail
  • Learn how to calculate areas under graphs for various shapes
  • Explore the relationship between force, mass, and acceleration using Newton's Second Law
  • Investigate real-world applications of impulse in sports physics
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in the application of the impulse-momentum theorem in practical scenarios.
Nizzeh
A golfer strikes a stationary golf ball, and the force applied by the club on the ball varies as shown in the graph below. Use this graph to determine the final speed of the golf ball. The mass of the golf ball is 0.1kg
Area of triangle = 1/2bh (then times by two for the full area.) Or AvgFt=m(v-u)
I tried avgF*t= m(v-u) and put 100*0.04=0.1(v-0) = 4/0.1 = 40m/s
also tried Area of Triangle = 1/2bh = 0.5*0.04*100 = 2 Then 2*2 = 4m/s to get the full triangle.
Final speed? As in t= 80?
Welcome to PH Forums.
The average Force during the 80 milliseconds of contact is 50 Newtons.
What does the Impulse - Momentum Theorem say? -- or -- How is impulse related to momentum?
it says Time of Contact / ms so I assume it's milliseconds.
Impulse = Momentum?
Nizzeh said:
Impulse = Momentum?
Not quite right. Look again.
Impulse = Change in Momentum.
Yes, that's it. Although, in this case, the ball starts out having zero momentum.
Ok so how did you get this? I am confused? Sorry about this.. what calculation would I do?
The impulse is the area under the graph, that's the area of the triangle. You have that right as 4 N-s = 4 kg-m/s .
You answer of 40 m/s also looks to be correct.
So which is the actual answer? you wrote 50 above which kinda confused me.
What did I say about 50 Newtons ? I said it was the average force during the 80 ms of contact. That's all
Ok so the formula I'd use and the solution is what?
