6 Nodes, 4 Elements, Size of Stiffness Matrix?
10 replies · 15K views
ThurmanMurman
Howdy,
If I have the following configuration of nodes:
2---4--6
1---3--5
What should the dimensions of my FEM stiffness be?
Thanks
Alright my attempt at formatting got messed up once I posted. Nodes 2-4-6 are equally spaced across the top, and nodes 1-3-5 sit below 2-4-6 on the bottom. 2-4-6 are respectively connected to 1-3-5 vertically, and 2 is connected to 3 diagonally, and 3 is connected to 6 diagonally.
The matrix size is (number of nodes) times (number of degrees of freedom per node).
The number of elements and how they connect is irrelevant.
So is the (number of nodes) = (number of rows) and the (DOFs per node) = (number of columns)?
Just to check my understanding, I think that my arrangement of nodes (4 total) with 2 DOFs each (8 total) leaves me with a 4X8 stiffness matrix. Is that correct?
Stiffness matrices are square and symmetric. So your stiffness matrix will be 8x8.
So is there a (nodes,DOFs) equation that states the size of a stiffness matrix for a system?
No, the number of rows and columns are both equal to (number of nodes) x (DOFs per node) .
Sorry if that wasn't clear - I took it as "obvious" that stiffness matrices are square.
So for my 6 node example, the stiffness would be sized (number of nodes = 6) x (DOFs per node = 2) = 12 x 12?
