A A better way of talking about time?
  • A
  • Thread starter Thread starter Yuras
Yuras
Mentors’ note : This thread was split off from https://www.physicsforums.com/threads/time-dilation-for-two-observers-in-relative-motion.1068098/
PeroK said:
If two people walk away from each other, they both look smaller relative to the other. Each might say that eventually the other is only about as big as his or her own thumb.
Excellent analogy. Note though that we don't talk about "height contraction" in this case.
Time dilation as a concept is a pedagogical disaster. IMO it should have not been introduced in the first place. There is only one time - the proper one. It's too late probably, but on the other hand we somehow managed to (mostly) get rid of "relativistic mass" - another miss-invention of the past.
Likes Dale
And there is another kind of time - the coordinate time. I think, this is a pedagogically important part of SR.
We have it still, it is only called energy, which is a coordinate dependent quantity.
Likes Dale
I understand why you are saying that, but... I came from the geometric camp. In my world coordinates are just labels, they can't be important.
It's actually a 4-scalar :
$$E=g_{\alpha\beta}p^\alpha u^\beta$$
I mean, it obviously depends on the observer via ##u##, but proper time does that as well.
  • Skeptical
Likes Dale and PeroK
Proper time is invariant. The energy I mean (=relativistic mass), the time-component of the 4-momentum, is not invariant.
Likes Dale
That’s because it does not describe the Euclidean analogy of time dilation, which is two odometers moving from a common point in different directions. Each odometer also projects a line orthogonal to its motion at fixed distances from the start. Both odometers will note that its own 1 m line is crossed by the other odometer when that one shows a number greater than one.
What was described was simply that effects may be symmetrical between observers.
It has the very same issues as using Cartesian coordinates on Euclidean space. The analogies are abundant. The only reason people “get” Euclidean effects better is that they have more intuition in Euclidean geometry than in Minkowski geometry.
The thing is that they are important for how people learn - for better or worse. This is as true in Euclidean space as in Minkowski space.
I mean, yes, that is a scalar. But changing coordinates changes what observer is at rest in those coordinates and therefore which scalar you are referring too. This is somewhat unavoidable if you introduce coordinates. You might as well say that the coefficients of a vector relative to a basis are scalars (because in one sense they are - just contract with the dual basis), but that doesn’t mean that you will have exactly the same numerical coefficients in a different basis. It is definitely a way forward, but not how most people learn.
You are missing their point. Their point is that energy relative to an observer is an invariant quantity. Obviously it depends on the observer because the observer 4-velocity is in there.
Yes. The combined information about a frame-dependent quantity and the related reference frame is invariant. In the case of the proper time, the reference frame (rest frame of the object) is implicitly included.
There is no reference to any reference frame when it comes to proper time. Proper time is a geometrical quantity that refers to the path length along a time-like world line. Just as path length in Euclidean space is perfectly well defined as a line integral along the path. No reference to a particular coordinate system is needed.
However, just as in Euclidean space - some coordinates may make expressions easier than others.
Likes Yuras and Sagittarius A-Star
Yes, you are right. In SR, proper time is the norm of a 4-vector and therefore invariant. Frame-dependent are the components of a 4-vector (if a reference frame is not included in the information).
People think about space geometrically, while we explain them space-time in terms of coordinates. No wonder they come back and ask strange questions again and again.
My point is that we should change how we teach people.
I'm actually a bit surprised to encounter an opposition here. Physics doesn't require coordinates in a sense that everything we measure at the end of the day is a proper 4-dimentional object. While time dilation is an effect of coordinates, so putting it into a center of the theory is... unphysical?
For any nontrivial calculation we need coordinates, so we can't avoid them. But they should be secondary. And IMO pop-sci should stop emphasizing things like time dilation, relative simultaneousness etc.
BTW we are hijacking the thread and probably confusing the OP.
Likes PeroK
I’m a proponent of spacetime diagrams… since we often refer to the “spacetime geometry”. Sadly, I think Einstein thought Minkowski made it (to Einstein) unnecessarily complex… and so we have many physicists who regard the spacetime diagram as “too difficult”.
I think a spacetime diagram of the situation and its Euclidean analogue would help the OP.
For example, look at
https://www.physicsforums.com/threa...procity-of-time-dilation.1057792/post-6973393
You misread me. I do try to teach relativity without going too much into coordinates, time dilation, length contraction, etc. It is difficult for a reason though: People generally have a lot of baggage here before they come to an actual course where they are ready to be given the geometric treatment. Even in Euclidean geometry, people are taught to compute the length of lines using Pythagoras' theorem, which is essentially breaking the line down into its coordinate components. There is also an often deeply rooted sense of universal time which does not make things any easier.
I do cover time dilation, length contraction, etc towards the end of my SR course for one very simple reason: If I did not, then people would not unlearn what they already "learned" so they can learn what is actually going on. There is simply too much of these concepts in popular media and lower level courses that unless you cover it, students will still get it wrong (I have tried not covering it, it just results in students trying to apply it to the exam problems anyway and failing miserably).
Feel free to open a new thread if you want to discuss it further.
[Mentors’ note: after exercising the mentorly superpowers that I acquired when I was bitten by a radioactive doodlebug as an adolescent, we are now in that different thread]
Likes Klystron, PhDeezNutz and PeroK
… I came from the geometric camp. In my world coordinates are just labels, they can't be important.
That is a defensible proposition (I’ve recommended Taylor and Wheeler’s “Spacetime Physics” so often that I think I deserve a cut of the sales) but I find that many people are unable to appreciate the power of the geometric approach until they have ground through the coordinate-based approach so familiar from high school classical mechanics.
The pedagogical disaster, at least as measured by observed confusion in various PF threads (such as the one from which this was split) is not teaching relativity of simultaneity alongside time dilation and length contraction and showing how the three together create a consistent whole.
Likes vela
Orodruin said:
You misread me.
Sorry if that's the case. Though by opposition I mostly meant the initial response from @Sagittarius A-Star
That's 100% true. But it's made by our own hands, isn't it? And it's very hard to fix at this point, that's why I'm calling it a pedagogical disaster.
Yes, it's a reasonable practical approach. The question is how would you teach SR if there would be no such baggage.
Since we are in a separate thread now, I can actually answer the original question:
how is this possible when both observers can claim that it is the other's time that is passing more slowly
It's possible because there is nobody there to check their claims until they actually come into one point and compare their clocks locally.
But I'm afraid that would I post this answer, the OP would conclude that physicists don't agree even among themselves :)
Depends what meaning you put into ”own”. I certainly did not make it. People who died before I was born did to a large extent. So large that it is now everywhere. High-school teachers are parroting it at an alarming rate and even more alarming is all the popular media - not in the least YouTube videos - embracing it. If you go on reddit physics subs you are more than likely getting downvoted because people simply do not understand any other way.
If you have any ideas on how to fix this I am all ears.
A fair question, but one I have not spent too much time thinking about as it is an ideal case not likely to occur any time soon.
Likes PhDeezNutz and Yuras
I didn't mean you of course. And from the very beginning I have said that it was probably too late to fix.
Sorry, I'm only able to complain :)
I'm not teaching anyone, and I'm not even in the academia.
Though I think we have to at least acknowledge the issue.
Likes PeroK
Well, it’s another way of reinforcing that simultaneity is not directly measurable. But yes…
Your instinct that it doesn’t belong in the other thread is pedagogically sound 🙂
Likes Yuras
I have only anecdotal evidence, but it's kinda opposite (survival bias?) I remember people (me included) struggling with constantly accelerating observer (the most "complicated" topic most of them ever encounter) until they see the coordinate-free one-liner derivation.
It hurts every time I remember how many hours I wasted trying to get sense of time and space "switching roles" inside a blackhole and similar things.
Spacetime diagrams should be taught in a kindergarten! Though it should not contain the ##x## axes and instead of ##t## axes there should be just the world line of an observer.
(Disclaimer: I didn't actually think it through, so it might be a bad idea at the end of the day :) )
The inherent problem with removing the axes is that we ultimately have Minkowski geometry represented on Euclidean. You’ll need to at least draw a light coneor two, which I guess is easy enough in Minkowski space.
I have to work hard to see things geometrically. I'm much happier with algebra. Spacetime diagrams do nothing for me, I'm afraid. I have no mental mechanism to transform the actual Euclidean geometry of a 2D image to Minkowski geometry. Whereas, I used to be able to do a lot of algebra in my head.
In fact, Terrence Tao is a bit like this (although on a different plane):
https://mathstodon.xyz/@tao/113465947720694301
How does this one-liner look like?
I was totally sure I'll find it on wikipedia, but it's not there... Had to come up with something on the fly, so don't expect too much.
Basically you calculate hyperbolic angle (aka rapidity) between the initial 4-velocity ##u_0## and the current one ##u##. Start with their inner product ##cosh(w)=u_0\cdot u## and differentiate it by the proper time:
$$sinh(w)\dot w=u_0 \cdot \dot u = |\dot u| sinh(w)$$
The last step is analogous to ##cos(\frac{\pi}{2}+w)=-sin(w)## (note that ##u## and ##\dot u## are orthogonal). I don't know hyperbolic trigonometry enough to justify it right now, so I'm hand waving here, but in practice you of course just calculate ##u_0\cdot\dot u## in the reference frame of ##u##:
$$u_0\cdot\dot u=
\begin{pmatrix}
cosh(w) &
sinh(w) &
0 &
\end{pmatrix}
\cdot
\begin{pmatrix}
0 \\
|\dot u| \\
0 \\
\end{pmatrix}
It's a bit of a cheating, but the statement itself is coordinate independent anyway.
One way or another, after cancelling ##sinh## we get the following:
$$\dot w = |\dot u|$$
If the (magnitude of the) 4-acceleration is constant, then we just have uniform hyperbolic rotation, i.e. a hyperbola.
Note that this method handles variable acceleration as long as it stays in the same plane as ##u_0## and ##u##. For more general case you have to stop before the last step:
$$sinh(w)\dot w=u_0 \cdot \dot u$$
(I really hope I didn't make any silly mistake, and all the above actually makes sense :) )
Likes Sagittarius A-Star
Yeah, it's useful only for very basic things (aka almost never). Still I think it's an important tool to teach students to formulate their problems in geometric terms. I mean, there are different ways to do algebra: you can calculate the time component of 4-momentum in a particular frame or it's projection on observer's 4-velocity. The result is the same either way, but physical significance is huge. I think spacetime diagrams help to internalize more geometric approach. Though I'm not teaching SR, so my opinion on this is probably just a laughable nonsense.
Likes PeroK
Yes, this is trivially correct. The hyperbolic angle ##w## is ##{\alpha \over c}## times the elapsed proper time of the Rindler observer along the hyperbola via definition of the hyperbolic angle. Therefore ##\dot w = \alpha/c##.
Source posting:
https://www.physicsforums.com/threa...-without-delving-into-gr.1055627/post-6964768
I think is is important to teach the Minkowski metric. I see no good reason to remove it and the related definition of TD i.e. from the following paper. Only that it may be to difficult to teach / understand would be for me i.e. not a good reason.
Source:
http://www.faculty.luther.edu/~macdonal/EGR/EGR.html
Sorry, but I don't understand your point. I suggested to drop the axis, not metric.
Most likely I'm just misreading your comment, but are you implying that metric tensor is somehow related to coordinates? The whole point of dropping the axis is to prevent students from picking up such misconceptions.
Here are some non-basic situations where a diagram is quite useful.
No, I do not refer to the metric tensor alone. My above screenshot shows the product of the metric tensor with the squared differences-position 4-vector. It results in the (squared) norm of the differences-position 4-vector. Squared coordinate differences are shown.
See also:
Source:
  • #31
$$u_0\cdot\dot u=
\begin{pmatrix}
cosh(w) &
sinh(w) &
0 &
\end{pmatrix}
\cdot
\begin{pmatrix}
0 \\
|\dot u| \\
0 \\
\end{pmatrix}
This seems unnecessarily complicated. The quick way is to note that the world-line of an observer with constant proper acceleration is necessarily a hyperbola because anything else would not have constant curvature (just as a curve of constant curvature in Euclidean space is a circle). We therefore have (up to spacetime translations)
t^2 - x^2 = - 1/a^2
(the RHS must be negative for the hyperbola to be time-like)
It is simple to verify that ##a## is the proper acceleration:
Parametrize the hyperbola using the hyperbolic one*
t = \sinh(as)/a, \quad x = \cosh(as)/a
This gives ##dX/ds = (\cosh(as),\sinh(as))## which has norm 1 and is therefore the 4-velocity ##V## with ##s## being the proper time. It follows that
A = \frac{dV}{ds} = a (\sinh(as), \cosh(as))
which squares to ##\alpha^2 = -A^2 = a^2##.
* Here I obviously chose ##as## as the argument of the hyperbolic functions because I know that makes ##s## the proper time. However, it is also easy to make this a reasonable guess or just use a rapidity ##\theta## as the argument. In the latter case it immediately follows that rapidity is ##as## by rescaling to normalize 4-velocity (##\theta = as## this is the relativistic generalization of ##v = at## for constant proper acceleration).
The bottom line is you don’t have to delve deep into differentiating gamma factors and solving an ODE in ##t## to solve the case of constant proper acceleration.
Edit: ##\LaTeX## versions of the hyperbolic functions exist: \sinh -> ##\sinh## and \cosh -> ##\cosh## etc.
Likes Klystron and PeterDonis
  • #32
These are great diagrams!
But "basic" is a subjective term. Your examples are exercises, very useful for studding, while practical problems are too messy to draw, harder to interpret graphically (e.g. 4D) and easier to handle algebraically. That's my limited experience anyway.
Sorry, probably I'm just too tired right now, but I don't see your point. Let's hope someone will jump in and address it.
  • #33
But it's more general since it handles varying acceleration.
Orodruin said:
The bottom line is you don’t have to delve deep into differentiating gamma factors and solving an ODE in to solve the case of constant proper acceleration.
That's right. But for some reason it's always presented as a deep delve into differentiating gamma factors.
In general coordinate-free derivation can't beat coondinate-based one since you can always convert the former to the latter. Every non-trivial coordinate-free one contains a hidden coordinate frame.
  • #34
"Always" seems like a too strong statement. It is actually a false statement as the way I just presented is how I do it in my SR course. "Usually" or "often" may be more accurate, and mainly in very introductory courses. At the core it is also just geometry used to infer that the shape must be a hyperbola. It is the direct analogy of a circle in Euclidean space. I typically spend the entire first lecture (45'+45') just introducing Minkowski geometry and drawing parallels to Euclidean space.
I also have a very pragmatic reason for not digging deep into differentiating gamma factors: Apart from the fact that it just loses students' attention - I don't want to do it because it is just messy and you're bound to get something wrong at some point.
Likes Yuras
  • #35
I'll try to use hyperbola only in its strict mathematical sense from now on.
I'm jealous of your students. When I was studying SR we were still recovering from "SR can't handle accelerating observers" thing.
Likes PhDeezNutz
  • #36
The examples provide explanations, both physical and geometrical.
Some with nice numbers so that one can focus on the physics, and less on the arithmetic.
By "practical problems", do you mean not-necessarily nice numbers?
Sure... once one understands the physics and the underlying math, then one can use the formulaic approaches.
The problem for the beginner is that, in my opinion,
the heavy-formulaic approaches are too detached from the physics and the geometry.
Try doing a euclidean geometry problem or analyzing a block on an incline
algebraically or formulaically alone (that is, without drawing an associated diagram).
  • #37
I mean, this is another of these common misconceptions that you still see parroted in popular media and "modern" physics courses ... Every year there will be at least one or two students that have this preconception that needs to be rooted out. Again an issue of lower level courses being taught by people who never delved any deeper into relativity and parrot what they learned themselves in the same type of course.
Then we also have my favourite misconception: When considering muons produced in the atmosphere (and reaching the Earth due to being time dilated in the Earth frame) answering the question "how far did the muon travel in its rest frame" with a non-zero number. Nowadays I tend to ask exactly this question to students every year as it is great for hammering in the concept of relative motion when you follow up by telling them that the correct answer is zero.
robphy said:
Try [...] analyzing a block on an incline
Been there, done that. :cool:
Likes berkeman
  • #38
For beginners? :rolleyes: (the context of my suggestion).
Maybe you have some amazing students.
  • #39
I don't think this is true. For a fairly simple counterexample, see Misner, Thorne, & Wheeler, Section 2.8. For a more extended counterexample, see much of Wald's GR textbook, where Wald's abstract index notation is defined and used; the whole purpose of that notation is to be able to keep track of things like tensor indices (what MTW calls "slots") without having to choose any coordinates.
  • #40
IIRC there was an article some years ago in The Physics Teacher emphasizing that the relativity of simultaneity should be taught before time dilation or length contraction, and repeatedly emphasized because of the stubborn notion in the students' minds that there is one true time (in other words, that simultaneity is absolute).
Likes weirdoguy
  • #41
I agree that this quantity is a scalar, but I disagree that it is the energy. Energy is the timelike component of the four momentum: ##p^\mu=(E/c,\vec p)##. So your ##E## does not transform correctly, although they do coincide specifically for ##u^\beta=(c,0,0,0)##.
  • #42
It's the energy of an object with 4-momentum ##p^\alpha## as measured by an observer with 4-velocity ##u^\beta##.
The "timelike component of 4-momentum" is the energy measured by the observer whose 4-velocity is that same 4-momentum divided by the observer's rest mass ##m##. In other words, ##E = g_{\alpha \beta} p^\alpha p^\beta / m##; i.e., ##u^\beta = p^\beta / m##.
  • #43
It transforms as a scalar; but the physical meaning of this scalar has to be carefully specified; just calling it "energy" is not enough. See my post #42.
  • #44
Yes, I agree with that description. Not just "energy". Maybe "measured energy" for short, but certainly not just "energy".
Likes PeterDonis
  • #45
It's a question of terminology to some extend, though not all terminology is equally good.
Your definition doesn't immediately work in curvilinear coordinates or in GR. You need to amend the definition with e.g. some kind of normal coordinates. While my definition works as is. Though it's purely technical issue.
More important in my opinion is that your definition denies energy its objective existence. Physics doesn't depend on particular choice of coordinates, moreover it should work even without any coordinates at all. Does energy not exist until I introduce a coordinate system?
The third point is that your definition forces one to go to a specific coordinates to calculate energy (at least to do the "by definition" calculations), while I can do that in any coordinates, including curvilinear, and get exactly the same result.
I prefer to think about it differently. "My" ##E## is the actual physical definition of energy, and the timelike component of the four momentum coincides with energy in the observer's frame. So it's the timelike component who doesn't transform correctly.
  • #46
I believe that true physical quantities are things you can directly measure. So adding the adjective "measured" is kinda excessive. Though I understand what you mean.
  • #47
I think this should read ##E = g_{\alpha \beta} p^\alpha q^\beta / m_q##; (the particle-energy measured by a measurer)
where ##q^\beta## is the 4-momentum of the measurer
so that ##u^\beta = \left( q^\beta / m_q \right) ## (the 4-velocity of the measurer, like a "unit-vector" tangent to the measurer-worldline)
because ## m_p^2=g_{\alpha \beta} p^\alpha p^\beta##
is the essentially the square of the particle's invariant-mass.
## g_{\alpha \beta} p^\alpha p^\beta / m_p## can be called "the mass of the particle" (or its-energy equivalent)
## g_{\alpha \beta} p^\alpha q^\beta / m_q## can be called "the energy of the particle measured-by-##u^\beta##" (something clearly indicating "measured-by-##u^\beta##" is needed)
  • #48
It is completely a question of terminology. While I agree that not all terminology is equally good, far worse than poor terminology is using a common term in a different way than the community does. The terminology you are using is certainly non-standard (which should be supported with references to the appropriate source), perhaps even personal (which should be avoided here entirely).
Energy does not have an objective existence, and it does depend on the particular choice of coordinates. This should be as obvious as possible since KE is part of energy and KE depends on the choice of coordinates.
Yuras said:
"My" E is the actual physical definition of energy
Please provide a reference for this. If you even have such a reference, it is by far not the common usage of the term.
It is a different quantity so they need different terms. There are plenty of things in physics that are not directly measured.
  • #49
See for example Misner, Thorne, Wheeler, Gravitation, section 2.8:
One must have a variety of coordinate-free contacts between theory and experiment in order
to use the geometric viewpoint. One such contact is the equation E = — p • u for the energy
of a photon with 4-momentum p, as measured by an observer with 4-velocity u.
The geometric definition of energy is used multiple times throughout the section (and throughout the whole book IIRC.)
I think you are missing the context here. The whole thread is about how the "standard" way to present SR is, in my opinion, pedagogically questionable. Yes, almost everywhere energy is defined as the timelike component, but the geometric one is non unprecedented as well. I'm arguing that the latter is much better pedagogically. And to be honest, I don't quite understand why you think these are separate things.
I respectfully disagree. If it's a physical quantity, then it has to objectively exist. See section 2.2. of Misner etc for justification.
KE depends on observer, but it doesn't depend on coordinates. The same observer will measure they same value for KE in rectangular, spherical, polar or any other coordinates. The whole notion of "measurement" doesn't not depend on coordinates in the first place.
It's like saying that proper time depends on coordinates because it's an integral of ##dt## in the normal coordinates.
  • Skeptical
Likes weirdoguy
  • #50
Another quote from Misner etc (also section 2.8):
Equally coordinate-free are the photon energies ##E_e## and ##E_a## measured by emitter and absorber. No coordinates are needed to describe the fact that a specific emitter emitting a specific photon attributes to it the energy ##E_e##; and no coordinates are required in the geometric formula
$$E=-p\cdot u$$
