Mentor
- 37,243
- 16,364
Sure, it fixes the coordinate system, but fixing the coordinate system doesn’t make it independent of the coordinate system.Orodruin said:”Energy is S” fixes the coordinate system for which you want the time component of the 4-momentum
Similarly, the tension in a spring depends on the length. You can fix the length, but that doesn’t make the tension independent of the length.
When you fix the coordinate system, a quantity that is coordinate dependent becomes well-defined, not coordinate-independent. I think you are confounding well-defined with coordinate-independent.
Even after your explanation I don’t think this is good. It is certainly confusing, and unnecessarily so.Orodruin said:the value of the "energy in coordinate system S" depends on what you pick for coordinate system S.
"energy in coordinate system S" is frame independent as well.
I am not completely sure which quantity you are referring to by “energy in coordinate system S”. I think it is ##e_t \cdot p##, which depends on ##t##.
It is well defined and, as you say, can be calculated in any other frame. But none of that removes the fact that the coordinate ##t## is literally right there in the formula and changes when you change coordinates.
