A box slides down with initial V, force needed to stop it?
The discussion revolves around a physics problem involving a box sliding down a ramp with an initial velocity. The problem includes various forces acting on the box, such as weight, friction, and an external force required to stop it. Participants are analyzing the forces and equations related to motion and acceleration.
  • Mixed
  • Participants discuss the calculation of forces needed to counteract the box's motion and question the initial assumptions about the forces involved. There are attempts to clarify the problem statement and the duration of the applied force.
Some participants express uncertainty about the calculations and the interpretation of the problem statement. There is a suggestion that the original poster's calculations may be correct, but the lack of clarity in the problem description is causing confusion. Multiple interpretations of the problem are being explored.
There are constraints regarding the clarity of the problem statement, particularly concerning the duration of the applied force and the translation of the problem into English. Participants note that the original problem may have been inadequately described, affecting the discussion.
Hilmy atha
Vo = 5m/s
W to the left = 6N
Ffriction = 2N
F to the left = W - Friction = 4 N
m = 1kg
g = 10 m/s^2
Ramp length = 10m
sin a = 3/5
cos a = 4/5
F = ma
Vt ^2 = Vo^2 + 2as
Vt = Vo + at
Outside force (1) to cancel acceleration from weight
= 4N
So now a = 0
Now we calculate how much decceleration is need to stop the initial 5m/s
Vt ^2 = Vo ^2 + 2as
0 = 25 + 20a
a = 1,25 decceleratiom from outside force (2)
F2 = m.a = 1.25 N
So F1(to cancel initail acceleration) + F2(to cancel initial velocity) = 4 + 1.25 = 5.25N
Is there something wrong? The answer is not in the options :/
Wait why didn't the image shows up? It can't show images from google drive?
If the image isn't public access the software can't get to it. It's better to UPLOAD images to our server.
Hi. Welcome to Physics Forums.
Hilmy atha said:
W to the left = 4 N
Where did this come from? Is it part of the problem statement?
Okay i updated it
Can you provide a translation of the problem statement? It's not obvious how long the force is allowed to operate on the block. Is it applied during the entire motion?
Hilmy atha said:
F2 = m.a = 1.25 N
So you need 4 N (in addition to the 2 N friction force) to counter the down-the-slope weight component.
And you need 1.25 N to produce an up-the-slope acceleration.
4 + 1.25 = 5.25 N.
I can't find anything wrong with that. But it is early in the morning for me. :)
Possibly the problem creator had a sign error and came up with 4 - 1.25 = 2.75 (which rounds to 2.8)
In response go @gneill comment (which just came through), I assumed the force was applied for the entire 10 m of the slope.
It is not mentioned at all. Everything i typed is basically the translation in math equations
I typed the words into Google translate and the relevant part of the translation was:
"so that the right thing stopping at the bottom end of the track"
Per my previous post, I think your answer is correct.
In future please make sure that the problem has been described in English in the problem statement section. Translations of relevant material in images is fine. Note that this is a forum rule.
Your answer may end up closer to 5.0 N if you use a more accurate value for g.
10K
