What Is the Correct Formula for Stopping Distance in Physics Homework?
  • Thread starter Thread starter Coop
    Braking Car
The correct formula for stopping distance in the given physics problem is derived from the equation Vf^2 = Vi^2 + 2ad, leading to the conclusion that the stopping distance d equals 80 meters when the initial velocity Vi is 31 m/s and the deceleration a is -6 m/s². The statement "Stopping distance = 961 - 12d" is incorrect as it misrepresents the relationship between stopping distance and the other variables. The average velocity can be calculated using the formula v(t) = d/t, but this does not provide the instantaneous velocity at time t. Therefore, the correct interpretation of the stopping distance must be adhered to for accurate problem-solving.
  • Understanding of kinematic equations in physics
  • Familiarity with concepts of velocity and acceleration
  • Knowledge of how to manipulate algebraic equations
  • Ability to interpret and analyze physics problems
  • Study the derivation of kinematic equations, particularly Vf^2 = Vi^2 + 2ad
  • Learn how to calculate instantaneous velocity versus average velocity
  • Explore real-world applications of stopping distance in automotive safety
  • Practice solving similar physics problems involving motion and deceleration
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of motion and stopping distances in vehicles.
Coop
The driver of a car at 31 m/s sees (t = 0, x = 0) an obstacle down the road and brakes. The car slows down with a constant deceleration which has a magnitude of 6 m/s^2. Select the correct statement below (let d = stopping distance, all units are SI)
a. The position x(t) = 31t + 3t^2
b. The velocity v(t) = 31 - 3t
c. Stopping distance = 961 - 12d
d. The velocity v(t) = d/t
e. None of the above
Vf = Vi + at
Vf^2 = Vi^2 + 2ad
Xf = Xi + Vi*t + .5at^2
is not correct, because Xf = Xi + Vi*t + .5at^2, so x(t) = 31t - 3t^2
is not correct, because Vf = Vi + at, so v(t) = 31 - 6t
is correct, because Vf^2 = Vi^2 + 2ad, so 0 = 31^2 + 2(-6)d = 961 - 12d => d = 80 m
is correct, because the velocity at time t can solved by dividing the distance traveled over the time taken
But the answer key says c. is correct, why is d. not also correct? Is it because dividing d/t would only give the AVERAGE velocity, not the velocity at time t?
Thanks,
Coop
Exactly.
c cannot be correct unless you did dot copy it exactly as in the book.
d IS the stopping distance. So c will read
d=961-12*d
which is not true, is it?
Yes, nasu is correct. Choice c makes no sense. (I didn't read it before, I'm afraid.) Did you copy it correctly?
It's from a practice test made by my prof., directly choice c reads "The equation for the stopping distance is 961 - 12d = 0"
That's more like it. (Quite different from what you wrote the first time.)
Oh my mistake, I didn't realize, but now that you guys explained it I can see the difference
  • · Replies 17 ·
