Prathyush
- Messages
- 211
- Reaction score
- 16
- TL;DR
- I am interested in a feasibility analysis of running a Carnot engine between poles and equator.
Earth absorbs and releases a massive amount of energy as a part of the day night cycles.(~100 Peta watts of solar radiation received) And the temperature difference between the poles and equator drive weather phenomenon, which happens at an energy scale beyond technology.
I am wondering if one can run a Carnot engine between from the pole to the equator. I am thinking of it as a massive infrastructure project, capable of meeting immediate energy needs of the planet.( Capable of generating atleast 5-10 terawatts of sustained power)
Here is a plausibility analysis, with some design choices (but feel free to design it differently).
Some other similar design ideas,
- I am thinking of using water for the required thermal mass. Water is abundant and has a high specific heat.
- Water is contained in 2 separate tubes, one for hot side and one for the cold side. The tubes run from poles to equator. The tubes are constructed using a non corrosive thermally conductive metal and surrounded by thick insulation.
- On the hot side, I am imagining simple solar concentrators to keep the water above 90 degrees. On the cold side, I am imagining a simple heat exchanger keeping the temperature below 10 degrees. Solar concentrators and heat exchangers have a very long life span and recyclable. I chose the number 10 degrees and 90 degrees because it seems broad enough to be useful, and not so extreme that it would be difficult to maintain the temperature.
- I will do my calculatation per Terawatt. 1 Terawattday = 8.64e+13 Joules. Using this we can get an estimate of the thermal mass of water required. 1 Terawatt day/(Specific heat of water*50 degrees) = 400 million Kgs of water. The temperature difference of 50 degrees is a crude choice. This is affected by efficiency and ability to maintain the temperature differences.
- An ideal engine operating between 0C(273K) and 90C(363K) has an efficiency of about 25 pc. I am assuming in practice we can achieve an efficiency of 10 pc. So I will multiply the thermal mass by a factor of 10 and 4 billion Kgs of water. To be on the safe side we can estimate the amount of water required 10 billion Kgs/terawatt. But well within the realm of possibility.
- It can be easily built in a modular fashion.
- Use different material for thermal mass, instead of water. One can consider some kind of molten salt, to keep the hot side at a very high temperature, but it becomes close to some designs of concentrated solar power plants. And it does not seem useful(except perhaps for efficient gains), and water is abundant.
- Heating and cooling form a large part of residential energy use. It is possible to directly transport heat, But last mile delivery seems tricky.
- Another way is to completely do away with water and just use a insulated conducting material to transport heat. But that looks very expensive.
