A computational model of Bell correlations
76 replies · 10K views · last reply
entropy1 said:
I thought of this: you can also apply the model to a setting with fixed angles. In that case the flaw is that, given the 50/50 randomness of the bits generated at A and at B, that the correlation is 50/50 too.
No, I think that case can produce 100% correlation due to the shared seed, for some set ups. But it can’t produce in between correlation percentages.
Yes, probably.
Zafa Pi said:
The correlations happen
Why are you assuming that correlations are something that must "happen"? We don't know that. All we know are the correlations we calculate after the fact.
Zafa Pi said:
You make it appear that my "he" is Bell.
Not on purpose. My response would apply just as well to @entropy1 in post #7--that is the only definition of "nonlocality" that we have a definite theorem for.
PeterDonis said:
What is the "speed of information"?
If information is available at A, then, to make it non-trivially available at B, that can't be done faster than lightspeed. Information in this case being knowledge about a situation in A.
None of this helps any. You still haven't rigorously defined what you mean by "information" (defining it as "knowledge" doesn't help because that term is just as vague as "information"), or rigorously explained why it has to "travel" somewhere. I know it seems intuitively obvious to you, but this is one of those cases where "intuitively obvious" doesn't cut it. You need to actually try to rigorously formulate your requirement in a way that can be mathematically analyzed and used to make predictions. (That's what Bell was trying to do with his definition of "locality".)
Why not use your definition?
PeterDonis said:
That is why it is said that no information can be transmitted in this manner--information transmission requires the "source" to be able to affect the "receiver" in some controllable way.
All that is needed to transmit is a pair of bits from Alice to Bob at FTL in order to conspire and get any correlations you want. Too bad it can't be done.
I may not be reading you right, but the correlations have been taking place in extreme abundance in quantum optics labs since 1981. That is why they must "happen".
I see it as the same as why apples must fall.
Perhaps that what travels at speed c or slower, which is practically everything.
And "traveling": Information X "travels" from A to B if B produces a record with meaning P if and only if A has produced record X with meaning P.
Why must correlations be things that "take place"? As I said, we don't know that they "take place". All we know is that we can calculate them after the fact.
What does "take place" in quantum optics labs is that various preparation procedures are done, various measurements are made, and various results are recorded. Where in that do "correlations take place"?
This is the problem with using ordinary language instead of math. Ordinary language is vague, and it often includes implicit assumptions that are based on our classical intuitions and which are not valid--or at least not valid as assumptions--when quantum phenomena are involved.
If "information" is defined as "what travels at speed c or slower", then by definition, information cannot travel at FTL. Problem solved. Are you satisfied with that?
If A and B are spacelike separated, how do you know which one happened first? Your "if and only if" statement requires an invariant ordering: A has to come before B. But if A and B are spacelike separated, there is no invariant ordering.
Smack-dab in the recorded results.
You strike me as a smart and educated guy so I believe you are thinking of something I am not picking up on.
Consider this example:
Experiment 1) trial consists of A preforming X and getting a 1 or 0, and B preforming Y and getting 1 or 0. After many runs the results look like flips of independent fair coins.
Experiment 2) trial is like above, but the coins are not independent, and A and B's results are always the same.
In 1) the results are uncorrelated (have correlation coefficient 0).
In 2) we find that the results are highly correlated (have correlation coefficient 1).
In 2) we find correlation. In measuring entangled particles we find correlations (depending on the axes of measurement).
Does my criterion for "find" make sense?
I'm sorry, you still aren't grasping my point. See below.
Indeed. The correlations are in the recorded results, yes. But the correlations in the recorded results are things that we extract from those results by analyzing them. That does not in any way mean the correlations "take place". The correlations are just mathematical calculations we make. At least, that's all that follows from your statement that the correlations are in the recorded results. So if you want to convince me that the correlations are something that had to "take place", you need to make some other argument.
Sure, but it just means what I said above: we "find" the correlations by calculating them. It does not mean the correlations had to "take place". Something took place, yes. But that doesn't mean that something is properly described as "the correlations taking place".
I had a friend look at our discussion and I wrote 6 sentences to see if she could tell which ones you would find acceptable. She, and I were not sure.
At any rate I hope you agree that coral invasions take place.:rolleyes:
Zafa Pi, I think you are making category error. Correlation is not a physical mechanism, instead physical mechanisms manifest themselves as correlations in data.
That coral invasion is in your past light cone.
As you describe the setup, the correlation take place some time/where between the start of the experiment, and the collection and transport of "information" for correlation checking where it is finally "placed".
That's a bit on the vague side of things.
I agree, but so what?
I find birds chirping in the forest. I find beauty in the forest.
Two perfectly reasonable sentences in spite of birds chirping and beauty being different categories.
"A disagreement has taken place between A and B. " is also a valid sentence. Halfway between?
That's because "find in" in two sentences have different meanings.
Let me rewrite your sentences like that:
I find that birds chirping takes place in the forest. I find that beauty takes place in the forest.
Now you can see that second sentence has lost it's meaning.
The correlation is the result of dependence of the stochastic variables representing the local measurement outcomes (ie A and B). Could we speak of this "dependence" "happening"? In the sense that it "manifests itself"? Because dependence suggests a physical cause?
Sure. But if we observed coral invasions taking place in two widely separated locations and calculated correlations between them (comparing how much distance the coral invaded per unit time in each place, for example), would you say those calculated correlations "take place"?
If I am not mistaking, Bell's theorem deals with models of local hidden variables. But does it deal with non-locality?
Bell's Theorem defines "locality" as follows: the function that describes the correlation between the measurement results factorizes, i.e., it is the product of two functions, each of which depends on the measurement settings at only one of the two measurements. It includes hidden variables in the mathematical expressions it uses, but they are integrated over and do not play any essential part in the proof of the theorem. The key condition is factorizability.
In the sense that "non-locality" means the locality condition above is violated (as it is in QM).
So does that correspond with:
  1. At A, we know if the particle is detected;
  2. At A, we know the angle of the detector;
  3. At B, we know if the particle is detected;
  4. At B, we know the angle of the detector;
  5. But the correlation is a function of the difference of both angles.
so to establish the correlation, if we adopt realism and take the outcome of the measurement at the instant it is measured, we need the difference between both angles, so it can't be a factorizable function?
Sorry, I find it poetic and embued with meaning. Perhaps you've missed your calling.
Also the sentence "A disagreement has taken place between A and B. " is common place, unambiguous, with the same categories as the one above. Now perhaps you and @PeterDonis might want to ask where it takes place. Halfway between? Could the ratio of distances between be irrational? I have no good answers for such questions.
I hope you don't accuse me of being anti-Semantic, but I would prefer to check out of this topic and return to the happy place of QM.
I am unsure why one would assume only one of the settings counts. Would not both play a part?
I think you're making this more difficult than it needs to be. Have you read Bell's paper?
Here is Bell's line of reasoning:
We have a measurement of particle A and a measurement of particle B. These measurements take place at spacelike separated events.
At each measurement, we have settings, call them ##a## and ##b##.
If we do a large number of runs, we can construct a function ##E(a, b)## which gives the degree of correlation between the results as a function of the measurement settings.
Bell's locality condition is then that this function can be factorized: ##E(a, b) = F(a) G(b)##. Notice that each factor is a function of only one of the two measurement settings. He calls this condition "locality" because it appears to capture our intuitive notion that the results at one measurement should not depend on the settings at the other measurement, since they are spacelike separated. However, in the end it's just a mathematical condition; whether or not you think "locality" is a proper name for it is a matter of words, not physics or math.
Bell then shows that if the function ##E(a, b)## factorizes in this way, it must obey certain inequalities.
We know, however, that the function ##E(a, b)## which is predicted by quantum mechanics violates these inequalities.
Therefore, the function ##E(a, b)## which is predicted by quantum mechanics cannot factorize in the way described above, which means it violates Bell's locality condition. Therefore, quantum mechanics is "nonlocal" in this sense.
Check the proof again. That's not Bell's locality condition. The locality condition is that ##P## factorizes, if conditioned on the hidden variable ##\lambda##: ##P(a,b|\lambda) = P(a|\lambda)P(b|\lambda)##. The assumption of a conditioning on ##\lambda## is a crucial part of the proof. In general, ##E(a,b)## doesn't even factorize in perfectly local classical scenarios such as Bertlmann's socks. QM violates the assumptions of Bell's theorem by not allowing for a conditioning on ##\lambda##.
Yes, you're right; ##\lambda## is integrated over, but the factorization occurs inside the integral.
