A difficult boat and river problem
  • Thread starter Thread starter Swap
    Boat River
The discussion focuses on solving a physics problem involving a boat crossing a river with a constant speed, u, while the river flows at speed nu. The key equations derived include dr/dt = u(1 - n sin(theta)) and two additional equations relating the velocities in polar coordinates: nu sin(theta) - u = dr/dt and nu cos(theta) = r d(theta)/dt. The participants clarify the interpretation of velocities and provide insights into the integration process necessary to find the equation of the path, r = f(theta).
  • Understanding of polar coordinates and their application in physics
  • Familiarity with basic calculus, particularly integration techniques
  • Knowledge of vector addition and relative velocity concepts
  • Proficiency in solving differential equations
  • Study the derivation of velocity in polar coordinates
  • Learn about relative velocity in fluid dynamics
  • Practice integration techniques for differential equations
  • Explore applications of motion in a current, focusing on similar boat problems
Students and educators in physics, particularly those tackling problems involving motion in fluids, as well as anyone interested in applying calculus to real-world scenarios involving boats and rivers.
Swap
A boat is rowed with constant speed u starting from a point A on
the bank of a river of width d , which flows with a constant speed
nu . The boatman always points the boat at a point O on the other
side of the bank opposite to A. Find the equation of the path
r = f (theta ) for the boat.
dx/dt = v
I was able to find dr/dt in terms of theta. here is my expression dr/dt= u(1-nsin(theta)). The problem is when I integrate it i have to express dt in terms of d(theta) which I cannot find.
I don't understand the problem much. Is it the boat's velocity relative to the ground, or its velocity relative to the water, which always points towards the water? I guess it's the latter, because if n>1 then there is no chance that the boatman can guide the boat towards O.
Let's assume so. I think your equation is a little bit incorrect (just a little bit, most is fine). First, you should write down the formula of velocity in polar coordinates, i.e. write down \vec{v} in term of r , \theta and the unit vectors \vec{e}_r and \vec{e}_{\theta}. Then use the condition that \vec{v} is the sum of 2 velocity: u in the direction towards O and nu in the direction to the left. You should arrive at these 2 equations:
nusin\theta-u=\frac{dr}{dt}
nucos\theta=r\frac{d\theta}{dt}
From here, you can solve for r(\theta).
can u explain me how u arrive at the second equation. I don't understand it
Can you do step 1, i.e. writing down the formula of velocity in polar coordinates?
oh ok I got it. I didnt think of v=r(omega). Thx...
10K
  • · Replies 22 ·
  • · Replies 16 ·
