How Does Gravity Affect Equations in Vertical SHM Problems?
  • Thread starter Thread starter brendan3eb
    Shm
This discussion focuses on the application of the equation w=(k/m)^(1/2) in vertical simple harmonic motion (SHM) problems involving a mass attached to a vertical spring with spring constant k. Participants highlight the necessity of accounting for gravitational force (mg) when analyzing SHM, particularly in determining equilibrium points. The consensus is that while mg is crucial for establishing equilibrium, it can be neglected in the derivation of angular frequency w due to the equilibrium condition where spring force equals gravitational force. The discussion emphasizes the importance of understanding the differential equations governing SHM and the impact of gravitational forces on system behavior.
  • Understanding of simple harmonic motion (SHM) principles
  • Familiarity with spring constants and Hooke's Law
  • Knowledge of differential equations and their solutions
  • Basic concepts of forces, including gravitational force (mg)
  • Study the derivation of angular frequency in SHM, specifically w=(k/m)^(1/2)
  • Learn how to solve second-order differential equations in the context of SHM
  • Explore the concept of equilibrium in spring systems and its implications on SHM
  • Investigate the effects of external forces on SHM, particularly gravitational forces
Students and educators in physics, particularly those focusing on mechanics and oscillatory motion, as well as anyone seeking to deepen their understanding of the interplay between forces in vertical SHM systems.
brendan3eb
I have been doing quite a few SHM problems, and I just have a few questions in general. A lot of questions evolved from one particular problem type: A mass attached to the end of a vertical spring of spring constant k.
My questions:
1. How can we prove that we can use the equation w=(k/m)^(1/2) for this problem. Normally, you can just go:
ma=-ky
a=-k/m * y
a=-w^2*y
y's cancel out
w=(k/m)^(1/2)
but in this case you should have to account for the mg force, but in most solutions, I do not seem mg accounted for?
In one problem, I was asked to solve for the maximum amplitude the shm could have in order to not surpass a certain acceleration. Once again, all answers were along the lines:
ma=-kA
mg=-kA
A=-mg/k
Once again, how can you neglect the mg force?
My only idea is that since we determine the equilibrium point for most of these problems at the beginning - the point where the spring force matches the gravitational force - that they treat this equilibrium point like the spring's equilibrium point and can somehow, magically, neglect the spring force?
I have been doing problems for the last two hours, and still haven't really gotten much further on figuring this out..
you didn't prove that you could use w=(k/m)^(1/2). you have a second order differential equation y'' = -k/m * y
To solve this just try y = a sin (b *t) as a solution and then find out what a and b are.
if you would include an mg force then your new differential equation would become
y'' = -k/m * y - mg. try to prove that if y=F(t) is a solution of the first differential equation, that y = F(t) - mg/k is a solution of the second one.
When the spring is hanging vertically in equilibrium: Tension =Weight i.e ke=mg
When you displace it a small distance,x, Resultant force,F =mg-k(e+x)...use F=ma now.
  • · Replies 20 ·
